How to select parts for a MSA Study
Rio BP Simbolon
#11
My Opinion. sometimes it's not easy to find 10 parts for MSA which represent their tolerance range, example at pierching process, which making hole with punch. Variation of its process depend on the punch.. and the diameter result is almost same with diameter punch, and we make punch diameter near to maximum spec....
In this condition we use sample which represent variation process.
#12
yes there are times such as tool wear where the initial process will set at a max (or min) position and the process variation at that level is relatively small.
In these cases we can't get an NDC calculation that has useful meaning. HOWEVER, we can plot the repeated measurements (either as vertical points for each part if using 3 readings or on a Youden plot if using only 2 repeated readings) vs the specifications and SEE teh amount of measuremetn error vs the tolerance spread and we can make a judgment as to the relative usefulness of the system.
Yes, it's subjective, but so is the 10%-20%-30% of the tolerance or some minimum NDC value. These 'acceptance limits' were subjectively set - they are not laws of physics.
We need to move beyond relying on 'following the rules' and checking some statistical output that says we met the goal or we didn't and begin to really think about our data and our processes.
U
unueco
#13
Re: How to select parts for a MSA study ?
Greetings!
I realize this discussion has been "dead" for quite a while. But it relates directly to some questions I have. So hopefully I can resurrect it.
Firstly....
Parts should be selected randomly such that they are representative of the full range and distribution of the process.
While this is the oft quoted advice concerning part selection, am I the only one who finds this to be a frustrating oxymoron? In the first place, if part selection is supposed to be "random" then how can I add a condition about the results of the selection? Secondly, how am I supposed to verify that the parts fit the criterion....oh, hey, I'll just measure them....but wait, I'm supposed to be verifying my measurement system ....so..???
Second.....
What is the actual effect of part variation on the results? I had a GRR that failed R&R at 78%. Just as an experiment, I added 0.02 to all the measurements from all the operators on the 10th part. The GRR results passed with an R&R of 3.08%. Why?
Assistance with understanding is greatly appreciated!
Thanks!!
#14
Random as opposed to the frequent (and wrong) recommendation to select parts from the full range of the tolerance. The key is to understand how your process varies. Does it vary over each cycle of the machine, each batch of raw material, by shift? It it varies by batch of raw material, sample 1 part from 10 different batches, not 10 parts from a single batch.
Second.....
It depends on the metric that you use. If you are using %Tolerance, part selection has zero impact. If you are using %Study Variation, ndc, or %Contribution, the part variation is part of the calculation. Increased part variation will reduce the %Study Variation and %Contribution while increasing the ndc.
Golfman25
#15
In my business that could take several years to collect enough parts (and even if we took a few from fewer batches, it could take a year). Now what?
#16
If you have prior capability studies, use the variation from those studies to calculate % Process Variation.
#17
Be practical, take the parts from what you have. If there really is substantial variation between batches, use logic to determine if you need a quick check for every new batch that might be in a very different dimensional location that's when you did the first R&R. There is no need to wait.
Golfman25
#18
We try to be practical. But the MSA requirements seem to prevent this. Typically, the MSA requirement arises with a new part and a new. Then they tell us to use parts with variation. Well you'd need to mess up your perfectly good tool to do that, and sometimes it hard enough to get the thing going at first. Sometime is seems like an exercise in futility just to get the "right" number to "pass." There has to be an easier way.
#19
Maybe not an easier way, but the only ways: get a better relationship with your Supplier Quality people to invoke 'logic and reason' OR get new Customers. There are simply a few industries with a few Customers who have SQEs that are nothing more than 'check the box' people. Very frustrating yes, but in these cases I've found the only way is to find another job.
Golfman25
#20
It's not always the SQE people at the customer. Sometimes it's that third party auditor.
How about instead of a one size fits all mandate, use your brain and figure out the best way to accomplish your goal commensurate with the risks involved. But that would make too much sense.
