How to Quantify Significant Change for a Shelf Life Stability Test
#12
It's called "two-population hypothesis testing."
just to be picky the term is "two sample hypothesis test"
However, of more importance is that an alternative method may be more powerful: the matched pair test.
in a matched pair test, several test sets are developed where the materials adn processing are all the within each pair EXCEPT the thing that changed. Between 6 and 10 such pairs are created using independent set-ups/processing events. the statistical test to use would be the paired t test.
coolbreeze
#14
Hello again and thanks for clarifying.
In the context of sterile pouches seal stability - IMO the "significant change" clause is irrelevant. Even seal strength is not too relevant, though it's quite easy to measure and process, and thus tempting :) Of course seal strength has to be above an acceptable minimum, but much more important is the seal barrier (sealing) quality. The best way to demonstrate that is via biological challenge (sterility testing) but since it's a bit expensive and complicated, many start off with mechanical tests such as pressure testing (inflating and looking for pressure drops) and dye testing - each has their pros and cons. I am not aware of 1 comprehensive published standard covering this subject in a very good way - what I've seen is a combination of scattered published test methods, in-house developed test methods, and some (creative?) justifications. You could, though, make some good use of ISO 11607 (probably already are).
Cheers,
Ronen.
How does one determine the minimum acceptable seal strength when an actual failure limit cannot be determined if no failures were present during distribution testing? Although theoretical, is it typical to utilize the vendor's minimum seal strength specification?
Sam Lazzara
#15
I have a completely different angle on this topic. I am not that concerned about percent change, I am concerned about meeting the finished device performance specifications. These specifications should apply to sterilized devices throughout their labeled shelf life. I test devices post sterilization and aging to show they meet those specifications.
Ronen E
Problem Solver
Moderator
#16
It does make sense to set the vendor's minimum strength spec as a floor value, because there's no point in having one side of the pouch extra-strong while the other 3 are much weaker...
I think that in general focusing on seal strength is detrimental because it diverts one's attention from what's really important in that context - sealing. One could have a perfectly strong weld that is not properly sealed (=useless).
S How to quantify the Benefits of Internal and External OHS audits? Occupational Health & Safety Management Standards 4
D Visual Inspection - How do you quantify Visual Inspection for TS16949 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
J Quantify Quality Objectives? Auditing company's documented interpretation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
R PAPP Metrics - Can we quantify PPAP's? APQP and PPAP 7
U Power supply - Change From 160 to 300 Watts - Significant change? EU Medical Device Regulations 2
J Significant change related to design and intended use EU Medical Device Regulations 3
L Significant Production Run - How 300 was determined to be the minimum quantity APQP and PPAP 2
K Is a change that fixes a recalled device significant? Medical Device and FDA Regulations and Standards News 2
L Significant change notice for outsourced warehouse Medical Device and FDA Regulations and Standards News 2
qualprod The Perfect audit? External Audit causes a significant negative impact in a company General Auditing Discussions 9
Ed Panek Is Shelf Life Change a significant change? CE Marking CE Marking (Conformité Européene) / CB Scheme 7
K Interpretation of significant change - material change Canada Medical Device Regulations 3
R How long to wait for Notified Body Response - Potentially significant change to a medical device CE Marking (Conformité Européene) / CB Scheme 6
shimonv Non-significant notice of change to notified body EU Medical Device Regulations 4
C Suppliers re-classification from Critical to Significant or from Significant to Non-critical Supply Chain Security Management Systems 0
C Significant Organizational Changes - Documented Responsibilities Document Control Systems, Procedures, Forms and Templates 4
C EPA NPDES VISUAL ASSESSMENT - No Significant Storm Event ISO 14001:2015 Specific Discussions 0
M Notifying Registrar of Significant QMS changes ISO 13485:2016 - Medical Device Quality Management Systems 2
J Applying for 510K - What is a significant process change and what is not US Food and Drug Administration (FDA) 5
V Screening DOE with 7 Input factors and 4 responses - Significant factors Using Minitab Software 1
shimonv FDA released final guidance documents on what constitutes a significant change Other US Medical Device Regulations 2
R AS9100D Cl. 8.4.2 - Identify Raw Material as a Significant Operational Risk AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
G Sample Size, Significant Figures, Scale General Measurement Device and Calibration Topics 3
I Catch up 510(k) - Non-significant changes were made Other US Medical Device Regulations 1
M DOE: Significant factor or not Using Minitab Software 2
K Plastic Resin designated as Significant Characteristic Manufacturing and Related Processes 7
G Supplier Significant Environmental Aspects - Audit Finding ISO 14001:2015 Specific Discussions 21
A Significant Figures and Rounding SOP Document Control Systems, Procedures, Forms and Templates 4
E FDA Significant Change Interpretation - Guidance Document EU Medical Device Regulations 2
somashekar Industry examples of Significant Beneficial Environmental Impacts Miscellaneous Environmental Standards and EMS Related Discussions 3
Q Reporting Significant Medical Device Changes to Argentina's ANMAT Other Medical Device Regulations World-Wide 3
S Format for Significant Environmental Aspects Study ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
M Auto Parts Warehousing Facility ISO 14001 Significant Aspects ISO 14001:2015 Specific Discussions 23
R 4 Factors 3 Level DOE to determine which factors are significant Using Minitab Software 2
5 Number of 'significant digits' in measurements Inspection, Prints (Drawings), Testing, Sampling and Related Topics 31
R ISO is certified to ISO 14001:2004 - What are their Significant Environmental Aspects ISO 14001:2015 Specific Discussions 2
S Managing a Significant Number of Outstanding Non-Conformities Nonconformance and Corrective Action 6
E Significant Change and Guidance Documents for Medical Devices Other Medical Device Regulations World-Wide 6
E What's the difference: AIAG-PPAP's "Significant Production Run" and "Run @ Rate"? APQP and PPAP 11
T Health Canada Class III/IV "Significant Change" guidance interpretation Canada Medical Device Regulations 2
D Best Minitab Tool to determine a Statistically Significant Trend Using Minitab Software 5
C Significant changes between EN80079-34 and EN 13980:2002 which it replaces Manufacturing and Related Processes 7
K I've had a significant win with Safety Policy Occupational Health & Safety Management Standards 12
B Example of Production Process Change having Significant Consequences AS9100C 7.5.1.2 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
J Ford changing their acronym for Significant Characteristics from HIC to CTQ Customer and Company Specific Requirements 2
M Significant FDA Medical Device Marketing Shift... 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 10
R Definition Significant Event definition - 8.2.3.1 - Monitoring & Measurement of MFG Processes Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 4
C Does a "Significant Change" apply to Class II Medical Devices? Canada Medical Device Regulations 8
O Significant Production Run - 2.1 in Section 2 of the PPAP Manual fourth edition APQP and PPAP 3
B Rounding Numerical Values Up or Down with respect to the number of Significant Digits Measurement Uncertainty (MU) 9
