How to Prove and Explain to Consultant (Internal Auditor) and Manager?
dr0mbu1
hello all,
how to prove,to explain to consultant(internal auditor) and manager what:
1.consultant(internal auditor) should to warn about internal audit
2.internal auditor must to inform me during the audit
3.internal auditor must to told me in advance or topics would be audited
4.auditor must cover all of the audit results with you before issuing the final report.
thanks
Ajit Basrur
Re: how to prove,to explain to consultant(internal auditor) and manager? i tired
Hi dr0mbu1
Sorry didinot quite understand your question. Can you pl rephrase it ?
I didnt quite understand your position - are you an employee or an external consultant to that organization ? :confused:
Stijloor
hello all,
thanks
Am I correct to assume that the consultant is hired to conduct internal audits at your organization? If this is the case then the consultant/internal auditor should comply with the internal audit procedure established by your organization.
In a good audit program the consultant/internal auditor should:
  • Adhere to the organization's internal audit schedule so there would be no surprises.
  • Inform the auditee about any nonconformities.
  • Submit an audit schedule prior to the audit.
  • Report the audit results per your organization's audit procedure.
You should discuss the audit program and all pertinent details with all parties involved prior to conducting the audit to prevent problems.
An excellent document to assist you is ANSI/ISO/ASQ QE19011S-2004 "Guidelines for quality and/or environmental management systems auditing - U.S. Version with supplemental guidance added." This document is based on ISO 19011.
I hope this helps.
Stijloor.
dr0mbu1
Hi dr0mbu1
i am an employee, QC.
CliffK
Re: How to Prove and Explain to Consultant (Internal Auditor) and Manager? I tired
dr0mbu1,
From your initial post, it sounds like you were audited without advance notice, the auditor failed to tell you the audit status, and you were not told of negative findings before the audit report was given to your manager.
For yourself, you probably have to live with what occurred.
For the organization, you can point out that this kind of behavior from an auditor makes people uncooperative so that they undermine and subvert the audit program. Problems or potential problems will not be detected.
A successful internal audit program requires trust, which comes from openness and honesty on the part of all participants.
Wes Bucey
hello all,
thanks
I think I see the situation. dr0mbu1 works as an employee at a company and would like an idea of what the ideal relationship should be between the employee (or manager) whose area is being audited and a paid consultant doing internal auditing for the company where the employee works. Many of you readers may have other ideas, but I think the following might be a good start.
Yep. I think it is common courtesy to schedule the audit in advance and let EVERYONE know the schedule. No one is on vacation without having someone to replace him. Work which would keep folks from being able to deal with auditor may be rescheduled. This way, auditor doesn't stand around waiting for someone to show him things he wants to see or answer questions he wants to ask and crucial work is not delayed while auditor performs an audit.
If you are the employee or the manager/supervisor, you have a right to know who the stranger lurking and snooping around your area is and what he's looking for.
This one is a little less cut and dried. The employee or supervisor whose area is being audited has a duty to have EVERYTHING ready to be audited. This means
  • documents normally expected to be available at or easily accessible to a work station are there (the boss's job!)
It means the employee working at a station should know, at a minimum,
  • where the goods or material he works on come from [the previous step in production], how he assures the goods or material are suitable for him to work on,
  • how he is supposed to handle the situation when he comes across nonconforming product before, during, or after he works on it,
  • what he is supposed to do with or to the product to prepare it for the next step in production and how he knows that [follow written or verbal order or a blueprint?]
  • where the product he works on goes next [the next step in production],
  • who he should go to if he has a problem he can't handle and if he has power to stop production until his question is resolved.
Sometimes, especially in internal audits, it is a matter of efficiency to target only parts of the full list of things which should be happening at a work area. Many auditors like to emphasize they are looking for how well corrective action is proceeding on a previously reported nonconformance. These same auditors may recognize the importance of having accurate, up-to-date work instructions and customer specifications and will alert everyone that such documents will CERTAINLY be under scrutiny in addition to other items.
Yes! This is absolutely crucial. Sometimes auditors misinterpret what they observe and it helps to clear the air. Sometimes the person whose area is being audited is not exactly clear about what he is doing or why he is doing it, even if he is doing it correctly. At the very least, the person whose area is under consideration and his supervisor should be present when that area of the audit is discussed prior to writing the final report.
One thing I want to emphasize: any audit is of the PROCESS, not the individuals performing the work. If the process is found to be nonconforming, we hope the auditor will not play the blame game, but will call attention to the fact the process needs to be corrected, not the individual.
Any of our other readers have comments? I'd like to hear especially from independent folks who are paid to perform an internal audit at someone else's organization (not a third party registrar from an accredited body.)
What do YOU tell the auditees in advance? Who all is attending at the closing conference if you are presenting nonconformances?
dr0mbu1
thanks to all of you :thanx:
Wes Bucey thank you very much:thanx:.
Right now my consultant(internal auditor) play the blame game and blame me for nonconforming.
E
Elynn
My employees do 'mess' in an audit as the processes thought to be the 'best' are not practical .
