How to read and interpret an SIPOC (Suppliers Inputs Process Outputs Customers)
Q
QAMTY
Hi everyone
Doing several process maps in several process by using SIPOC.
After maps were done, I don´t clearly see the benefits of mapping.
I include in the sketches Suppliers, Inputs Processes, Outputs and customers.
I fed all data, and after mapped, don´t know how to "read" the SIPOC.
Are there some methods, or special ways to analyze the SIPOCS?, so that we can "discover" why process are running wrong, additionally
how to analyze at the same time several processes and finding
the elements which are causing problems.
I read on the net that can be useful before a project starts and can be detected the points in problems.
Or SIPOC are used just to document the processes?
Thanks for your feedback
John Broomfield
@Qamty
The result of your SIPOC process analysis should be your as-is procedure for that process but this can depend on the software you used.
It should also identify any needed improvements.
What was your objective for doing the SIPOC process analysis?
Please upload an example so we can see why SIPOC process analysis did not fulfill that objective for you.
Cheers,
John
Hi everyone
"SIPOC" is a typical Six Sigma over-complication of a useful concept. Add in the "S" and the "C" adds nothing of value, unless a person is unaware of the existence of suppliers and customers. Input-Process-Output should be all you need, if that.
Marc
Fully vaccinated are you?
A quick Bump from 8 years ago. Short and 'sweet'. I agree with @Jim Wynne 's post above which I put into my file about 20 years ago.
I am using the SIPOC every times when figuring out the relationship between the supplier and the internal/external customer processes.
Some times it can be used together with 5 why analysis and fish bones diagram to identify the potential root cause of an issue.
It is depended to us on how to plan the study for the investigate whether we need to drill down to the specific small process that causes the problem. However, I found this is a good tool helping my to analysis in a standard/systematic flow to look at during the study.
John Predmore
If you take 10 minutes and write down what is obvious to you in a SIPOC, then I agree, there is little value [to you] in that exercise. Maybe a visual aid is useful to explain your business to a new employee or a visitor. Maybe a diagram can help organize your thoughts better. The same could be said about many of the basic quality tools, if you don't go past what you already know, the tool provides little value for the effort.
The true value of SIPOC is not the lists (which come out of your mind and are previously known to you), but seeing the connections and requirements that were potentially not apparent, and seeing the flow of information and "value" (which is hidden except to a trained eye), and seeing the gaps in your understanding and recognizing what is missing, which is absolutely not visible until you see it for the first time.
I think the real power of these simple diagram tools is when it enables human minds to see past the obvious and discover previously-unrealized factors you would otherwise not identify or recognize sequences or relationships you would otherwise not uncover.
J Setting accuracy limit for a read out General Measurement Device and Calibration Topics 4
A Read instruction manual - What Graphic Symbol must I use? US Food and Drug Administration (FDA) 7
M How to read a calibration certificate for thermo hygrometer General Measurement Device and Calibration Topics 2
R How to keep track of employee read-only training ISO 13485:2016 - Medical Device Quality Management Systems 14
M Informational Interesting read for risk managers – The Psychology of Prediction Medical Device and FDA Regulations and Standards News 1
R Over read of physiological data by technicians EU Medical Device Regulations 0
B QRQC vs JIDOKA - I read somewhere that QRQC is like a French version of JIDOKA Problem Solving, Root Cause Fault and Failure Analysis 2
Marc Posting Job Openings - Read Me Please - 27 January 2019 Job Openings, Consulting and Employment Opportunities 0
D Do people read PEARS (Process Effectiveness Assessment Report)? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
B Does Anyone utilize MS Outlook Read Receipts ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
J Good Internal Audit Read Internal Auditing 0
I Has anyone read BIP 0115:2014? ISO 13485:2016 - Medical Device Quality Management Systems 5
M What positions are required to read your quality manual? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
A How to read an analog instrument during calibration Measurement Uncertainty (MU) 2
M Effectiveness of Read-Only Training for Procedures Training - Internal, External, Online and Distance Learning 4
S Read Only & Password Protected - Sufficient to Control Documents under 4.2.3? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
K Where you can read other companys' 483 FDA Warning Letters 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
S Poll result difference : how do you read it? Statistical Analysis Tools, Techniques and SPC 4
J Does Every Staff need to read the ISO9001 Quality Manual from Cover to Cover? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
M What do 'Read Across', 'Drill Deep' & '6 Panels' mean in GM's QSB Sheet? IATF 16949 - Automotive Quality Systems Standard 2
Marc Experts Determine Age of Book 'Nobody Can Read' World News 9
J How to read the "Median Rank Table" for Weibul Plots Statistical Analysis Tools, Techniques and SPC 2
automoto What are the VDA 5 requirements? Can't read German VDA Standards - Germany's Automotive Standards 2
L The Checklist Manifesto - Anyone read? Book, Video, Blog and Web Site Reviews and Recommendations 15
V Opinions of those who have used/read David Hoyle's ISO 9000 Handbook Book, Video, Blog and Web Site Reviews and Recommendations 2
A How to read a BS6001 Sampling Plan? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
M Minitab 15 - READ, SET from keyboard or file doesn't work in my macro Using Minitab Software 4
A Does anyone read another's blog? Coffee Break and Water Cooler Discussions 2
A A MUST READ---cross selling...good one.. Funny Stuff - Jokes and Humour 3
G Swine Flu PPT.. Do read !!! Coffee Break and Water Cooler Discussions 10
Y Which version of ISO 9004 would you recommend to read today? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
M Getting employees motivated to read and follow procedures ISO 13485:2016 - Medical Device Quality Management Systems 7
ScottK Make sure to read the en.Wikipedia home page today After Work and Weekend Discussion Topics 0
Manix I read this and thought of you lot!! Coffee Break and Water Cooler Discussions 4
Marc What Comic Strips do you read every day? Coffee Break and Water Cooler Discussions 23
V IMO our people don't need to read manuals or procedures and document changes to them Document Control Systems, Procedures, Forms and Templates 60
Marc Look Across, Read Across - GM - Visteon Customer and Company Specific Requirements 2
Scott Catron PLEASE READ before posting or viewing threads Funny Stuff - Jokes and Humour 0
Z Good sites to read up on ISO14001 Miscellaneous Environmental Standards and EMS Related Discussions 4
P GM's "Read Across" Process that shares 8D results across divisions and locations Customer and Company Specific Requirements 4
Q Gage Supplier - Need a 72" (min) Digital Read Out LLM for the Shop Floor General Measurement Device and Calibration Topics 2
ScottK Does anyone else here Read and/or Collect Comic Books? Coffee Break and Water Cooler Discussions 20
D Does anyone know where to buy an instant read dosimeter? ISO 13485:2016 - Medical Device Quality Management Systems 10
C Struggling to teach a co-worker how to read dial calipers, any advice? General Measurement Device and Calibration Topics 13
K What magazines do you read for enjoyment? Coffee Break and Water Cooler Discussions 26
B Star Wars Books - Anyone Else read/reading them? Coffee Break and Water Cooler Discussions 5
D Micrometer that will read accurately to .00001 inch - Seeking General Measurement Device and Calibration Topics 11
R SPOILER: Don't read if you haven't finished Harry Potter and the Mud Blood Prince Coffee Break and Water Cooler Discussions 19
J Looking for Quality/Mfg. books that read like novels Book, Video, Blog and Web Site Reviews and Recommendations 16
D Read or recite? Is it OK to read the company quality policy from a sheet of paper? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
