One is to just do a stacked column chart that autoscales to 100%. The draw back is that it might show 50% done, but you don't see how many there were total.
The second concatenates the percentages to the Categories so they both are listed at the bottom of the chart.
Neither chart is really polished (eg no titles) but I figure you can do that to suit your own tastes.
note: if you are concerned about one chart in from of the other you can change scales (making scale of Y1 larger, the bar chart could be in one site and the percentage at the other.
You could add a second Y axis and and use the percentage figures there.
This is what I often do in paretos (The enclosed example uses accumulated percentage, but that is easily corrected...). You could also try a pie chart.
I have given a shot at this. This is kind of close to Darius, but there cannot be a trend line for percentage completion since i believe there is no relation to each of the variables listed. These can be just left as data points in the plot.
