How to Submit an Expansion of Claims 510(k)?
cookie36
I am thinking of writing a 510(k) that is purely an expansion of claims. This will not affect our indications for use, as our indications is general enough. My question are:
1) is there any format/guidelines on how to do this? Or, does it follow the typical 510(k) format?.
2) If it follows the typical 510(k) format, is it sufficient to submit simply a literature review (extensive) on the claims for evidence (ie. for lab/bench performance testing results)? Or, will an inhouse clinical study be required? (see background below)
3) Could this be submitted as a special 510(k) as I will not change the wording of the indications itself?
Please help! Thanks!
Some background:
The device I work on is a large imaging medical device. Our current indications for use cover - "..disease states including, but not limited to applications in cardiology, neurology and oncology..". Granted, we mention "..not limited to" to keep our indications general - but we would like to be able to talk about applications in other areas such as: orthopedics, infection, and maybe also mention specific diseases in cardiology, neurology and oncology.
Is a literature review sufficient if additional diseases "claimed" is a widely adopted, well known application of our device?
cookie36
Re: How to Submit a Claims 510(k)?
I guess my question is that, Has anybody done an "expansion of claims" 510(k) when you do NOT change the indications for use and/or using evidence that is purely literature review.
I have seen 510(k) summaries that are purely claims 510(k) but typically the "verification/validation" evidence actually consists of an in-house study. I am wondering if anybody has done it when there is NO in-house study.
The guideance documents arent very clear.
G
Gizmo Guru
Hi, I'm confused by your statement that your firm wishes to "expand the claims" of your currently marketed device , but this will not require a change to your Indications for Use (IFU).
Your IFU states your claims. If you are making no changes to this, the materials, or the design of your device then you do not need to re-submit your 510(k). The only exception to this would be a change of labeling or a change in manufacturing/processing where you are using the identical Performance Criteria as those currently cleared. The latter would be appropriate for a Special 510(k).
Michael Malis
I am thinking of writing a 510(k) that is purely an expansion of claims. This will not affect our indications for use, as our indications is general enough...
it is a large imaging medical device.
Hello Cookie36,
Literature review will not be sufficient for wider claims!
You need to think about this from the FDA point of view - What proof do you have and plan to present to support these wider claims for your device?
Do you have any practical information of new applications that you plan to share?
Without this information you can have a number of issues with your 510k...
Regards,
Mike
Peter Selvey
A 510(k) is formally based on "substantial equivalence", so technically the primary target is to prove that the intended purpose of your device is equivalent to an existing (predicate) device.
The regulation does allow for some variation, provided that those differences have no significant impact on safety. So, you could use your own device as the predicate device. To quote directly from 21CFR807.92:
If the indication statements are different from those of the legally marketed device identified in paragraph (a)(3) of this section, the 510(k) summary shall contain an explanation as to why the differences are not critical to the intended therapeutic, diagnostic, prosthetic, or surgical use of the device, and why the differences do not affect the safety and effectiveness of the device when used as labeled
This is different to the European approach, where substantial equivalence is important factor but the final target is to prove if the device is safe and effective, with a firm basis on real clinical data.
I think some of the responses above may be using the European thinking. It is worth to note that the European approach where clinical evidence is almost always required is not universally accepted, and there are arguments both for and against.
Bruce Banner
You can and need to file a 510K to expand your claims. It will not be a special because the device is not changing. It will need to be a traditional.
Dramirez
Hi:
If your intention is to introduce new claims (referring to specific diseases areas of use) that will definitively impact your IFU. At the eyes of FDA, referring to specific diseases requires much more than literature review. You need to show that your device is actually safe and effective for the diagnosis/treatment of the "new" diseases.
