How to Properly Calibrate a Bore Gage
marcez2
I would like to know the appropriate way for claibrating bore gages..
Should I calibrate the whole component, with the bars, the anvils and everything..assembled..? Or can I calibrate only the dial gage..? I would be very grateful if someone can help me..Thanks so much..
Re: how to properly calibrate a bore gage?
If you're not sure about how to go about it, it's probably best to have it done by a qualified calibration lab.
Wes Bucey
I agree! Plus, it may be time to check your definition of what YOU mean by "calibration" which you should compare with "certification" to NIST Standards.
Almost always, the mere fact one asks such a question is a strong indicator the person asking is not clear on what really needs to be done.
Most metrology experts would cringe in a manner similar to a brain surgeon cringing when someone asks what size hole saw to use to open a patient's skull.
marcez2
Re: How to properly calibrate a bore gage?
why?
We have saved lots of money by calibrating instruments inside..
I have temperature and humidity control, an analyst very well trained, good work instructions.., good masters , We are a machining factory, we have hundreds of different kinds of instruments therefore, we are really saving a lot of money, because several instruments are very easy to calibrate..
Anyway, I still have that doubt, because some people in the plant have complained to us..when they see that we disassemble the bore gage to calibrate it and we only calibrate the dial gage.I tell them that the accesories does not have any kind of identification, I mean, that there is no traceability, and because of that it is possible to interchange them with any dial indicator and in that way it is impossible to know if the calibration has been made with a specific group of accesories , that is the reason why I calibrate only the dial indicator.
But, I am very interested in knowing other opinions..I would be very grateful if you can help me with further information
marcez2
and anyone know how a certified calibration lab do it?....
Ashwani
hiiiiiiiiiii
i think you should concentrate on the IS for bore gauges related information.
we used to calibrate in assembled condition.
You can use a ring gauge for internal calibration.
If you have elctronic probes you may go for calibration with ring gauge using TIR method, but probe calibration is must in it.
Ring gauges for calibration you can get from good instrument manuf organization or prepare inhouse
just dont forget to get it hardened chrome plated to minimise the rate of wear.
one more thing if you calibrate it by ring matster gauge you need not get it calibrated from external lab if your master ring is calibrated from NABL / IEC 17025 accredated lab.
i will provide you in detail knowledge in a few hours as i am a bit busy
marcez2
At present I calibrate only the dial indicator with primary calibrated block gages..
If I calibrate the complete bore gage as you say with master rings I should have hundreds of different master rings..because I must calibrate in 0%, 25%, 50%, 75 % and 100% of the total range of the instrument and in that way you have lots of possibilities because each different accesory gives a differente range of measurement to the device, I cant imagine dealing with such a complexity..
anyones hasa procedure or work instruction?
Calibration should include the entire gage. So what if the dial indicator is calibrated. If the anvils are worn or damaged, the bore gage will have bias regardless of whether the dial indicator is calibrated or not.
Ashwani
if thats case
you can use the calibration setup's from different manufacturers like LVDT based etc.
