How to Statistically Prove 2 Dimensions are Related
susanyap123
Hi, I had a set of data as attached which shows that a machining process from 'Dimension-A' will affect 'Dimension-B'. I need to prove to my customer in statistical. Is there any way of proving it using Minitab? If yes, which tools should I use? Thanks
  • Book1.xlsx
Start by plotting the data using a scatter plot. Doing so, you will see that there does appear to be a relationship, but there also appears to be an outlier (sample 18). Verify that these measurements are correct to determine how to handle this outlier.
Next, you can do a simple correlation followed by a regression analysis if you want to proceed that far. Note that the relationship only explains approximately a third of the variation. The remaining variation may be due to measurement variation, process variation, or other factors.
Ian r squared value .294 is very low. dimension A is NOT the primary driver of Dimension B. If you look at the scatter diagram you can clearly see this. I know you want to 'prove' that A causes B, but it doesn't...
perhaps if we understood the process and what the dimensions were we could provide more insight. it is possible that A does cause B and your study design is flawed.
Part of this issue is "probably" because the data were collected from the process, which was presumably stable. There is too little spread to clearly see the relationship. If a larger spread were used the R^2 would probably increase.
Good point about R^2. As Ellis Ott said: "Plot the data!"
I disagree about the comment on proving a relationship. What you stated is correct for observational data. However, experimental data that has been replicated can essentially prove a relationship. For example, I only have to flip the light switch on and off a few times to essentially prove that it causes the light to turn on and off.
Statistical Steven
Statistician
You are correct that every time you turn on the switch the light does on proves there is a cause and effect relationship. But when you have observational data (as is the case with regression) with MSE, you cannot prove a cause and effect relationship.
susanyap123
Hi, I do agreed that using scatter plot we are only able to see both DIM A & DIM B do have a relationship but may not be cause. My company BB also considered operators may be 1 of the KPIV. Thus, he used some hypothesis testing. But I not sure is this method correct? should 2-sample t test be better?
the samples are collected from 2 operators (20 samples each).
  • Book3.xlsx
First - lets be clear. if there is any relationship between the performance of A and B it is tenuous at best. LOOK at the scatter diagram the 'best fit' line is almost flat. the r squared value is also clear on this. B may be built on A but the variation in B is not controlled by A. At least in the way you have measured things.
IF we had a better idea of the physical relationship between A and B and the process by which B is created we might be able to suggest a more definitive analysis. Parallelism of A related to 4 individual dimensions of B could be a very poor way of assessing the relationship.
Secondly the 'hypothesis' test of the operators is clear from a LOOK at the data (again given the obvious limitations of trying to correlate parallelism of A to 4 values of B) even with box plots that there is NO relationship (either statistical or physical) between the operators and the results in A or B. No amount of statistical test hunting will overcome this...
All of this doesn't mean that A isn't causing B. ALL statistical analysis must match the physical reality of the system. Statistics doesn't obviate physics.
If you really want to understand the relationship between A and B we need to understand what A and B are and how they are created...without it you are just yanking on the statistical slot machine arm...
F Sample Size to get Statistically Valid Data Measurement Uncertainty (MU) 6
Soog1459 Statistically valid number of biopsy devices should be tested US Food and Drug Administration (FDA) 4
D Best Minitab Tool to determine a Statistically Significant Trend Using Minitab Software 5
P Sterile Packaging Validation - FDA Requirements for Statistically Valid Tests 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
K Statistically Valid Audit Sample for Management System Audits? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
F How to statistically determine the maximum performance life of a chemical Statistical Analysis Tools, Techniques and SPC 4
S Statistically valid method for multiple raw material sampling Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
H How to Select a Statistically Valid Sampling Plan Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
H Process that is Not Stable vs. Not Statistically Capable - Differences Capability, Accuracy and Stability - Processes, Machines, etc. 9
J Demonstrate Receiving Inspection Sampling Method is Statistically Adequate Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
N Statistically Comparing Technician Techniques Reliability Analysis - Predictions, Testing and Standards 16
B Statistically Sound Data Sampling Technique for Internal Audits Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14
S Getting started with statistically based process improvement The Reading Room 12
M Statistically Toleranced Drawing Feature Dimensions - Target Value and Range Statistical Analysis Tools, Techniques and SPC 5
L How to Monitor Corrective Actions - Statistically Monitoring Corrective Action Nonconformance and Corrective Action 34
G Pp and Ppk indices - Is it statistically possible to have a Ppk greater than Pp? Capability, Accuracy and Stability - Processes, Machines, etc. 16
M Auditing Statistically - A statistical approach to sample sizes General Auditing Discussions 11
J Statistically Determining how many Tests to conduct. Statistical Analysis Tools, Techniques and SPC 3
J Statistically Valid Sample Sizes For SPC Statistical Analysis Tools, Techniques and SPC 1
qualprod How to prove improvements? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
Q Do we have to prove a link between the mill and our raw material supplier? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
P How to Scientifically Prove the Importance of a Process - CMMI Process Areas Software Quality Assurance 7
B How to prove that an organization implements anti bribery policy IATF 16949 - Automotive Quality Systems Standard 8
C UDI Label Verification - How do we ensure the barcode is correct and prove it? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 18
U Sample size to prove parts are good with 99.73% confidence Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
L What needs to be done to prove compliance with RoHS and WEEE EU Medical Device Regulations 5
A Is MSA useful to prove a Measurement System after Relocation? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
P How to prove that Cr oxide makes a stent biocompatible (e-polished 316LVM) Manufacturing and Related Processes 9
P Testing a US device in Europe to prove Equivalence in a ?head-to-head? Study EU Medical Device Regulations 6
J Reliability Prove-out, Pass-Fail Testing Reliability Analysis - Predictions, Testing and Standards 2
K What would you give up to prove conformity and honesty? Internal Auditing 21
S ISO 17025 requirements not enough to prove NIST Traceability? ISO 17025 related Discussions 10
I Prove or disprove that a cube can be cut in 27 smaller cubes in less than 6 cuts Brain Teasers and Puzzles 14
M How do I prove I don't receive a controlled product? Ractopamine Hydrochloride Misc. Quality Assurance and Business Systems Related Topics 4
C Clinical Data to Prove Equivalence Other US Medical Device Regulations 4
U Can anyone prove that: 2x2=5 ? Coffee Break and Water Cooler Discussions 63
D Testing an Inspector to Prove Competency in Visual Inspection Records and Data - Quality, Legal and Other Evidence 2
S Lean System Developer - How should I work to prove myself? Lean in Manufacturing and Service Industries 19
D How to Prove and Explain to Consultant (Internal Auditor) and Manager? Internal Auditing 7
M Planning requirement 5.4: How should the management prove compliance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J How to prove that we conform to legal requirements Miscellaneous Environmental Standards and EMS Related Discussions 11
L Is there any way to prove a process is in control other than with a control chart? Statistical Analysis Tools, Techniques and SPC 6
H How do we prove that we are improving the continual improvement process? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
L How do you prove you need resources? Misc. Quality Assurance and Business Systems Related Topics 5
J Finished Goods Testing - Using historical test data to prove finished goods OK Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
A Contract Review - How do you prove it? Contract Review Process 16
K Statistical Hypothesis Testing to prove signficant quality improvement or decline Statistical Analysis Tools, Techniques and SPC 6
H Looking to make inspection faster for part with over 100 dimensions. Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
V Over 60 dimensions CMM measurement in control plan APQP and PPAP 8
J Best Practices for Choosing In-process Inspection Dimensions & SPC Dimensions Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
