How to perform verification of the Statistical Analysis Software?
SGquality
I have an open source software (RStudio) that is used for t test, ANOVA, Correlation Test, etc. and wanted to know if there are "golden sample" data sets to give the known output?
I am basically trying to run this golden data set to get the desired output and show it like a verification of the open source software.
Thank you!
v9991
Thank you!
Referencing to text books is one option...but book or guide cannot be justified.and defended as standard.
One best approach is either to compare two different applications. Viz jmp vs minitab. Or jmp/minitab vs excel
For excel. We need to trace the steps ...of creating the entire details (simpler formulae could be done thru calculator. But very laborious )
Thisnis often best approach, as a. We have complete knowledge and confidence on the steps.of verification
Mike S.
Happy to be Alive
I am confused. Why could comparing to a book not be justified but comparing to another software program could?
If I have textbook that gives an example and answer, and my software matches that answer, what reasonable person would not consider that an adequate verification of the software for that type problem?
v9991
it is not about reasonable person; it is about the 'rationale', ' adequacy and reliability' of using a text book as reference.
when we want to perform verification, the reference has to be a standard. ( known - reliable -traceable etc )
1. the steps followed in book could be different OR not always explicitly outlined ; simplest examples could be like standard deviation calculated to population vs sample; rounding of no. of values/digits; and other intricacies as we go into calculation involving multiple steps.
I acknowledge that contents published in book are also verified/reviewed - proof-read ; but COTS-testing/release process is better and more reliable.
note :- guidance and standard are not equated with text book.
2. sl.1 is also relevant when we take a 2nd "commercial off-the-shelf" application; but its a reasonable consideration that it has gone thru necessary testing & release processes; which is better and more reliable than reference to an book.
and, as for excel, it is similar to COTS, and since its done inhouse, we are in-charge of complete reference used in verification process.
3. and obvious one of them are that, text books are prone to errors; which is why they publish errata etc.,
M How to perform Chelex DNA Method Verification in the lab General Measurement Device and Calibration Topics 2
R How do you perform verification of a NCR (Nonconformance)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
K How to perform Verification for a Gage that is used in Destructive Testing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
C Do I need to perform design verification Design and Development of Products and Processes 3
J How & how often to perform verification of Test Software of Automatic Test Equipment? General Measurement Device and Calibration Topics 3
M Must a company be 17025 accredited to perform internal calibrations? ISO 17025 related Discussions 7
J Starting a Weibull Analysis: Source on how to perform Weibull Reliability Analysis - Predictions, Testing and Standards 2
E When to perform accelerated aging studies and transport test(OQ or PQ) Qualification and Validation (including 21 CFR Part 11) 4
F Who can sit in/perform an API audit? Oil and Gas Industry Standards and Regulations 2
V Supplier wants to perform pre-qualifications prior to every run instead of locking in parameters. Supplier Quality Assurance and other Supplier Issues 7
M MDR requires the NB to perform "tests in order to check that the quality management system" EU Medical Device Regulations 3
M Define voltage and frequency to perform tests 61010-1 and 61326-1 for CE certification CE Marking (Conformité Européene) / CB Scheme 4
M Informational How to perform a clinical evaluation of medical devices – Part 2 – Level of clinical evidence and what sufficient clinical evidence means Medical Device and FDA Regulations and Standards News 9
L Gage R&R studies for identical Devices - Need to confirm the requirement to perform them Reliability Analysis - Predictions, Testing and Standards 2
M Informational How to perform a clinical evaluation of medical devices – Part 1 – Overview and sample of activities Medical Device and FDA Regulations and Standards News 0
blackholequasar Internal Auditing Inspiration - Getting volunteers to perform internal audits. Internal Auditing 22
E Input to ANOVA 1-WAY - How can I perform this analysis in minitab? Using Minitab Software 2
B AS9102 FAI & Lower Level Drawings - How should we perform the FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
M Perform a coating weight test within 3 hours of processing the parts Manufacturing and Related Processes 2
D How to ensure independence and authority necessary to perform QM tasks ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Q How to perform Process Capability for true position Statistical Analysis Tools, Techniques and SPC 11
H Do you have to perform an full internal prior to IATF 16949 audit? IATF 16949 - Automotive Quality Systems Standard 21
J Internal Audit clarification - How to perform the audits IATF 16949 - Automotive Quality Systems Standard 6
S When will notified bodies be ready to perform audit to the MDR? EU Medical Device Regulations 1
chris1price Is there a regulatory (MDD, MDR, FDA, ISO, etc) requirement to perform a mock recall? CE Marking (Conformité Européene) / CB Scheme 4
P Can CEO perform internal audit Internal Auditing 11
B How to perform a MSA - GRR (Gage R&R) A&R/ANOVA Vs GUM/VDA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
W DCMA and AS9100C - Dedicating a week and 5 auditors to perform a AS9100C audit AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
W How to perform validation for an epoxy curing station Manufacturing and Related Processes 3
C How to perform Gauge R & R on Automated Test & Measurement Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
E How do you perform a GR&R for system software generated values? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
B Do I need to perform Gage R&R on a Digital Temperature & Humidity Gage Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 18
G Plant Relocation - Is it necessary to perform FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
L Who can perform ISO 9001:2008 Internal Audit prior to our Registration Audit? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
R Registrars offering to perform Second Party Audits - Have they failed their role? Registrars and Notified Bodies 112
V Is it required to perform Process Validation for food or dietary supplements? Food Safety - ISO 22000, HACCP (21 CFR 120) 4
E Should companies that perform calibration services be ISO 17025 accredited? ISO 17025 related Discussions 13
W Hiring an External Auditor to perform our AS9100 Compliance Audits AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
E How to perform Discrimination check for Dial Indicator? General Measurement Device and Calibration Topics 2
A Do we need to perform Qualification and Validation? ISO 13485:2016 - Medical Device Quality Management Systems 3
A Does ISO/TS 16949:2009 require us to perform Final/Pre-dispatch Inspection? IATF 16949 - Automotive Quality Systems Standard 5
N Example of how to perform a Visual Attribute Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
J How do you perform a S3 Stability Study for a Non-Replicable Measurement System Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
K Do we need to perform Analytical Method Validation upon Relocation? General Measurement Device and Calibration Topics 5
R Looking for service provider to perform residual dirt test, GME7061 General Measurement Device and Calibration Topics 2
J Is MS Outlook a sufficient reminder to perform yearly supplier evaluations? Quality Manager and Management Related Issues 10
T How to perform an MSA on Cross Hatch Test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
P Is it necessary to perform Root Cause Analysis for each failed part? Problem Solving, Root Cause Fault and Failure Analysis 16
R Can a Distributor perform Packaging Validation? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