B Historical Standard Deviation or Select Parts for MSA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B How important it is to select Parts that represent the Process Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
B Operating Range & Measurement System Discrimination:How to select parts for R&R test? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
M How to Select FDA Medical Device Product Code? Other US Medical Device Regulations 10
P Material selection - How do we select a raw material? Bolt made of SAE J994 grade 2 Customer and Company Specific Requirements 3
K How do you select the right grips for your tensile tests? Imported Legacy Blogs 0
Y Can manufacturer select AR for MDD different from AR for RED? EU Medical Device Regulations 5
S Excel Help - Equivalent of "Range($G$14:$AD$121).Select" in R1C1 notation Excel .xls Spreadsheet Templates and Tools 5
S A Standard for you to select Standards - ISO 16142-1 Other Medical Device Related Standards 1
R Is it possible to randomly select samples from 1 column to many column Using Minitab Software 2
C UDI: HIBCC vs. GS1 - Recommendations regarding which one to select Other US Medical Device Regulations 2
T Select Updates for Non-Clinical Engineering Tests - Intravascular Stents Other US Medical Device Regulations 0
C When do I select Team for Black Belt Project? Six Sigma 3
R How to select appropriate standards for Multi-Functional Physical Therapy Equipment IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
J How to select pieces for GR&R (Gage R&R) Studies? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
L How to select an Authorized Representative CE Marking (Conformité Européene) / CB Scheme 2
somashekar Definition Evaluate and Select ... What are the most common understandings of these words. Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 12
A Who to decide and select Internal Auditors and what are the criteria? Internal Auditing 18
R How to select the the target value from spec. limit (18 samples) Statistical Analysis Tools, Techniques and SPC 4
C How to select the requirements for Continuous Sampling Plan (CSP-1&F), Mil-Std 1235C? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
A How to select equipment for MSA (Measurement Systems Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
C ASQ Examination Fees Increasing for Select Certifications Professional Certifications and Degrees 1
H How to Select a Statistically Valid Sampling Plan Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
R Six Sigma vs. TQM - How to Select and What are their Differences? Six Sigma 2
M How to select a consultant to help out for ISO 14001 Certification? Consultants and Consulting 11
kedarg6500 How to Select Checking Aids APQP and PPAP 7
D Variable sample size - Xbar-s charts - How to select A3 and B4 Statistical Analysis Tools, Techniques and SPC 11
C What is the Best Way to Select a Registrar? The Reading Room 3
S Attribute MSA - Risk analysis -- How to select the samples Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Q Gage R&R - How to select samples near the limits? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S How to select the part for Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
Casana How to select a consultant? What criteria to consider and look for when looking Consultants and Consulting 5
P How To Select Regulatory (Regulatory Requirements?) For Implement Iso/ts 16949 IATF 16949 - Automotive Quality Systems Standard 3
Y How to select the most suitable person to be the Management Representative? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
D Suggestions for Ishikawa for hyperdetailed customer - plastic molding automotive parts Nonconformance and Corrective Action 9
R Is a FAIR required on parts that we design? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
C Packaging Long Parts Manufacturing and Related Processes 3
D Separation of F-type applied part and remaining parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
John C. Abnet VDA 6.3 - Question 7.3 - "blocking of parts" VDA Standards - Germany's Automotive Standards 6
I When is necessary to have RoHS declaration on non-electrical parts? REACH and RoHS Conversations 1
Z Rapid audit template for plastic parts manufacturing process Manufacturing and Related Processes 12
C Scrapping on production floor - Setup parts 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
G Bad Parts cause Customer line stop IATF 16949 - Automotive Quality Systems Standard 13
G Calibration of "Master Parts" Used as Gauges Calibration Frequency (Interval) 5
P FDA Approved Product Contact Parts ISO 13485:2016 - Medical Device Quality Management Systems 6
M Identifying Applied Parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
M Nonconforming parts accepted by operator with intention Human Factors and Ergonomics in Engineering 33
J Mechanical inspection techniques of close tolerance parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
J Sister-company providing parts is only ISO 9001 registered IATF 16949 - Automotive Quality Systems Standard 7
A AS9100D 8.1.4 Prevention of Counterfeit Parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
