How to Record Informal Testing (Not Verification/Validation)
ga2qa23
Hello all, I'm a medical device startup and we're trying to understanding if we need to (or even should) record informal testing of our R&D prototypes. I have an electrical medical device with a circuit board inside and its own software. It's a simple Class 2 device on the low-risk side. We coded the software ourselves. We're not building anything in-house. I'm purchasing everything (custom-made circuit board, hardware, a plastic shell, etc.) from third-party contract manufacturers, and it'll be send to a separate vendor for final assembly, packaging, and sterilization.
Basically, we already did a bunch of quick/informal testing with low-fidelity mockups of our medical device. But now we're getting into high-fidelity (near-perfect) prototypes. We're starting to do the same testing as we'd do for our final verification/validation testing. We're basically testing the high-fidelity prototypes against our "Design Input" requirements, electrical safety tests (IEC 60601-1), electromagnetic tests (IEC 60601-1-2), and low-level software coding tests. It's not going to serve as our official verification/validation reports. This is just "preliminary" testing to make sure that our final parts will be able to pass the real verification/validation tests successfully the first time.
The big question is: do we need to record this informal "preliminary" testing? Should we even try?
There's really zero regulations/guidances about this subject. I understand that the intention of our Design History File (DHF) is to record the conception/evolution/approval of our medical device design, but technically we can just do all the work and only do a design review/approval of our final prototype version (used for final verification/validation testing). I also understand that FDA expects human factors / usability testing to be conducted as part of the medical device development, but that's mostly separate from everything I mentioned above.
I guess I could record the "preliminary" testing on some special kind of test report, but be clear that there's no real "acceptance criteria"???
And for low-level software testing, I guess I could also record the test results on informal test reports?
Or should I just do the "preliminary" testing, not write anything down formally nor informally, and just roll with it?
Zero_yield
No cost too great...for Quality
Hello ga2qa23,
The term that gets thrown around at my workplace for this kind of activity is "skunk work" (which a Google search suggests came from Lockheed, but I digress). You often have to do a lot of tinkering before you even understand a concept well enough to design a good experiment.
I would only document these activities as much as is useful to the development process and good project management. If you're not even at the point where you have acceptance criteria, I would keep making iterations with only internal documentation until you get to your actual validation and verification testing.
Development of medical devices can be glacial at times. Take advantage of being able to move nimbly in this phase of development.
ga2qa23
Hello ga2qa23,
Thanks for your help! We already have acceptance criteria already. The requirements that we're testing against are very straightforward. We're also going to do some "preliminary" testing of our hardware with the vendor we selected to certify our future/final medical device against IEC 60601-1 and IEC 60601-1-2.
But what do you personally mean by "internal documentation"? Is that a document that's not technically version-controlled / approved by test personnel & Quality Assurance personnel? Like if we put a prototype in the oven to see if it still worked after being exposed to high temperatures, would you just write it down on an 'uncontrolled' Word file and keep it outside of the Design History File (DHF)?
Could you please give a general example from your experience?
William55401
Your QMS design control procedures are important. When does Design Control begin for this project? Mature organizations establish a bright line between research / skunk works and put in formal controls (read as documentation with approvals and all the fun the comes with it). This is your company. Establish compliant procedures that make sense for how you want to operate. To me, declaring when the project is in scope of the QMS procedures is a key step,
ga2qa23
The Design Controls are already in-place. We've written our product requirements (Design Inputs), we've done supplier evaluations, and we've done circuit board diagrams / hardware diagrams / software source code. But they're not the "final" versions yet yet. We already had prototypes manufactured with them but they're still not considered ready for final verification/validation testing. They're not the actual "Design Outputs" just yet. We wanted to conduct a bunch of "preliminary" testing with our high-fidelity prototypes, so we know it's good before we can make final changes to become the "finished" design.
In the future, we "finish" our drawings/software. We would arrive at our "final" versions for each "Design Output" that can be used for the final verification/validation testing.
You should absolutely record the preliminary testing. This is known as feasibility testing. The information gained from the feasibility testing may result in design changes. You should be capturing the justification for changes even in the early stages. I would document feasibility testing in your controlled laboratory notebooks. (I hope you have these.)
ga2qa23
We don't have paper binders of "controlled laboratory notebooks" but we use Microsoft Word and we basically have a formal template for a "Verification/Validation Test Plan" as well as the resulting "Verification/Validation Test Report". So we have that. Isn't that satisfactory for an FDA-regulated medical device?
It is pretty much industry standard to have laboratory notebooks. They can be paper or electronic, but they need to be controlled and the content protected. The purpose is to document organizational knowledge for the future benefit of the company. Have you ever wanted to go back and figure out the justifications for design decisions, and then you realize this information was never documented? I have experienced that, and it is not fun.
ga2qa23
I would greatly appreciate if you could help me understand: so it's not technically required then right? My team has a bunch of uncontrolled Microsoft Word files being used for that purpose. But in my understanding, it's not actually required to have controlled laboratory notebooks (paper or electronic) in order to get FDA 510(k) approval for our medical device.
