How to show the effect of the failure mode on the manufacturing process as a customer of product design process?
morteza
Hi all,
The AIAG-VDA FMEA defines the customers as follows:
2.2.3 Define the Customer
There are two major customers to be considered in the FMEA analysis:
END USER: The individual who uses a product after it has been fully developed and marketed.
ASSEMBLY and MANUFACTURING: the locations where manufacturing operations (e.g., powertrain, stamping and fabricating) and vehicle/ product assembly and production material processing takes place.
In the DFMEA form, there is a column for showing the effect of failure mode on the end user. How can we illustrate the effects of failure mode on the manufacturing process (e.g. inadequate chamfer size leads to difficulty of the component assembly in the assembly line) as a customer? Assembly line is not the next higher level in DFMEA.
Thanks all
Tidge
I don't know if this will help in your circumstance, as I am unfamiliar with the construction and organization of information in the PFMEA documentation in your use... but I can describe how I addressed this problem for a manufacturing customer. I generated several baseline manufacturing process FMEA that were tied to the process (generally equivalent to major pieces of manufacturing equipment) rather than product. This would be akin to having a PFMEA for an injection molding process as opposed to having a PFMEA for each housing.
  1. The PFMEA informative documentation included a process flow. The process flow was a semi-abstract diagram that mapped the distinct process steps of types of manufacturing processes, as opposed to individual components that pass through the process.
  2. Typically: many steps in the general process for each component all lead to a similar "end result" of a non-conforming part.
  3. The different effects of a non-conforming part were analyzed in a distinct section.
Some explanation:
(1) The steps of the map were approximately mapped 1:1 with a work-order traveler used as pieces moved between different stations/area on the manufacturing floor. We expanded the map to include "process steps" that might not be part of any particular work order, such as equipment prep, maintenance, shutdown.
(2) All the steps in the process map had sections in the PFMEA worksheet, but most did not have any part-focused analysis. Instead, these sections direct the reader to review the "non conforming product" part of the worksheet. We did include the practices and controls that were in place for those specific process steps. For example: a setup step might have a risk control such as checking fluid levels, which might otherwise be cumbersome to call out as a risk control somewhere else in the process map.
(3a) Generally, the "non-conforming end result" section was the section of the process map where the physical work (on a part) is actually done... and where the mental work of analysis happens. For a deburring process, it would be when the worker applies the deburring tool to the part... as opposed to when prepping the grinder/knife/whatever or a post-deburring wash/rinse. It is important to note that this is where there need to be analysis of non-conforming outputs of the typical "too much, too little, wrong ____" as well as any special failure modes for unique design requirements (e.g. EMC/EMI shielding that may apply only to some parts).
(3b) The "non-conforming end result" will look very much what the DFMEA has, except that for PFMEA it is almost always the case that the manufacturing process isn't actually controlling design risks, it is more appropriate to say that the manufacturing process has controls in place to avoid introducing risks.
(3c) The organization of this non-conforming end result section will have output-specific lines. For my client: we categorized parts by product line, as the most serious (patient/user) risk was generally the same for all the parts that were produced via any given process. If there were special characteristics with unique risks for certain components, we sub-categorized. It is necessary to maintain a mapping of what parts belong to what lines of analysis.
I can offer some specific advice about deburring: Deburring is (in my experience) one of the few manufacturing process steps where it makes a lot of sense to have both "too much" and "too little" lines of analysis in a PFMEA, because the effects can be quite different for each. Just as an example: too much grinding can leave gaps for fluid ingress, too little can lead to sharp edges, pinched wires. In contrast, a punching process that leads to non-conforming parts is unlikely to lead to as many different effects.
morteza
Hi Tidge,
Thanks for your explanation. It was great for PFMEA.
My question was about on DFMEA. In the new AIAG-VDA DFMEA form, there is a a column namely " Next higher level or end user" to show the effect of the "design failure mode" on the next higher level or end user. If the failure mode have effect of manufacturing process (within the organization or customer plant), should we describe this effect in the "Next higher level or end user" column?
Tidge
My primary experience with DFMEA is with medical devices, one of the "left most" columns in our top level assessment of risks (we call this a Hazard Analysis) contains a link the use case (which includes the diverse user/patient profiles). It is typical that the "lines of analysis" in this top level risk file have multiple, unique "severity" ratings that are associated with specific harms. (the severity of each and every harm is established in a governance document, independent of design or project).
In DFMEA, we put controls in to mitigate the risks associated with the harms because the mfg process could introduce problems to the design. In the PFMEA, we put controls in to prevent the occurrence of these harms (most of the time, there can be exceptions). For simplicity, the severity ratings from the top level document are dropped down into the FMEA, and usually it is appropriate to only include the most severe rating... that is, a control or preventive measure for a specific harm will almost certainly be appropriate for the less severe harms (of the same type of injury).
