How to Schedule Mercury-in-Glass Thermometer Calibration
darkafar
We have three mercury-in-glass thermometers. We calibrated them before first putting them into use. That was about one year ago. By the suggestion on the calibration certificate issued by an external lab, we should calibrate them once per year.
I’m not fully convinced that we should calibrate fluid-in-glass thermometer once per year. I prefer to calibrate them once for all. I want to see, how other factories schedule their liquid-in-glass thermometer calibration activities.
harry
Re: Mercury-in-glass thermometer, how to schedule calibration?
I suppose the first question you need to answer is: where you use it, how often and how critical are the readings to your process?
darkafar
Suppose it is a thermometer to measure warehouse temperature, how do you schedule its calibration?
BradM
Scheduling calibration will certainly depend upon other factors. As far as the calibration interval, that is up to your discretion.
I would develop some recommended interval, as mercury can become separated and yield some erratic readings.
It's all about risk and return. You can go out longer than a year, but you risk having more exposure to failure.
Based solely on my opinion and practice, we usually verify them once a year. But note, that's just one user and one practice.
harry
Unless you have temperature sensitive materials like some type of glue, paint, chemicals, etc. otherwise it shouldn't be a big problem. As one cover posted in another thread, are you interested in knowing whether it is telling the truth?
If needed, can you verify it with another thermometer - preferably a calibrated one used elsewhere. If not, can you compare its reading with another one or two. The logic is not all 2 or 3 can be out in tandem. If the readings are inconsistent (within limits) it is an indication that one or more may be out. Finally, you may want to check the zero degree (ice point) or boiling point. This is what they do with thermometers used for general purpose in the food industry where +/- 1 or 2 degrees is acceptable.
P
potdar
Certain equipment are 'calibrated for life'. It depends on where you put them to use and what is the likelihood of them going out of calibration. A fluid in glass thermometer is one such equipment. If you see no reasons for it to go out of calibration where you use it, it is calibrated for life. It will either break or it will continue working ok.
Other such examples are glassware used in a laboratory. A burette or a pipette is calibrated for life if used to measure solutions. The same is not true if it is measuring suspensions. The suspensions may erode the device / cause deposits on it - causing it to go out of calibration.
amanbhai
Re: How to schedule Mercury-in-Glass Thermometer calibration?
We somehow calculate the amount of kerosen oil in bulk containers & it could easily cost us millions.
We had two options 1. chinese made thermometer was costing very little to us (as much as 10 time less) than the Uk made but the accuracy of both totally different. The UK make is much better so we opted for UK.
Now, as far as the calibration is concerned it is the user who can define next calibration date not the calibration agency.somehow you have to justify that.
Calibration forever of Mercury-in- Glass thermometers........ i don't agree with this idea. I don't understand why?
:thanks:
Jerry Eldred
Although I've long held an INITIAL CALIBRATION ONLY view on liquid-in-glass thermometers, some very knowledgable colleagues over the years have shown me a good reason they need periodic calibration.
A not-too-well-known possibility for error on these thermometers is micro-fracturing inside. A small fracture (or multiple fractures) along the stem WILL cause negative temperature errors. Particularly on the ASTM type.
So if your application requires known accuracy, they definitely need periodic calibration (verification).
K
Karl_pmel_ssbb_cqe
Buy mercury thermometer with auxillary scale at 0C if needed so you can check at ice point.
Have calibrated initially: scale and ice point.
Inspect annually and prepare ice point bath per ASTM method, see change in ice point vs. past calibration. Apply change to scale, and use for this calibration cycle.
This is based on careful examination of thermometer at manufacture and subsequent calibration - i.e., sort out the bad ones.
The ice point shift is explained by the relatively thinner glass in the bulb and the thicker glass in the scale. The scale should have less change than the bulb. The bulb impacts the ice point as most of the mercury is contained in the bulb.
See J. Wise of NIST paper http://ts.nist.gov/MeasurementServices/Calibrations/upload/SP819.PDF
F
freelovefest
ISO is pretty clear about the need to only calibrate mercury thermometers initially and then drop them from the control program. I had always disagreed until I re-read ISO 14969, which is the techinical guide for the 13485 standard. The guidelines are paraphrased below:
"7.6.3 Some monitoring and measuring devices which require initial calibration or certification need not be included in the control programme. Examples of such equipment are
 mercury-in-glass thermometers,
 steel rulers, and
 laboratory volumetric measurement glassware that is not exposed to processes or environments which might affect its calibration.
Monitoring and measuring materials intended to provide a qualitative reference should be stored and maintained in a location which does not compromise the integrity of the material"
If you store your thermometers well, and there are no movable parts to them, this should be a good enough reference to use with any auditor. It certainly changed my thinking on the subject. Still, a good 20 year interval, with this guideline as justification should quell any concerns a regulatory body might have.