O Is it mandatory for Medical Devices to work properly after dielectric strength tests? IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
R How to properly use Survival Analysis to predict time to machine failure Reliability Analysis - Predictions, Testing and Standards 0
A Federal 700B-26 Gage Block Comparator is not reading properly General Measurement Device and Calibration Topics 0
J Properly understanding SPC - Newbie SPC questions Statistical Analysis Tools, Techniques and SPC 34
M Help with SCAR - Not all sub-assemblies had properly received a First Article Nonconformance and Corrective Action 2
Sidney Vianna Interesting Discussion IAF CertSearch Database - Repository of "properly" Accredited Management System Certs ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 79
drgnrider Calibration Schedule (Frequency) not properly reflected on Laboratory Paperwork Calibration Frequency (Interval) 7
E How to Properly Apply Linearity - How does it "Fit"? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
J Aerospace Parts not Evaluated Properly by Trained Person AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
Sidney Vianna How do philanthropic foundations ensure their projects are properly managed? Coffee Break and Water Cooler Discussions 1
M Paperwork not Properly Filled Out and Signed Off Internal Auditing 9
Stijloor The Government can not print money properly... World News 8
E Control of Outsourced Processes (not properly described in the quality manual) ISO 13485:2016 - Medical Device Quality Management Systems 44
S How to show that policies are properly communicated & Training Effectiveness ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
G How to properly check British Standard threads? 3-wire method and a supermic General Measurement Device and Calibration Topics 39
K Training package to help train operators how to use a measuring devices properly General Measurement Device and Calibration Topics 8
P U-chart Sanity/File Review - Is the chart constructed properly? Statistical Analysis Tools, Techniques and SPC 2
C Who is responsible? Checking if the documents are properly in order ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
M I have a feeling that my talent is not utilised properly Career and Occupation Discussions 11
A Looking for a third party to calibrate our measure equipment - South Carolina General Measurement Device and Calibration Topics 6
I Can I Calibrate On Demand? General Measurement Device and Calibration Topics 9
S Calibrating our own equipment, can we? Micrometers to calibrate vernier calipers General Measurement Device and Calibration Topics 13
F Crimper Calibration - How do you Control & Calibrate your crimpers? Calibration Frequency (Interval) 13
P How to Calibrate a HP 3458A Digital Multimeter with Fluke 5080A calibrator General Measurement Device and Calibration Topics 1
B Choosing not to calibrate (IATF 16949) IATF 16949 - Automotive Quality Systems Standard 6
K New Kilogram - The process we use to calibrate the standards General Measurement Device and Calibration Topics 6
D How to Calibrate any Digital Sphygmomanometer under use for 2 years in a Hospital Forum News and General Information 1
L Re-calibrate after software update? Calibration Frequency (Interval) 3
J To Calibrate or not to calibrate electronics rack components Manufacturing and Related Processes 5
T How to Calibrate Taper Gages General Measurement Device and Calibration Topics 1
N Calibrate temperature on refrigerated Centrifuges? General Measurement Device and Calibration Topics 2
B Can we calibrate a standard pin with a gauge? General Measurement Device and Calibration Topics 2
D Lesser expensive to calibrate various test weights General Measurement Device and Calibration Topics 5
A How to Calibrate Laser Beam Tester & Radiation Monitor General Measurement Device and Calibration Topics 3
D How to Calibrate and Verify a Heating Oven General Measurement Device and Calibration Topics 3
P How do you calibrate a VNA (Vector Network Analyzer) cal kit? General Measurement Device and Calibration Topics 4
V How to Calibrate Ring Force Gauges Service Industry Specific Topics 1
bobdoering Who says you can't calibrate a steel rule! Funny Stuff - Jokes and Humour 14
S How can I Calibrate a Biosafety Cabinet? General Measurement Device and Calibration Topics 1
C How to Calibrate a Viscosity Tester General Measurement Device and Calibration Topics 3
0 Is it possible to use a threaded ring gage to calibrate the M8 gage? Calibration and Metrology Software and Hardware 4
C How to Calibrate a Medical Infrared Thermometer General Measurement Device and Calibration Topics 3
T How do I calibrate NPT Thread Plug Gages? General Measurement Device and Calibration Topics 9
E Do you need a Certification to Calibrate Gauges? General Measurement Device and Calibration Topics 2
B Calibrate Hole Presence Detection Device? General Measurement Device and Calibration Topics 5
J What do you use to Calibrate 40" Calipers General Measurement Device and Calibration Topics 10
A Guideline to Calibrate Chamber Temp. & Pressure of a Medical Steam Sterilizer General Measurement Device and Calibration Topics 8
S How to calibrate AOI (Automated Optical Inspection) for IOPQ Qualification and Validation (including 21 CFR Part 11) 3
S Laboratory to Calibrate Objective Micrometer needed General Measurement Device and Calibration Topics 4
C Tolerance Estimation of a Load Cell I want to Calibrate General Measurement Device and Calibration Topics 9