G Kpi doesn't show action plan ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
Ashland78 Need to show evidence in accordance with QR-11012 and SPB-00001-09 Customer and Company Specific Requirements 5
Nihls When the MSA results show no operator influence Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
E Our company is planning to file MDD not MDR next month. Do we require to show chemical characterization report ? CE Marking (Conformité Européene) / CB Scheme 2
B IATF16949 audit requirement - Auditor request UCL and LCL must be show Xbar-R, IATF 16949 - Automotive Quality Systems Standard 7
F Hi friends, can anyone show me an example of a procedure for ISO 13485 6.4.1 Work Environment? ISO 13485:2016 - Medical Device Quality Management Systems 4
R How to SHOW the importance of checklists, through some team gaming or play? Training - Internal, External, Online and Distance Learning 37
Wes Bucey International Manufacturing Technology Show - 10 September 2018 - Chicago (meet up?) Coffee Break and Water Cooler Discussions 6
S What records are required to show compliance to ISO 13485:2016? ISO 13485:2016 - Medical Device Quality Management Systems 1
K Questions on Technical File to show it is current EU Medical Device Regulations 5
D How do I show compliance to RoHS, REACH and Conflict Minerals? REACH and RoHS Conversations 6
K Operator Checks - How to show that they were completed on a checklist as acceptable IATF 16949 - Automotive Quality Systems Standard 2
M Metric/Way to show how Internal DPPM and External DPPM relate to each other Nonconformance and Corrective Action 1
R Is it legal to attend a trade show while you have a 510(k) application pending? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
M Presentation displays for malls, etc. for exhibition to show products Coffee Break and Water Cooler Discussions 5
D Medica show in Dusseldorf - Has anyone else gone? Other Medical Device and Orthopedic Related Topics 3
W How to show compliance to multiple CE Directives ? CE Marking (Conformité Européene) / CB Scheme 4
T Is there a requirement in TS16949 that PO's show a revision level? IATF 16949 - Automotive Quality Systems Standard 3
S Which non Salmonella organisms show positive in Wellcolex? Test kit ? US Food and Drug Administration (FDA) 1
C Do I need to show fasteners in my BOM's/DMR etc? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
G What is needed to show competency Clause 6.2.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
W DIN ISO 1101 - Show me the General Dimensioning Tolerance Value Other ISO and International Standards and European Regulations 3
M Unapproved System Display at a Mexican Trade Show Other Medical Device Regulations World-Wide 2
L CE Auditor Using ISO audit reports to show compliance to the MDD?? EU Medical Device Regulations 4
P Is it necessary to show Model Number on the Labeling (meter box, label and manual)? Other US Medical Device Regulations 3
Hershal Reality TV show contest Coffee Break and Water Cooler Discussions 1
AnaMariaVR2 Design of Experiments in a Cooking Show Coffee Break and Water Cooler Discussions 0
T How to Show "Date/time" Data Graphically in Minitab Please? Using Minitab Software 2
S Suggested process to show compliance for this 820.120(a) for Label Integrity 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
R How do we show our Software Develoment Life Cycle is similar to IEC 62304 Other US Medical Device Regulations 3
L Old and New Primary Standards show a difference between them General Measurement Device and Calibration Topics 9
Marc Questions about the Internet circa 1994 on NBC's "The Today Show" After Work and Weekend Discussion Topics 1
V Can we show Photocopied Uncontrolled Copies of Documents to an FDA Auditor? US Food and Drug Administration (FDA) 15
H Can anyone show me a sample of a Cleaning Program for Food Manufacturing? Food Safety - ISO 22000, HACCP (21 CFR 120) 5
Ajit Basrur How to show percentage in an Excel graph? Excel .xls Spreadsheet Templates and Tools 13
P Rework Notification - Is it sufficient to show how we control rework process Manufacturing and Related Processes 1
Anerol C How I can show evidence that quality related activities are impacting the financials ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
L BSI Logo - Requirements when using the BSI logo to show certification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
G Japan's PMDA Response to Question on Trade Show Display of Non-approved Device Japan Medical Device Regulations 9
P Must show Sub-Supplier details? Supplying a Tier 2 company IATF 16949 - Automotive Quality Systems Standard 7
JoCam How do I show the benefits of a QMS to the Design Team? ISO 13485:2016 - Medical Device Quality Management Systems 23
I In ISO 9001:2008 - Can we show an Internal Department as our Client/Customer ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
Marc Land a Million Show - Aviation Funny Stuff - Jokes and Humour 0
B Can somebody help me to show a 'delta-FMEA' example? FMEA and Control Plans 10
S How to show Approval for Documents and Training? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
V Competency - How I can show experienced operators are competent? Document Control Systems, Procedures, Forms and Templates 3
S How to show that policies are properly communicated & Training Effectiveness ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Stijloor GM to take back 5 Delphi plants, contract details show World News 0
T Prison Break Fans ?? - TV Show Coffee Break and Water Cooler Discussions 10
