How to Properly Calibrate a Bore Gage
jfgunn
#11
Questions for Bore Gages: What type of bore gage are you using? Does it have a three point measuring head or two? Does it have a removable dial indicator? Does it have setting rings with it?
The previous suggestion of GIDEP is a good one. They have a nice procedure that I would like to attach except that that would be a federal crime! If you have 1 military contract, go to www.gidep.org and sign up for free.
We are an accredited lab for bore gages. For a threee point measurment device, we specifically make a note on our accreditation scope that if the gage has a removable dial indicator, that we will remove it and just calibrate the indicator. We will then peform a function test of the bore mechanism and fixtures.
If the gage has two points, we will use an id stack of gage blocks and calibrate everything.
If the gage has setting rings, we calibrate those and use the rings to check the bore gage.
If the gage has setting rings, we will
#12
Unless the rules changed, if you supplied to a company that supplied to the US government, you could join for free. This meant that any supplier of GM could join.
marcez2
#13
I would really like to know the opinion of some professional who works on a specialized lab..
Anyone there..?
Anyone has sent a bore gage to calibrate in a lab?
Stijloor
#14
Anyone there..?
Yes yes! We are here, and many of my Fellow Covers have tried to help you. :yes:
The most obvious response to your request would be: "Have you talked to the manufacturer of the bore gage?"
In addition, most equipment comes with operating- and calibration information/instructions.
Many organizations use these types of gages. Your best bet is, and just to make sure, is to go to the source.
Stijloor.
harry
#15
Anyone there..?
......................We are an accredited lab for bore gages. For a three point measurment device, we specifically make a note on our accreditation scope that if the gage has a removable dial indicator, that we will remove it and just calibrate the indicator. We will then peform a function test of the bore mechanism and fixtures.
Have you missed the above response? It's from the Lab Manager of an accreditated lab for bore gages.
merrick65
#16
I would recogmend calibrating the indicator and then the bore gauge as whole system/unit. You could always put a tamper eseal on the gauge to verify the indicator hasn't been changed. We calibrate bore gauges with master ring gauges and also with a bore gauge calibration fixture (developed in house).
Dale D. Barnes
#17
People with more knowledge than I have answered but I will tell you how I accomplish the task.
I have many (close to 40) different size bore gages. I use Mahr Federal Maxum gages and Marposs E4 column with M1 Star handles. I have always calibrated my bore gages as one solid piece (yes they can be interchanged but no one but the gage lab is allowed to do that, so they would be re-calibrated).
My method of calibration was to certified NIST traceable gage blocks and certified Nist traceable parrallel bars. I would place the bars in a vice and stack the blocks to the correct minimum and maximum size and take readings on the bore gage. This was very time consuming so I started purchasing minimum rings and maximum rings (always have nominal rings with the gage). This made the process go a lot faster and in the long run saved money. Now that is not to 25%, 50%, 75%, and 100% of the tolerance but it allowed me to check nominal, min to that specific bore gage size, and max to the same size. I have never had an auditor find any problem with either method that I used. We are an automotive supplier and are audited to ISO and 17025 so I cannot speak on other areas of manufacturing but what I deal with daily.
Hopefully this will give you some idea what is possible. Another point is that the rings are calibrated to an outside source. I have the equipment to do the rings but it also is time consuming so I am still sending them out.
Dale
TamTom
#18
by lloking for a procedure for bore gauges i found your thread. At the moment I would like the just check the function point.
But I think we have to point gages, so hat to you mean by using gauge blocks? How do this ? Didn't I need rings?
I really would apriciate if you could be more specific.
Regards,
TamTom
bryan norris
#19
Re: how to properly calibrate a bore gage?
If you're not sure about how to go about it, it's probably best to have it done by a qualified calibration lab.
Can someone direct me to the correct ANSI/ASME standard referencing calibration of dial bore gages? It appears to have been B89.1.21 in 2012 but I am unable to locate this standard on the ANSI site. I am primarily interested in knowing if ASME requires that our calibration lab allow dial bore gages to acclimate to lab temperature for 24 hours prior to calibration/certification of the gage.
dwperron
#20
ANSI/ASME B89.1.21 is a draft standard, it has yet to be released.
The standard Air Force procedure (33K6-4-992-1) calls for an 8 hour soak time.