At the end of the day, the accountability falls back to the Management. Employees may be responsible for making sure processes passed down work as they are the 'lead actor' in the field. But as a Manager, creating the "best' process that doesn't fit practically is useless.
A proper IA should be scheduled and prepared for. Despite that, employees should be at all times ready for Audits with what processes they are practicing. Else, N.C. will be definite
Q Do we have to prove a link between the mill and our raw material supplier? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 9
P How to Scientifically Prove the Importance of a Process - CMMI Process Areas Software Quality Assurance 7
B How to prove that an organization implements anti bribery policy IATF 16949 - Automotive Quality Systems Standard 8
C UDI Label Verification - How do we ensure the barcode is correct and prove it? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
S How to Statistically Prove 2 Dimensions are Related Using Minitab Software 18
U Sample size to prove parts are good with 99.73% confidence Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
L What needs to be done to prove compliance with RoHS and WEEE EU Medical Device Regulations 5
A Is MSA useful to prove a Measurement System after Relocation? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
P How to prove that Cr oxide makes a stent biocompatible (e-polished 316LVM) Manufacturing and Related Processes 9
P Testing a US device in Europe to prove Equivalence in a ?head-to-head? Study EU Medical Device Regulations 6
J Reliability Prove-out, Pass-Fail Testing Reliability Analysis - Predictions, Testing and Standards 2
K What would you give up to prove conformity and honesty? Internal Auditing 21
S ISO 17025 requirements not enough to prove NIST Traceability? ISO 17025 related Discussions 10
I Prove or disprove that a cube can be cut in 27 smaller cubes in less than 6 cuts Brain Teasers and Puzzles 14
M How do I prove I don't receive a controlled product? Ractopamine Hydrochloride Misc. Quality Assurance and Business Systems Related Topics 4
C Clinical Data to Prove Equivalence Other US Medical Device Regulations 4
U Can anyone prove that: 2x2=5 ? Coffee Break and Water Cooler Discussions 63
D Testing an Inspector to Prove Competency in Visual Inspection Records and Data - Quality, Legal and Other Evidence 2
S Lean System Developer - How should I work to prove myself? Lean in Manufacturing and Service Industries 19
M Planning requirement 5.4: How should the management prove compliance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J How to prove that we conform to legal requirements Miscellaneous Environmental Standards and EMS Related Discussions 11
L Is there any way to prove a process is in control other than with a control chart? Statistical Analysis Tools, Techniques and SPC 6
H How do we prove that we are improving the continual improvement process? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
L How do you prove you need resources? Misc. Quality Assurance and Business Systems Related Topics 5
J Finished Goods Testing - Using historical test data to prove finished goods OK Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
A Contract Review - How do you prove it? Contract Review Process 16
K Statistical Hypothesis Testing to prove signficant quality improvement or decline Statistical Analysis Tools, Techniques and SPC 6
Ronen E Can anyone please explain this? (510k submission requirement) Other US Medical Device Regulations 14
A Please explain MDR Rule 11 to me EU Medical Device Regulations 67
R Explain what "design change" is to people new to the industry ISO 13485:2016 - Medical Device Quality Management Systems 9
Sidney Vianna Interesting Discussion Hello IAF. Are you listening? Please explain the inconsistency in your IAF Mandatory Documents (2019) ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 6
John Predmore Explain Quality Management System (QMS) for the uninitiated ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
I Trying to explain some of the Management Review Inputs (AS9100D) Management Review Meetings and related Processes 10
T From 21 CFR to IEC 60601 - Please explain IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
E IATF 16949 Clause of 8.4.3 - Approvals - Can you explain to me IATF 16949 - Automotive Quality Systems Standard 1
J Please Recommend books that explain how to understand IATF 16949 IATF 16949 - Automotive Quality Systems Standard 3
E Definition QUALITY 4.0 - Somebody here could explain the meaning of Quality 4.0? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 2
M Please explain the following Automotive Acronyms IATF 16949 - Automotive Quality Systems Standard 3
M Help trying to explain accuracy procedure General Measurement Device and Calibration Topics 1
S Please explain Medical Device Product Classification Rationale 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
C Can anybody explain h.2 equation of GUM? Measurement Uncertainty (MU) 3
M Shewhart Control Chart for SPC In Excel - Explain the yellow and red marked column Statistical Analysis Tools, Techniques and SPC 2
S Class III Sampling Plan - Explain AQL vs. 95%C & 90%R Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
B AS 9104/1 - Can anyone briefly explain me what AS 9104/1 calls for? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 1
B Please Explain Clause 8.3 in ISO 9001:2008 Nonconformance and Corrective Action 4
arios Flowchart to explain the Medical Device Vigilance Reporting Process wanted EU Medical Device Regulations 4
A Customer Demands (MSA=Bias + GRR/2). Can somebody explain what it means? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
V Is there a form I can use to explain what I'm submitting PPAP for? APQP and PPAP 9
Sidney Vianna The GRI Report or Explain Campaign (Sustainable Development) Sustainability, Green Initiatives and Ecology 4
P EN ISO vs. ISO - Please explain to me EN ISO vs. ISO standards Other ISO and International Standards and European Regulations 3
