How to select the part for Gage R&R
Stevenli
In MSA manual, it mentioned select 10 parts to concduct the GRR, and we'd better to select those parts which can cover the whole process variation. Then my consultant said we can select some parts which are closed to LSL/USL.
My question is how can I select those parts from the production process? The probability is quite low concenring the normal distribution in the area of LSL/USL. Does anybody have a clue or can you show me your method?
Thanks a lot in advanced
Howard Atkins
Forum Administrator
I am afraid I can not help and I will complicate this:
This is one of the biggest problems that exist with GRR as if there is very little change between the parts then the GRR cannot be good as statistics deals very badly with "little change". Idealy you want parts that are out of spec as this gives the best results.
If the GRR is for the instruments and the operators why do you actually need to measure the same dimension and not collect 10 seperate dimensions with the same tolerance?
Because in general, GR&R is used to verify that the system is appropriate for use on a particular part. The subject of "families" has been discussed before, and it's true that sometimes there's no need to use specific parts, but care must be take to insure that surrogate data is reasonably analogous.
Ron Rompen
If possible, you can purposely MAKE parts which are 'beyond the norm', and which approach (or exceed) the USL/LSL.
I have done this in the past, especially for flatness measurement; on thin parts it is fairly easy to create virtually anything wanted.
Atul Khandekar
I believe that a GRR study requires that parts be selected from the process in such a way that they represent the entire process variation that occures during production. If you have SPC charts, you can study how the process varies over time and select parts over a period of time, not all at once.
Unfortunately, I have not not been able to find any supporting evidence for this. Question would be: exceed USL/LSL by how much? 10%? 50%? This is sure to reduce the GRR number (variable).
The Taz!
One more wrench for the works. . . . Once you have the parts selected, maintain them for periodic studies for the same gage family. Use the same samples year after year. This will help show degredation in the gaging process.
Of course, if you are making wings for 747's. . ..get a LARGE storage area!
:bonk:
M How to Select FDA Medical Device Product Code? Other US Medical Device Regulations 10
P Material selection - How do we select a raw material? Bolt made of SAE J994 grade 2 Customer and Company Specific Requirements 3
K How do you select the right grips for your tensile tests? Imported Legacy Blogs 0
Y Can manufacturer select AR for MDD different from AR for RED? EU Medical Device Regulations 5
B Historical Standard Deviation or Select Parts for MSA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S Excel Help - Equivalent of "Range($G$14:$AD$121).Select" in R1C1 notation Excel .xls Spreadsheet Templates and Tools 5
S A Standard for you to select Standards - ISO 16142-1 Other Medical Device Related Standards 1
R Is it possible to randomly select samples from 1 column to many column Using Minitab Software 2
B How important it is to select Parts that represent the Process Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
B How to select parts for a MSA Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 19
C UDI: HIBCC vs. GS1 - Recommendations regarding which one to select Other US Medical Device Regulations 2
T Select Updates for Non-Clinical Engineering Tests - Intravascular Stents Other US Medical Device Regulations 0
C When do I select Team for Black Belt Project? Six Sigma 3
R How to select appropriate standards for Multi-Functional Physical Therapy Equipment IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
J How to select pieces for GR&R (Gage R&R) Studies? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
L How to select an Authorized Representative CE Marking (Conformité Européene) / CB Scheme 2
somashekar Definition Evaluate and Select ... What are the most common understandings of these words. Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 12
A Who to decide and select Internal Auditors and what are the criteria? Internal Auditing 18
R How to select the the target value from spec. limit (18 samples) Statistical Analysis Tools, Techniques and SPC 4
C How to select the requirements for Continuous Sampling Plan (CSP-1&F), Mil-Std 1235C? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
A How to select equipment for MSA (Measurement Systems Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
C ASQ Examination Fees Increasing for Select Certifications Professional Certifications and Degrees 1
H How to Select a Statistically Valid Sampling Plan Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
R Six Sigma vs. TQM - How to Select and What are their Differences? Six Sigma 2
M How to select a consultant to help out for ISO 14001 Certification? Consultants and Consulting 11
kedarg6500 How to Select Checking Aids APQP and PPAP 7
D Variable sample size - Xbar-s charts - How to select A3 and B4 Statistical Analysis Tools, Techniques and SPC 11
C What is the Best Way to Select a Registrar? The Reading Room 3
S Attribute MSA - Risk analysis -- How to select the samples Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Q Gage R&R - How to select samples near the limits? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Casana How to select a consultant? What criteria to consider and look for when looking Consultants and Consulting 5
P How To Select Regulatory (Regulatory Requirements?) For Implement Iso/ts 16949 IATF 16949 - Automotive Quality Systems Standard 3
Y How to select the most suitable person to be the Management Representative? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
B Operating Range & Measurement System Discrimination:How to select parts for R&R test? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
F Physical Part Measurement General Measurement Device and Calibration Topics 3
S Clean room not part of my certification ISO 13485:2016 - Medical Device Quality Management Systems 2
A MDR ANNEX XI part A or Part B EU Medical Device Regulations 0
J Part submission warrant for Level 1 PPAP APQP and PPAP 1
K How to handle GTINs for different configurations of one device with one part number? Other Medical Device Related Standards 0
A 60601-1 : Integrated Dry ECG Electrodes = 2 Patient connections inside 1 applied part? IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
0 To which part of 13485 does this refer? ISO 13485:2016 - Medical Device Quality Management Systems 3
D Separation of F-type applied part and remaining parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
V Part selection for R&R studies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S ISO 9001:2015 vs 21 CFR Part 211 matrix Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
D CFR Title 14: Aeronautics and Space PART 120—DRUG AND ALCOHOL TESTING PROGRAM Federal Aviation Administration (FAA) Standards and Requirements 3
D Is PMCF really a continuous activity per Annex XIV,Part B? EU Medical Device Regulations 5
M 21 CFR 820 vs 21CFR820 vs 21 CFR Part 820 Document Control Systems, Procedures, Forms and Templates 3
N BF-type applied part MOPP vs secondary IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
D Relabelling a component that will be sold as a spare part - Do I become legal manufacturer? EU Medical Device Regulations 2
