How to Reuse Obsolete Documents - Guidance needed
Arsalann
Can anyone telme how can I be ableto re-use obsolete documents??? IS there any guideline, refrence ?? Plase let me know about this.....
Thanks,...
G
grandmaz
Re: Guidance needed on how to reuse obsolete documents
I don't see why you couldn't just review the document for any updates that may be needed, and release it. No sense in recreating the wheel when you don't have to.
Welcome to the Cove. :D Good answer!
Sidney Vianna
Post Responsibly
Thanks,...
I am afraid that we would need additional information in order to better answer your question. Can you be more specific to what type of document you are referring to? Is it a drawing? a procedure? a bill of materials? Why was the document made obsolete?
There is a difference between an obsolete document (which technically should not be used any longer) and a previous version of a document. Some organizations produce, repair and/or overhaul several versions of a same product. In that scenario, one must be concerned in using the APPLICABLE/APPROPRIATE version of a document, which might be an old version of a current document. Just because it is not the latest version of the document, it does not mean that it is obsolete.
AliInMo
Our company will sometimes obsolete a product, so the work instructions will be pulled and made obsolete. Then, for some reason, a customer will want to go back to using that obsolete product, so it is re-launched. In that case I will retrieve the obsolete document and send it out for review to make sure there were no changes made during the re-launch and then re-release the document using the Rev. that it was at when it was made obsolete (unless of course there were changes made, in which case it would be moved to the next Rev.). This is one of the main reasons I keep Word versions of obsolete documents on file.
Randy
The obsolete document is a record that could be referenced, it's under control to prevent unintended use, so establish an intent and then reference it.
Either that or re-enter it under your document control process.
Do what works best for you.
Arsalann
In my case, I have an obsolete documents which cant be use again for same purpose. If I do not re-use it, the empty vacancy remains in my documents e.g, ab-01, ab-02, ab-04 etc... ab-03 is an obsolete. But, I want to handle it by giving another topic. If I give another name to this, then my documentation work will increase further. So, I wanna re-use without more documentation.
somashekar
You are then not having an identity of your obsolete document. Now do you need to keep the ab-03 example as obsolete ?
This is the question.
See what 4.2.3 of ISO9001 says at g)
g) to prevent the unintended use of obsolete documents, and to apply suitable identification to them if they are retained for any purpose.
If you do not want to retain them at all, then do your way. Then you have no obsolete document and no question of re-use.
If you need then then give suitable identification.
In your example, if you give ab-03 an other identification for being obsolete., and then use the ab-03 for a current document, your purpose of reducing more documentation stands defeated, rather you are burdened more.
harry
I think what the original poster is saying is that:
1. He had some obsolete documents in his system.
2. Can he reuse the document numbers (used to identify the document) assigned to these obsolete documents for some new documents.
3. He thinks he can save time by re-using these document numbers
I think what is key but not clear here is what is meant by 'same purpose'.
Generally, if used for the 'same purpose', you just obsolete the older version and replace with the current ones denoted by a revision number and/or revision date. The original document numbering remains.
