How to start implementing a QMS according to ISO 17025
L
lodapl
Hello everyone!
I am working in a metrology lab and I have been assigned the implementation of a QMS according to ISO 17025. Personally, I would like to obtain accreditation by the end of 2013 or first half of 2014, even though there is no time limit.
Before I was assigned this task, I had been doing calibration services so I have a pretty good idea of uncertainty and other technical aspects. Though one can always learn more and new things.
I've been wondering where to start. I researched for a lot of information on how to implement a QMS, and this is what I came up with:
  • Identify main processes.
  • Identify main roles and responsibilities.
  • Write a procedure for creation of documents in the QMS.
  • Elaborate documentation, always in coordination with each section in the company, following those already indentified processes.
  • Supervise that everything is going according to what is documented.
After this, start with the Quality Manual, Policies, Roles and Responsibilities Manual and everything needed to comply with ISO 17025.
I think this is an idea that can be improved.
What dou you think? I would like to know a few suggestions on how to start implementing an ISO 17025 QMS.
Thank you!
Paul
Jen Kirley
Quality and Auditing Expert
Welcome to the Cove, Paul!
I think your plan so far is sound. You do not seem at all lost in the subject. If you get the feeling you want examples of tools for use with 17025, I suggest checking in our Post Attachments List - see the green button in the header. I did a search using key word "17025" and came up with this list of attachments, each located within a discussion on the subject.
Also see links to related threads at the bottom of this page, and others that you view.
As for the time frame, expect the accrediting body to want to see at least one full round of scheduled internal audits completed, evidence of corrective actions, and a management review before your accreditation audit can take place.
I hope this helps! You are among friends here.
qusys
Hello everyone!
Thank you!
Paul
if your organization is already certified vs ISO 9001 , I think that the accredidation to ISO 17025 will improve your processes. You are ok with the plan, I would only suggest the involvement and the sponsorship of the management given that the standards requires ad hoc mgmt review for the ISO 17025.
For this reanson,if you are already ISO 9001, you have an advantage.
L
lodapl
I think your plan so far is sound. You do not seem at all lost in the subject. If you get the feeling you want examples of tools for use with 17025, I suggest checking in our Post Attachments List - see the green button in the header. I did a search using key word "17025" and came up with (link not allowed), each located within a discussion on the subject.
Hi Jennifer and thank you for your reply.
Didn't know about that button. Quite useful!
I'll look for more information in those attachments.
Regarding the time frame, approximately, how much time do all that you mentioned takes?
Hi qusys, thank you for your reply.
Actually, we aren't certified in ISO 9001, our first certification would be ISO 17025 and we're working towards it. Though, I think it has similar requirements of a QMS as the ISO 9001.
Management is really into this new phase. I think the only inconvenience would be the budgeting :tg:
Thanks!
Paul
Hershal
Metrologist-Auditor
First, get a copy of the Standard and read it. Read it first assuming nothing, just to get used to it.
Next, get training in the Standard. Training may be available from your accrediting body (AB). If you are in a country other than US, go to www.ilac.org and find the recognized AB that is closest to you. They may have training. If you are in US, then there are at least 6 ABs that can provide information and possibly training.
Next, your plan seems reasonable. Remember the KISS rule - Keep It Short and Simple. You MUST address every Clause of the Standard. However, as a calibration lab, some things may not apply. You address them by stating they do not apply and providing the reason.
Some things need to be addressed in the apex manual, but detail can be more easily provided in a lower level manual. Uncertainty is a good example there.
Contact the AB that according to the ILAC website is closest to you, remembering that if you choose to use a different AB, you may need to provide the reason why. That is acceptable, as it is the lab's choice on which ILAC Signatory to use. If you are in US, get quotes from ALL the US ABs before deciding which you will seek accreditation from. Also seek to talk to the Program Manager (by whatever name) for calibration.
Do an internal audit before the AB comes. Do a management review, and if the management review is hosted by a parent organization, then make sure the cal lab is SPECIFICALLY discussed and the minutes reflect that.
Make sure you have your best uncertainty estimated, and realize after the technical demonstrations you may need to demonstrate uncertainty for the assessor. If there are pfoficiency tests or inter-laboratory comparisons (PT/ILC) available, participate or at the very least be enrolled in them, before the AB comes for assessment.
Hope this helps.
Hello everyone!
Thank you!
Paul
L
lodapl
Thank you very much, Hershal.
This will help quite a lot!
Regarding the training, I will be taking a course on interpretation of requirements of ISO 17025 which is around March or May i think.
There is only one National AB here and we will be addressing them for certification.
Again, thank you for your reply.