supadrai Possible to Submit a 510(k) if you have never, do not and cannot produce the device for which you're submitting the application? US Food and Drug Administration (FDA) 4
F How to submit a PPAP when a subcontractor is the sole manufacturer IATF 16949 - Automotive Quality Systems Standard 2
gunnyshore Adding a new facility - do I need to submit an amendment to the MDL or MDEL, or both? Canada Medical Device Regulations 3
D Does Manufacture can submit CE mark application under MDD with NB for his New product after May 2020? EU Medical Device Regulations 3
F How to submit PPAP without IMDS APQP and PPAP 10
M Informational TGA presentation: How to submit an effective good manufacturing practice clearance application Medical Device and FDA Regulations and Standards News 0
Watchcat EU Certification - What do you submit to an NB EU Medical Device Regulations 5
B Submit a 510(k) with a Predicate cleared but not Listed US Food and Drug Administration (FDA) 9
L Reasons to submit a new PPAP or notify the customer APQP and PPAP 3
L 510k exemption process - Do you still need to submit technical dossier? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
N How to deal with catalog parts suppliers who refuse to submit PPAP documents? APQP and PPAP 0
I Where to submit Adverse Events Reports in Europe EU Medical Device Regulations 7
B Should I Request/Submit a PPAP from/to a Supplier/Customer for only Repackaging Parts APQP and PPAP 7
Ronen E FDA releases new draft guidance on when to submit a 510(k) for device modification Other US Medical Device Regulations 10
B Submit a Special 510(k) or "Documentation by our own" 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
L 20 days to submit PPAP APQP and PPAP 9
J Can we submit data with Special 510(k)? US Food and Drug Administration (FDA) 8
A Using Regulations.gov to Submit Comments on FDA Guidance Documents Other US Medical Device Regulations 5
E When to submit a Technical File for a Class IIb Medical Device EU Medical Device Regulations 3
P Do we need to submit Special 510K for a Blood Glucose System? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
D Customer will not submit Purchase Orders - System for ISO 9001 Compliance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
L Can we submit an AS9102 if we are not AS9100 certified? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
S Guidance to prepare and submit a Level 3 PPAP to a Customer APQP and PPAP 6
I Where do we submit the FAA Preapplication forms? Federal Aviation Administration (FAA) Standards and Requirements 1
O Medical Device Registration in EU - Which Ministry to submit Technical File? EU Medical Device Regulations 9
S How to Submit ISO/TS 16949 & ISO14001 Certificates to HMMA IATF 16949 - Automotive Quality Systems Standard 4
W Submit MDR for a device cleared by FDA but not sold in US? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
P Part Submission Form - Need to submit PSW only once? APQP and PPAP 5
M If I update a DFMEA do I need to submit to my Customer? FMEA and Control Plans 7
C When to submit a 510(k)? After the DMR (Device Master Record) is finished? Other US Medical Device Regulations 4
A Should I submit the entire copy of my software in a 510(k) submission?? US Food and Drug Administration (FDA) 7
Howard Atkins Is there a time frame for CBs to submit the TS 16949 Audit Report? Registrars and Notified Bodies 2
J What is the time limit for an auditor to respond to NCR's and submit audit report? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
shimonv Deciding When to Submit a 510(k) for a Change to an Existing Device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 17
sagai New Draft Guidance - When to Submit a 510(k) for a Change to an Existing Device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
B Deciding when to submit a Special 510(k) US Food and Drug Administration (FDA) 10
S How to locate a Sponsor in Australia to submit Product Approval Applications by TGA Other Medical Device Regulations World-Wide 4
R In 510k application do we submit documents showing compliance with 21CFRPart820 Other US Medical Device Regulations 12
P Does our company need to be certified in order to submit a 510k Other US Medical Device Regulations 4
A Before the ISO-9001 certification audit can we submit the documents to our customer ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
N Can I submit 510(k) without Biocompatibility Test Results? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
C When to Submit a 510(k) in the Product Life Cycle 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
W Is Foreign Exporter required to submit a 510(k)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
C Do we have to submit a new 510(k) for a device with a new MCU? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 12
E Do I need submit a traditional 510(k) or Abbreviated 510(k) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 10
N Supplier PPAP - How many parts should they submit? APQP and PPAP 6
C When to submit a 510(k) for a change to an exisiting medical device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 29
A What is PPAP (Production Part Approval Process) Why submit it and/with PSW APQP and PPAP 2
P Can I submit a 510(k) without aging data? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
C Only appearance and PCB are changed - Do we need to submit a new 510(k)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
