How to state that Calibration Services & Equipment are Traceable to NIST
Curtis317
If you were going to start a calibration service how would you be able to state that your services or equipment calibrations is traceable to NIST? Just have your equipment calibrated by another service that is traceable or do you have to go through the NIST?
Hershal
Metrologist-Auditor
Re: How to state that Calibration Services & Equipment are Traceable to NIST?
The way you would present the information on your certificate to a customer is to provide sufficient information to link the calibration of their equipment back to your standard. There should be information on your standard such as its last calibration or next due date, or the traceability number. The traceability number is typically the certificate number from the lab that calibrated your standard.
Generally you do not need to go through NIST, but for some items you may need to, or may need to use a NIST Affiliate, that is, another national lab that for a specific measurement is considered to be NIST.
Beware of the so-called NIST Number. For that to be valid, you will need the specific NIST report that details the calibration of your standard at a specific time.
Hope this helps.
N
natecsss
The company we work with certifies that their instruments are calibrated and returned in a state the meets or exceeds the original published specifications. Calibration was performed with standards that are traceable to the NIST.
dwperron
You might want to check with your calibration lab to see how they support that they are "NIST Traceable". If you go through an audit you will have to prove that you are NIST traceable, and if your cal lab can't prove that they are traceable then you are in trouble.
If the lab you use is ISO 17025 accredited then the traceability search is part of the accreditation, and you can assume that they are NIST traceable
BradM
Here are a couple of links that might help:
http://www.nist.gov/traceability/
http://www.nist.gov/pml/mercury_traceability.cfm
Basically focus on the "unbroken chain". Also keep in mind, that chain may have two links or twelve. :) The more links you have, the more error (uncertainty) you are adding at each step. So if you are going to set up a calibration service, it will depend on what you will be performing and what kind of standards you purchase. You may (just may) find that sending some standards directly to N.I.S.T. is your best option. Other things may go to a shop (like Fluke) that sends their equipment directly to N.I.S.T.
dgriffith
Traceability through the NIST is desirable, and sending directly to them gives you the highest echelon of the realized SI units, but danged if they aren't slow as molasses and quite expensive.
My Fluke 742-100 resistor standard came back from calibration at Fluke--and their resistance traceability for their standard used was through the NRC (Canada).
As long as the other NMI is a member of a mutual recognition arrangement (MRA) which includes the NIST, it's acceptable.
Gman2 The current state of our Calibration System General Measurement Device and Calibration Topics 28
F Starting a Calibration Laboratory in State College, PA Career and Occupation Discussions 4
K Do I need a "State of the art" plan? CE Marking (Conformité Européene) / CB Scheme 1
M Can a PLD Registered in only one state sell prescription drugs to one in another state Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
M Referenced Standards and/or "State of the Art"? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
M Informational EU – October 2019 update – State-of-play of joint assessments of Notified Bodies in the medical device sector Medical Device and FDA Regulations and Standards News 2
William55401 How Often Does FDA State Consultant Recommended in a Pharma WL? US Food and Drug Administration (FDA) 1
A EU MDR Annex I section 11.3 - Medical Devices labelled as having a specific microbial state EU Medical Device Regulations 7
T Legalizing ISO 13485 certification with an US state department of health ISO 13485:2016 - Medical Device Quality Management Systems 5
T Customer audit demands - that I state in my QM who can shut down production AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
M Informational EU – State-of-play of joint assessments of Notified Bodies in the medical device sector – June 2019 Medical Device and FDA Regulations and Standards News 0
M Does ISO 13485 or MDR require you to state the origins of customer requirements or user needs? Design and Development of Products and Processes 2
M Informational EU – Update on state-of-play of joint assessments of Notified Bodies in the medical device sector Medical Device and FDA Regulations and Standards News 1
M Medical Device News State-of-play of joint assessments of Notified Bodies in the medical device sector EU Medical Device Regulations 0
D Drawing (print) does not specify restrained or free state Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
N ISO 14644-1 Clean Room Occupancy State Validation Requirements Manufacturing and Related Processes 3
M Keeping up with "State-of-the-Art" & updated Standards EU Medical Device Regulations 11
R Measuring LiON Battery State of charge - Transporting batteries by Air RoHS, REACH, ELV, IMDS and Restricted Substances 1
D Verification that Manufacturing Equipment has maintained a Validated State Design and Development of Products and Processes 11
Randy New Texas State Trooper Coffee Break and Water Cooler Discussions 6
K Average height of adults by sex by state Other Medical Device and Orthopedic Related Topics 10
A ISO 17025 sections state "Shall have a Policy and Procedure" ISO 17025 related Discussions 2
K Medical Application Classification in Controlled/Uncontrolled by Mobile App State. 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
Ajit Basrur Telangana will be India?s 29th State Coffee Break and Water Cooler Discussions 3
V The ASQ Global State of Quality Book, Video, Blog and Web Site Reviews and Recommendations 2
S SFDA (China's state Food and Drug Administration) changed to CFDA China Medical Device Regulations 6
D State Past Due on its own Meter Inspection ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
V Quality/Manufacturing/Six Sigma Jobs - Tri State (NJ,NY,CT) Career and Occupation Discussions 1
Sam Lazzara February 2013 Medical Device "State-of-the-Art" updates Other Medical Device Related Standards 6
A Can Internal Audit Observations be kept confidential from State FDA inspections ? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
L MD State License Requirements for Medical Device Distribution Other US Medical Device Regulations 2
B Safe Disposal of No Clean Soldering Flux in NY State Manufacturing and Related Processes 6
S Labeling & Packaging Procedure required by the state of California ISO 13485:2016 - Medical Device Quality Management Systems 4
optomist1 GD&T - Use of Restrained State/Non-rigid Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
E Every US state has Medical Device Regulations beside FDA Regulations Other US Medical Device Regulations 11
Mikey324 How to Check for Legal (OSHA Federal & State) Updates Occupational Health & Safety Management Standards 5
Stijloor Consultant/Auditor needed in New York State Food Safety - ISO 22000, HACCP (21 CFR 120) 1
B CI (Continuous Improvement) Tools and Techniques - What is the state of the art? Lean in Manufacturing and Service Industries 4
K Microbiological State of a Reagent Kit - Enquiry Regarding ISO 18113 Other Medical Device Related Standards 1
somashekar Medical Device Manufacturing License from FDA and State of Location Required? Other US Medical Device Regulations 10
J0anne Prescription Only vs. Over The Counter Pharmaceuticals because of State Laws 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
R Class III Medical Device in Netherlands - Member State Country Notifications? ISO 13485:2016 - Medical Device Quality Management Systems 4
G Arizona State University BB Certification course: Seeking opinion on value for cost Professional Certifications and Degrees 8
O Mystery of China SFDA (State Food and Drug Administration) and CCC ISO 13485:2016 - Medical Device Quality Management Systems 26
P ETO Sterilisation of Single Use Part supplied in Non-Sterile State EU Medical Device Regulations 12
Marc Federal and State Taxes for 2009 due 15 April 2010 (US obviously) Coffee Break and Water Cooler Discussions 16
D Requirement of "State Of The Art" in MDD (Medical Device Directive) EU Medical Device Regulations 42
I Where does it state Supplier Corrective Action is required? Supplier Quality Assurance and other Supplier Issues 5
T Polite way to state Continuous Improvement is not a form? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
mr500 Interpreting Decimals in the mm state - Off Wall Question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14