Paul
Next, get training in the Standard. Training may be available from your accrediting body (AB). If you are in a country other than US, go to (no url allowed) and find the recognized AB that is closest to you. They may have training. If you are in US, then there are at least 6 ABs that can provide information and possibly training.
Hope this helps.
E Theoretical project: Implementing ISO 13485:2016 into a start up acrylic bone cement manufacturer ISO 13485:2016 - Medical Device Quality Management Systems 4
A Implementing ISO 20000-1 - Where to start Other ISO and International Standards and European Regulations 4
T Plant Start-Up - Planning and Implementing Quality Systems for a New Facility Manufacturing and Related Processes 3
C Suggestion for Implementing ISO 9001 in a Start-Up Company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
M Where to Start when Implementing ISO Standards in Rotational Molding ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S Implementing ISO 9001:2008 - Where to Start? Document Control Systems, Procedures, Forms and Templates 15
H How to Start Building New Management System for OHSAS 18001 and to Start Implementing Occupational Health & Safety Management Standards 10
R New to ISO9001 - Implementing ISO 9001 at company - Resources and where to start ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
D Implementing ISO 17025 - Where Do I Start? ISO 17025 related Discussions 11
Q How do I start implementing TS 16949? IATF 16949 - Automotive Quality Systems Standard 4
A Implementing ISO 9001:2000 - Service Company - Where do I start? Service Industry Specific Topics 9
bryan willemot Wanted: in need of start up Lock out Tag out program in Excel or Word, your help is much appreciated Occupational Health & Safety Management Standards 3
A Which certificate should I start with from ASQ, CQIA or CQE? (or should I take something else) Professional Certifications and Degrees 4
N Writing Risk Management procedure for small manufacturing and we don't know where to start. Manufacturing and Related Processes 9
H Can I just forget physical run charts and start digital? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
I ISO 9000 Where to Start ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 93
C Regulatory Affairs in a start-up medical device company Career and Occupation Discussions 2
M Seeking Consultant for Orthopedic Start Up company Other Medical Device and Orthopedic Related Topics 1
J Incoming Stock QC, where to start? Manufacturing and Related Processes 6
J Stock Traceability Methods, where to start? Manufacturing and Related Processes 0
S Where to start for MDSAP for Canada? Canada Medical Device Regulations 5
U Examples of Quality Objectives for a Medtech start up ISO 13485:2016 - Medical Device Quality Management Systems 4
J ISO 13485 System 'soft start' - How to best reflect this in initial audits, management review minutes and other records? ISO 13485:2016 - Medical Device Quality Management Systems 3
A AS9100 Training - Where do I start? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
mike10 QMS Update - Rev. up or start over? Document Control Systems, Procedures, Forms and Templates 5
N China - Start manufacturing before change approval? China Medical Device Regulations 3
S How to start with ISO process in project based team - Documentation Document Control Systems, Procedures, Forms and Templates 4
T CE mark start date for a device EU Medical Device Regulations 7
qualprod Statistics - Where to start in ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
W My company is looking to start a materials testing lab that conforms to ISO17025:2017 ISO 17025 related Discussions 3
G Start and main steps of API Q1 Certification Process Various Other Specifications, Standards, and related Requirements 5
M Error trying to Start a New Thread Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 2
H Transferring an ISO 13485 certificate to a new CB - Do I have to start from scratch? ISO 13485:2016 - Medical Device Quality Management Systems 2
M Start-Up Company looking for ISO 13485 Certification Body and Medical Device CE Mark Notified Body Registrars and Notified Bodies 6
Marc Basic - How to Start a New Discussion Thread Elsmar Xenforo Forum Software Instructions and Help 1
TheMightyWife Can not start Personal Conversations Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 18
E Is it possible to start an ISO 9001 QMS from scratch (Really) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
M AS9100 - Where to start - Small company (10 employees) and I am the Quality Dept. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 45
M How do you start a calibration/anything company? Career and Occupation Discussions 11
E ISO 9001 certification of the new plant before start of production ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
B Gap analysis of new start-up company technical documentation CE Marking (Conformité Européene) / CB Scheme 1
qualprod How to start with Lean? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
R QMS and ISO - Where to start? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
S ISO 17025 - Help in Getting accreditation- Where to start from ISO 17025 related Discussions 12
H Need to Start an R&D Laboratory, what to do? Design and Development of Products and Processes 6
O Start Up Approval Dimension Records IATF 16949 - Automotive Quality Systems Standard 5
V Product Development - When to start calculating Process Capability Capability, Accuracy and Stability - Processes, Machines, etc. 3
Moncia Design FMEA - Where to Start FMEA and Control Plans 20
M Where does Document Revision Control Start? Rev 0 or Rev 1 Document Control Systems, Procedures, Forms and Templates 21