C Bulk Record Retention Review Records and Data - Quality, Legal and Other Evidence 4
R Device Master Record Vigilance ISO 13485:2016 - Medical Device Quality Management Systems 5
S Record of Disciplinary Action ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
E PMS record retention time for legacy devices EU Medical Device Regulations 1
Sam Lazzara Record signature requirements in proposed FDA 21 CFR 820 QMS Regulation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
A ISO 13485 Calibration Requirements- Assess and Record validity Previous measuring results ISO 13485:2016 - Medical Device Quality Management Systems 5
M How to record the effects of adjacent systems (shown in boundary diagram) in the AIAG-VDA DFMEA form FMEA and Control Plans 0
S Record approval- Signatures required ISO 13485:2016 - Medical Device Quality Management Systems 4
B Acquired Medical Device Product Line - Documentation Requirements for Device Master Record ISO 13485:2016 - Medical Device Quality Management Systems 7
D Device Master Record (DMR) checklist ISO 13485:2016 - Medical Device Quality Management Systems 1
G How to record Regulations and Standards as Design Inputs? Design and Development of Products and Processes 15
M Record Retention Verbiage Needed for "Lifetime" Retention EU Medical Device Regulations 14
M Sample record for verification performed by importers before placing a device on the market EU Medical Device Regulations 0
S IVD Device History Record ISO 13485:2016 - Medical Device Quality Management Systems 5
E Record Retention - Raw Material (Steel Certs) Records and Data - Quality, Legal and Other Evidence 3
E Procedure ( SOP) for Device Master Record ( DMR ) and for Device History Record (DHR)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
S Records - Do's and don't' of record entries (FDA - 21 CFR 820) Records and Data - Quality, Legal and Other Evidence 13
N Importer of record - Europe EU Medical Device Regulations 0
M Question for Auditors - "Off the Record" Conversation? General Auditing Discussions 14
C GUDID Device record history Medical Device and FDA Regulations and Standards News 2
D IATF16949 7.5.3.2.1 Record Retention - Our Product or Customer Product? Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 1
S How do you record your Nonconforming product? Batch production of staged processes Nonconformance and Corrective Action 2
I Can a document (form) approval record be separate? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
M Defining and Documenting Record Retention CE Marking (Conformité Européene) / CB Scheme 5
Q Forms Master List versus Record Matrix ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
B Record Management - Does the QMS need to control templates of records? Records and Data - Quality, Legal and Other Evidence 17
S Service record requirements for Non-Serviceable Medical Devices CE Marking (Conformité Européene) / CB Scheme 1
R No design history file or device master record ISO 13485:2016 - Medical Device Quality Management Systems 5
Sam Lazzara Medical Device File (MDF per 13485:2016 4.2.3) versus FDA Device Master Record (DMR) ISO 13485:2016 - Medical Device Quality Management Systems 3
I What kind of information needs to be in a calibration record? General Measurement Device and Calibration Topics 25
E ISO 9001:2015 - Record requirements for out of calibration tool ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 28
N ISO 13485 Quality Record Retention Period ISO 13485:2016 - Medical Device Quality Management Systems 4
M Loss of a Quality Record - FDA Inspection Records and Data - Quality, Legal and Other Evidence 4
B MDSAP 8.2.6 CH6 task 17 ANVISA 16/2013 3.2.1 - Label History in Device history record Other Medical Device Regulations World-Wide 3
I Training records and levels - When does training NOT need a record? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
Gman2 Quality Record Retention (Internal Audits, CA's) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
R Are DMR (device master record) and DHR (device history record) inspected by FDA or audited by an NB ISO 13485:2016 - Medical Device Quality Management Systems 9
N When to record values if a spec for a mfg process is set Manufacturing and Related Processes 3
S Mobile app data privacy - Length of record retention in a software app Medical Information Technology, Medical Software and Health Informatics 1
S Foreign Manufacturer and DMR - Who keeps the DMR (Device Master Record)? ISO 13485:2016 - Medical Device Quality Management Systems 2
M Medical Device News Health Canada - Scientific Advisory Panel on Software as a Medical Device (SAP-SaMD) - Record of Proceedings – January 26, 2018 Canada Medical Device Regulations 0
J Training Record Template and tracking Document Control Systems, Procedures, Forms and Templates 1
S DMR (Device Master Record) for Medical Device Software IEC 62304 - Medical Device Software Life Cycle Processes 3
D Design Outputs vs DMR (Design Master Record) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
H In-house device calibration record - Actual values obtained required? General Measurement Device and Calibration Topics 9
M Is referenced content sufficient to meet record content requirements? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
R Reissuing pages of a record 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
S Record Retention - How long must a company keep the following records? Records and Data - Quality, Legal and Other Evidence 17
M Batch record supersedes all other instructions 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
