How to Select a Statistically Valid Sampling Plan
H
hitesh
If any body can provide me incoming raw material inspection procedure which requires use of statical sampling inspection plan, I will appreciate it.
Sincerely,
Hitesh
H
hitesh
Re: Incoming Raw Material Inspection Procedure
Hi Harry,
Thanks for your feed back. I have verified "Incoming" and "Receiving" threads but I could not find any incoming inspection sampling procedure which uses statical sampling plan.
Please let me know if you have a procedure shows how to select AQL and Inspection Level for each particular group of product.
Regards,
Hitesh
Hi Harry,
Regards,
Hitesh
"Raw material" covers an awful lot of different types of commodities, so the type of procedures you're looking for will be unique to each organization. Determining requirements for receiving inspection is a matter of risk analysis, which will also be different for your company than it is for mine.
You need to familiarize yourself with the general concept of acceptance sampling, the various standard sampling plans available, and then determine what level of risk is acceptable for each type of incoming commodity you're dealing with. There's lots of information available here about receiving inspection and sampling plans. You can start with the list of related threads at the bottom of this page, and also use the Cove "Search" function.
H
hitesh
Hi Jim,
I am familiar with ISO 2859 series of standards. We have decided to use ISO 2859 -1 and ISO 2859-2 for our inspection purpose.
When you say "Risk" that the company is willing to take, do you mean risk in terms of AQL/LQ value?
Sincerely,
Hitesh
Hi Jim,
Sincerely,
Hitesh
I mean the risk you're willing to assume that using sampling plan x, "good" material will be rejected or bad material will be accepted.
Added in Edit: I just realized that this is an issue regarding medical devices, and I know next to nothing about those requirements. There may be specific sampling requirements that I'm unaware of.
H
hitesh
Thank Harry,
Yes, I am looking for how to select validated statical sampling plan and more specifically what AQL values are used most commonly in Medical Device Manufacturing Industry for Incoming Inspection.
Sincerely,
Hitesh
sshankle
The sampling plan parameters (such as AQL) you select will be based on the specifics for your company and the item(s) you are inspecting.
Another thing for your consideration is that AQL is producers risk. In medical devices it may be more apropriate to use LTPD (consumers risk) as your most critical parameter for basing your plan, but again this is situation specific.
I hope that helps...
Scott
H
hitesh
Thanks Mark,
I agree with you but the benefit of using AQL is that you can apply switching rules.
Sincerely,
Hitesh
M How to Select FDA Medical Device Product Code? Other US Medical Device Regulations 10
P Material selection - How do we select a raw material? Bolt made of SAE J994 grade 2 Customer and Company Specific Requirements 3
K How do you select the right grips for your tensile tests? Imported Legacy Blogs 0
Y Can manufacturer select AR for MDD different from AR for RED? EU Medical Device Regulations 5
B Historical Standard Deviation or Select Parts for MSA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S Excel Help - Equivalent of "Range($G$14:$AD$121).Select" in R1C1 notation Excel .xls Spreadsheet Templates and Tools 5
S A Standard for you to select Standards - ISO 16142-1 Other Medical Device Related Standards 1
R Is it possible to randomly select samples from 1 column to many column Using Minitab Software 2
B How important it is to select Parts that represent the Process Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
B How to select parts for a MSA Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 19
C UDI: HIBCC vs. GS1 - Recommendations regarding which one to select Other US Medical Device Regulations 2
T Select Updates for Non-Clinical Engineering Tests - Intravascular Stents Other US Medical Device Regulations 0
C When do I select Team for Black Belt Project? Six Sigma 3
R How to select appropriate standards for Multi-Functional Physical Therapy Equipment IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
J How to select pieces for GR&R (Gage R&R) Studies? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
L How to select an Authorized Representative CE Marking (Conformité Européene) / CB Scheme 2
somashekar Definition Evaluate and Select ... What are the most common understandings of these words. Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 12
A Who to decide and select Internal Auditors and what are the criteria? Internal Auditing 18
R How to select the the target value from spec. limit (18 samples) Statistical Analysis Tools, Techniques and SPC 4
C How to select the requirements for Continuous Sampling Plan (CSP-1&F), Mil-Std 1235C? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
A How to select equipment for MSA (Measurement Systems Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
C ASQ Examination Fees Increasing for Select Certifications Professional Certifications and Degrees 1
R Six Sigma vs. TQM - How to Select and What are their Differences? Six Sigma 2
M How to select a consultant to help out for ISO 14001 Certification? Consultants and Consulting 11
kedarg6500 How to Select Checking Aids APQP and PPAP 7
D Variable sample size - Xbar-s charts - How to select A3 and B4 Statistical Analysis Tools, Techniques and SPC 11
C What is the Best Way to Select a Registrar? The Reading Room 3
S Attribute MSA - Risk analysis -- How to select the samples Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Q Gage R&R - How to select samples near the limits? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S How to select the part for Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
Casana How to select a consultant? What criteria to consider and look for when looking Consultants and Consulting 5
P How To Select Regulatory (Regulatory Requirements?) For Implement Iso/ts 16949 IATF 16949 - Automotive Quality Systems Standard 3
Y How to select the most suitable person to be the Management Representative? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
B Operating Range & Measurement System Discrimination:How to select parts for R&R test? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S How to Statistically Prove 2 Dimensions are Related Using Minitab Software 18
F Sample Size to get Statistically Valid Data Measurement Uncertainty (MU) 6
S Statistically valid number of biopsy devices should be tested US Food and Drug Administration (FDA) 4
D Best Minitab Tool to determine a Statistically Significant Trend Using Minitab Software 5
P Sterile Packaging Validation - FDA Requirements for Statistically Valid Tests 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
K Statistically Valid Audit Sample for Management System Audits? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
F How to statistically determine the maximum performance life of a chemical Statistical Analysis Tools, Techniques and SPC 4
S Statistically valid method for multiple raw material sampling Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
H Process that is Not Stable vs. Not Statistically Capable - Differences Capability, Accuracy and Stability - Processes, Machines, etc. 9
J Demonstrate Receiving Inspection Sampling Method is Statistically Adequate Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
N Statistically Comparing Technician Techniques Reliability Analysis - Predictions, Testing and Standards 16
B Statistically Sound Data Sampling Technique for Internal Audits Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14
S Getting started with statistically based process improvement The Reading Room 12
M Statistically Toleranced Drawing Feature Dimensions - Target Value and Range Statistical Analysis Tools, Techniques and SPC 5
L How to Monitor Corrective Actions - Statistically Monitoring Corrective Action Nonconformance and Corrective Action 34
G Pp and Ppk indices - Is it statistically possible to have a Ppk greater than Pp? Capability, Accuracy and Stability - Processes, Machines, etc. 16