A Add MDSAP to Internal Audit Schedule Medical Device Related Regulations 0
N Internal Audit Schedule – Who gets to set the schedule? Internal Auditing 16
T Internal Audit Schedule when Hiring Out Internal Auditing 7
M Informational EU – Schedule of meetings of MDCG and subgroups – 2019 Medical Device and FDA Regulations and Standards News 2
R How far apart can you schedule separate areas or departments in your internal audit? Internal Auditing 4
A API Spec Q1 9th Edition - 12 month Internal Audit Schedule Audit Nonconformance Oil and Gas Industry Standards and Regulations 10
D Where I can find an ISO 13485:2016 Audit Schedule example? ISO 13485:2016 - Medical Device Quality Management Systems 4
J AS9100D - Good ways to document an internal audit plan / schedule Internal Auditing 25
D Delivery Schedule Performance - IATF 16949 Cl. 9.1.2.1-d IATF 16949 - Automotive Quality Systems Standard 3
K Is an annual "audit schedule" the same thing as an audit scope/ audit plan? Internal Auditing 8
B Need to convert Reference Only M&TE to a calibration schedule General Measurement Device and Calibration Topics 3
C Does anyone have an AS9100:2015 audit schedule template? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
D Please share your IATF 16949 Internal Audit Plan and Schedule Internal Auditing 13
M MDSAP Audit Plan - Please share an Audit Plan/Schedule/Agenda ISO 13485:2016 - Medical Device Quality Management Systems 7
P Internal Audit Schedule Complexity (ISO 9001:2015 ) Internal Auditing 3
A Developing a ISO 9001:2015 Internal Audit Plan and Schedule Internal Auditing 40
M Example Internal Audit Schedule wanted Internal Auditing 47
C DCMA (Defense Contract Management Agency) asking for Inspection Schedule Dates AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
L Sourcing Audit Schedule for Supplier Audits IATF 16949 - Automotive Quality Systems Standard 3
A Management Review not conducted according to schedule Management Review Meetings and related Processes 9
T Are Customers required to follow a Manufacturers Maintenance Schedule? ISO 13485:2016 - Medical Device Quality Management Systems 3
S No Audit Schedule and Internal Audit not Performed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
D Health & auditing/assessment schedule Imported Legacy Blogs 0
L R2 Certification Internal Audit Plan, Audit Sheet, and Schedule Manufacturing and Related Processes 2
B Is there an FDA requirement for a Supplier Audit Schedule US Food and Drug Administration (FDA) 22
S Help me with preparing Internal Audit Schedule based on Risk analysis 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
B ANVISA B-GMP Inspection Schedule Other Medical Device Regulations World-Wide 4
drgnrider Calibration Schedule (Frequency) not properly reflected on Laboratory Paperwork Calibration Frequency (Interval) 7
B Corrective Action for Deviation (delay) in the Delivery Schedule Quality Manager and Management Related Issues 10
R Internal Audit Schedule Conformance Quality Manager and Management Related Issues 31
Y Training Plan/Schedule - Can anybody share a format or template for annual training Training - Internal, External, Online and Distance Learning 8
J TS 16949 Clause 4.2.3.1 based on Customer Required Schedule IATF 16949 - Automotive Quality Systems Standard 2
L ISO 13485 Internal Audit Schedule example needed Internal Auditing 9
S Schedule D II Format for Medical Device Registration India Other Medical Device Regulations World-Wide 3
Moncia Supplier Audit Requirements for ISO 22000 - Is a schedule required? Food Safety - ISO 22000, HACCP (21 CFR 120) 5
T Schedule for SOP Review - Listing by Names of Process Owner versus Job Titles? Document Control Systems, Procedures, Forms and Templates 12
M QSIT-Based ISO 13485 Internal Audit Schedule Internal Auditing 8
K Seeking help in making a decision - Project behind schedule Quality Manager and Management Related Issues 11
Q Maintenance Schedule with Client in my Procedures? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
C Does anyone have an example of an ISO 14001 Internal Audit Schedule ISO 14001:2015 Specific Discussions 2
J Timing of an Internal Audit Schedule ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
R Receiving inspection and Internal Audit schedule ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
F How to Integrate Audits and Audits Schedule - ISO 9001 and OHSAS 18001 Occupational Health & Safety Management Standards 2
V Layered Process Audit Schedule example Process Audits and Layered Process Audits 2
N Second Party (Supplier) Audit - Audit Schedule and Audit Report Template/Format General Auditing Discussions 3
E Document Retention Schedule Requirements per ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 4
V How to calculate for LCL and UCL for Schedule Deviation Quality Tools, Improvement and Analysis 2
D Is there any software for making an Injection Molding Machine Schedule? Lean in Manufacturing and Service Industries 6