I How to Reuse an Obsolete Document? Quality Manager and Management Related Issues 7
N Where to find Regulations for Reprocessing and Reuse of Single-Use Devices Other Medical Device Related Standards 2
K ISO 15223-1 Do Not Reuse and Do Not Resterilize Other Medical Device Related Standards 5
I Reuse PCBs in a Medical Device ISO 13485:2016 - Medical Device Quality Management Systems 6
A Safety Shoes & Temporary Workers - Is it correct to reuse again or not? Occupational Health & Safety Management Standards 11
H Is there a Standard on the Reuse of Resin in Extrusion Process? ISO 13485:2016 - Medical Device Quality Management Systems 1
M Is it compulsory to update the obsolete GMDN codes in ARTG? Other Medical Device Regulations World-Wide 4
R FDA - How to discontinue/obsolete medical devices that share sub-components with others that will still be distributed Other US Medical Device Regulations 5
W Is it required to stamp obsolete hard copy DHR's "obsolete"? ISO 13485:2016 - Medical Device Quality Management Systems 6
L Do you need to save hard copies of obsolete documents? Document Control Systems, Procedures, Forms and Templates 10
A UDI on medical device: Does it make other markings obsolete? EU Medical Device Regulations 2
J Obsolete or Delete - Accepted Components from Suppliers RoHS, REACH, ELV, IMDS and Restricted Substances 3
xcanals_tecno-med.es ISO 14969 (Now Obsolete) --> ISO 13485 handbook ISO 13485:2016 - Medical Device Quality Management Systems 16
T Master Document List - Obsolete Documents Document Control Systems, Procedures, Forms and Templates 23
T Handling of Obsolete Material Work Instruction ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S Difference between Obsolete, Void and Inactive Document Control Systems, Procedures, Forms and Templates 2
D AS9100C 4.2.3 - Obsolete Electronic ERP Documents AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
W Control of Obsolete Documents Document Control Systems, Procedures, Forms and Templates 21
T Document Control Master List for Obsolete Documents Document Control Systems, Procedures, Forms and Templates 6
D Do we need to take a SA for a standard that is going to be obsolete? Other ISO and International Standards and European Regulations 2
B Reusing paper of Obsolete Documents to Control Waste Document Control Systems, Procedures, Forms and Templates 12
S Can you "Obsolete" a record (inspection reports)? Records and Data - Quality, Legal and Other Evidence 13
L Easy Access of Obsolete Documents - Corrective Action help needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
I When was IEC 60601-1-4 made obsolete? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
apestate How do you sell a DCMA Inspector on replacements for obsolete items? Various Other Specifications, Standards, and related Requirements 9
T Obsolete Document References in other Documents AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
R Save Obsolete Documents in Plant Closing? Document Control Systems, Procedures, Forms and Templates 15
T Obsolete Uncontrolled Electronic Documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
A How do you retain Obsolete Documents? Document Control Systems, Procedures, Forms and Templates 18
E Particular standard IEC 60601-2-40 references obsolete EMC standard IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
Marc 12 Things That Became Obsolete This Decade - 2000 - 2010 Coffee Break and Water Cooler Discussions 13
Jerry Eldred Guildline 9975 DC Comparator Resistance Bridge Manual Needed (Obsolete) General Measurement Device and Calibration Topics 2
P Obsolete Quality Records - Approval Prior to Disposal Records and Data - Quality, Legal and Other Evidence 15
P AS9100 4.2.3 Control Of Documents - Requirement to retain Obsolete Documents? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
A Component supplier electrical test requirement - Obsolete Components Other Medical Device and Orthopedic Related Topics 2
T Reasons for retaining Obsolete Documents and Retention Time Document Control Systems, Procedures, Forms and Templates 13
R Obsolete a DoC if NB (Notifying Body) changed EU Medical Device Regulations 3
P Removal of Obsolete copies of Controlled Documents ISO 13485:2016 - Medical Device Quality Management Systems 8
K 93/42/EEC Obsolete Document Retention requirements - New timeframe? Document Control Systems, Procedures, Forms and Templates 3
Jerry Eldred Document Retention of Obsolete Calibration Procedures General Measurement Device and Calibration Topics 4
Q Obsolete Documents vs. Inactive Documents Document Control Systems, Procedures, Forms and Templates 22
K How long do you keep copies of your obsolete documents, not records just documents? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
J Control of Obsolete Documents - Changing document control software ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
chris1price Support for Obsolete Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 3
H What do you do when a part goes Obsolete and How do you Initiate such a Process? Document Control Systems, Procedures, Forms and Templates 7
A Obsolete Document Retention Requirements ISO 13485:2016 - Medical Device Quality Management Systems 4
K Document Control Terms: Obsolete, Master Copy, Controlled and Uncontrolled Copy Document Control Systems, Procedures, Forms and Templates 2
Marc B-school Confidential - MBAs May Be Obsolete Professional Certifications and Degrees 19
Marc Is the quality profession about to become obsolete? Paradigm Shift Philosophy, Gurus, Innovation and Evolution 19
R Obsolete Standards - Need J 377:1987 SAE standard, where can i get this old one? Various Other Specifications, Standards, and related Requirements 3