O Is it mandatory for Medical Devices to work properly after dielectric strength tests? IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
R How to properly use Survival Analysis to predict time to machine failure Reliability Analysis - Predictions, Testing and Standards 0
A Federal 700B-26 Gage Block Comparator is not reading properly General Measurement Device and Calibration Topics 0
J Properly understanding SPC - Newbie SPC questions Statistical Analysis Tools, Techniques and SPC 34
M Help with SCAR - Not all sub-assemblies had properly received a First Article Nonconformance and Corrective Action 2
Sidney Vianna Interesting Discussion IAF CertSearch Database - Repository of "properly" Accredited Management System Certs ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 79
drgnrider Calibration Schedule (Frequency) not properly reflected on Laboratory Paperwork Calibration Frequency (Interval) 7
E How to Properly Apply Linearity - How does it "Fit"? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
J Aerospace Parts not Evaluated Properly by Trained Person AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
Sidney Vianna How do philanthropic foundations ensure their projects are properly managed? Coffee Break and Water Cooler Discussions 1
M Paperwork not Properly Filled Out and Signed Off Internal Auditing 9
Stijloor The Government can not print money properly... World News 8
E Control of Outsourced Processes (not properly described in the quality manual) ISO 13485:2016 - Medical Device Quality Management Systems 44
S How to show that policies are properly communicated & Training Effectiveness ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
G How to properly check British Standard threads? 3-wire method and a supermic General Measurement Device and Calibration Topics 39
K Training package to help train operators how to use a measuring devices properly General Measurement Device and Calibration Topics 8
P U-chart Sanity/File Review - Is the chart constructed properly? Statistical Analysis Tools, Techniques and SPC 2
C Who is responsible? Checking if the documents are properly in order ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
M I have a feeling that my talent is not utilised properly Career and Occupation Discussions 11
A Looking for a third party to calibrate our measure equipment - South Carolina General Measurement Device and Calibration Topics 6
I Can I Calibrate On Demand? General Measurement Device and Calibration Topics 9
S Calibrating our own equipment, can we? Micrometers to calibrate vernier calipers General Measurement Device and Calibration Topics 13
F Crimper Calibration - How do you Control & Calibrate your crimpers? Calibration Frequency (Interval) 13
P How to Calibrate a HP 3458A Digital Multimeter with Fluke 5080A calibrator General Measurement Device and Calibration Topics 1
B Choosing not to calibrate (IATF 16949) IATF 16949 - Automotive Quality Systems Standard 6
K New Kilogram - The process we use to calibrate the standards General Measurement Device and Calibration Topics 6
D How to Calibrate any Digital Sphygmomanometer under use for 2 years in a Hospital Forum News and General Information 1
L Re-calibrate after software update? Calibration Frequency (Interval) 3
J To Calibrate or not to calibrate electronics rack components Manufacturing and Related Processes 5
T How to Calibrate Taper Gages General Measurement Device and Calibration Topics 1
N Calibrate temperature on refrigerated Centrifuges? General Measurement Device and Calibration Topics 2
B Can we calibrate a standard pin with a gauge? General Measurement Device and Calibration Topics 2
D Lesser expensive to calibrate various test weights General Measurement Device and Calibration Topics 5
A How to Calibrate Laser Beam Tester & Radiation Monitor General Measurement Device and Calibration Topics 3
D How to Calibrate and Verify a Heating Oven General Measurement Device and Calibration Topics 3
P How do you calibrate a VNA (Vector Network Analyzer) cal kit? General Measurement Device and Calibration Topics 4
V How to Calibrate Ring Force Gauges Service Industry Specific Topics 1
bobdoering Who says you can't calibrate a steel rule! Funny Stuff - Jokes and Humour 14
S How can I Calibrate a Biosafety Cabinet? General Measurement Device and Calibration Topics 1
C How to Calibrate a Viscosity Tester General Measurement Device and Calibration Topics 3
0 Is it possible to use a threaded ring gage to calibrate the M8 gage? Calibration and Metrology Software and Hardware 4
C How to Calibrate a Medical Infrared Thermometer General Measurement Device and Calibration Topics 3
T How do I calibrate NPT Thread Plug Gages? General Measurement Device and Calibration Topics 9
E Do you need a Certification to Calibrate Gauges? General Measurement Device and Calibration Topics 2
B Calibrate Hole Presence Detection Device? General Measurement Device and Calibration Topics 5
J What do you use to Calibrate 40" Calipers General Measurement Device and Calibration Topics 10
A Guideline to Calibrate Chamber Temp. & Pressure of a Medical Steam Sterilizer General Measurement Device and Calibration Topics 8
S How to calibrate AOI (Automated Optical Inspection) for IOPQ Qualification and Validation (including 21 CFR Part 11) 3
S Laboratory to Calibrate Objective Micrometer needed General Measurement Device and Calibration Topics 4
C Tolerance Estimation of a Load Cell I want to Calibrate General Measurement Device and Calibration Topics 9
