How to test 8.7.4.7 d) ? What "not protectively earthed accessible part" means?
eldercosta
First off, my device's Applied Part type is BF.
The question about the meaning of "not protectively earthed accessible part" is in the context of this clause, i.e. 8.7.4.7 d) .
My impression is this clause applies to accessible parts that may be in contact with the patient (per the rationale). However, I am not 100% sure about that, the text of the clause and rationale, to me, is in a gray area.
My device does have has a metallic cover that is fixed with screws to the back of the device (the cover is to protect connectors so its area is around 20% of the back. Both, cover and back are metallic and painted (powder coating). The cover is not protectively earthed, unlike the back part, which meets the protectively earthed requirements. Despite not being protectively earthed, the cover may be earthed by the screws. Depending on how the clause is interpreted, the test laboratory may apply V2 of Figure 18 to the cover that may be incidentally earthed. Or I am misinterpreting the clause and figure?
Thank you in advance for your comments.
Benjamin Weber
Clause 8.7.4.7 d) is about measuring the patient leakge current, when an external voltage is present at a metal accessible part that is not protectively earthed (this is NOT the applied part).
If you have accessible parts which are not applied parts per definition but could be subject to the same requirements per cl. 4.6, this applies also to those accessblie parts.
If your metal cover is not intentionally protectively earthed I assume the tester would either
  1. apply the external voltage (max. mains) to the metal cover during the test per fig. 18
    OR
  2. consider the cover as PE connected and then test the PE impedance (with removing the powder coating at the test location) and not apply the external voltage durign the test per fig. 18.
In the first case the tester would very likely have a problem with his test equipment, due a (more or less) short circuit of the test voltage V2 and earth via the metal cover. Actually I think he would have seen this coming and ask you wether this part should be PE connected or not.
If you are lucky, the PE impedance measured at the metal cover is OK. But in this case you should really consider this part as intentionally PE connected. You can do this by taking care of a good conductive connection via the metal screws or by an additional dedicated PE connection (a cable).
If you don't want to have the metal cover to be PE connected, then you have to seperate is clearly from PE, e.g. by using plastic screws.
Peter Selvey
This is interesting ... if you look in IEC 60601-1 ed 2, Clause 19.2 this test is generally not applicable. It is excluded from F-type parts, and also excludes Type B parts "unless inspection of the circuits and physical arrangements shows that a SAFETY HAZARD exists".
In practice this was rarely applied, as Benjamin indicated it's a potentially destructive test.
In Ed 3, if you read 8.7.4.7 d) it looks applicable to both B and BF. However, 8.5.2.2 indicates an exception for contiguous metal and also risk based option.
It looks like mistake in that that there is no tie between 8.7.4.7d and 8.5.2.2. For example the last sentence should read:
This test need not be conducted:
- if it can be demonstrated that there is adequate separation of the parts involved, or
- if the the exceptions in 8.5.2.2 apply.
eldercosta
Benjamin, Peter, first off, thank you for your comments.
@Benjamin
About the cover, getting it protectively earthed would require modifying a PC (medical/industrial - the cover just protects the connectors on the back of the PC), which I would rather not if I can.
@Peter
The cover is not close to the patient, quite the opposite. Per 8.5.2.2, there is a MOPP between this cover and the AP (actually there are two, as creepage/air clearance and insulation components meet the 2xMOPP for 240V mains). So my design meets the first part of the subclause.
After I posted, I noticed the third paragraph (This test need not be conducted if it can be demonstrated that there is adequate separation of the parts involved.); it seems to me that, based on this statement, this test does not need to be applied in my case.
About the last paragraph of your post, the amendment 2 of IEC 60601-1 3.0 says "Replace, in the existing third paragraph of list item d), "parts involved." with "parts involved or if the RISK is acceptably low according to 8.5.2.2."
W Conducting an MSA Test on scales Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
T Lot Release Test and Certificate of Analysis 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
John Broomfield Construction Inspection and Test Plan Misc. Quality Assurance and Business Systems Related Topics 5
Z COVID-19 Antigen Test Kit (Self-test) Registration in Peru Other Medical Device Regulations World-Wide 0
R GearBox Test Bench Calibration General Measurement Device and Calibration Topics 2
N 60601-2-34 Electrosurgery interference Test IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
M Gage R&R automated test equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
F Self-test minimum requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
H Regarding the validity of EMC & Safety test reports without NABL & ILAC-MRA mark. CE Marking (Conformité Européene) / CB Scheme 2
Z Implement methods of Round Robin test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
D 62304 code review, unit test, integration test example IEC 62304 - Medical Device Software Life Cycle Processes 2
D DOD First Article Test Plan & Report Manufacturing and Related Processes 4
Stoic Details of Operational Qualification (OQ) test design for plastic extrusion processes, effect of material property noise, and GHTF/SG3/N99-10 US Medical Device Regulations 2
A Earth (ground) leakage current routine test IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
G Audit & Agreements for "Test Laboratory" Supplier? US Medical Device Regulations 4
G Developing our custom test methods and test equipment US Medical Device Regulations 5
K Looking for a tape to perform cross hatch test on powder coating parts Reliability Analysis - Predictions, Testing and Standards 3
G Change Control for Test Samples Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
MaHoDie Summative Usability test Human Factors and Ergonomics in Engineering 2
A Calibration of spring loaded test fixture General Measurement Device and Calibration Topics 5
E Pressure vessels hydraulic test IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
C Spinal implant predicate device test results 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
S Statistical Test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
Ed Panek Looking for Test Resource General Measurement Device and Calibration Topics 1
R Microbiological test (USP61, USP62, USP71, ISO 11137.1, ISO11137.2) --- Testing flow chart Other Medical Device Related Standards 0
S Discussion on OBL and OEM test data for submission as per new EUMDR EU Medical Device Regulations 0
E Do I need test reports for all standards mentioned in my 510k application? Other Medical Device Related Standards 8
C DV/PV Test Part Storage IATF 16949 - Automotive Quality Systems Standard 9
R Statistical Methods for comparing test and reference product equivalence for quality attributes US Food and Drug Administration (FDA) 3
Vader22 5 Why RCA for failure to test Contingency Plan IATF 16949 - Automotive Quality Systems Standard 9
S Knee-Patella wear test CE Marking (Conformité Européene) / CB Scheme 4
L PFMEA for test procedures (ISO 14971) ISO 14971 - Medical Device Risk Management 5
A Direct vs. Post-License Investigational Test Authorization (ITA) Canada Medical Device Regulations 0
P Test Method Validation (TMV) for all Measurement Methods in Rec/Inspection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
L AS9100 Section 8.4.2 - External provider test reports AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
T ANOVA analysis to find F test. Using Minitab Software 3
P API Q1 - Monogram Product & API 4F - Proof Load Test Oil and Gas Industry Standards and Regulations 3
D Test Management Software Software Quality Assurance 1
B How to test operator to see if they can catch the defective parts? Manufacturing and Related Processes 8
G 60601-1 8.8.3. short circuit of both side during insulation test IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
K Bacterial Endotoxin test for Purified water Manufacturing and Related Processes 2
shimonv Test Method Validation ISO 13485:2016 - Medical Device Quality Management Systems 10
C Test compulsory for Sutures? Manufacturing and Related Processes 6
dgrainger Informational DRAFT: The Medical Devices (Coronavirus Test Device Approvals) (Amendment) Regulations 2021 UK Medical Device Regulations 1
K Identification test in ph.eur. Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 1
AllTheThings ISO-17025 accredited TEST lab performing internal calibrations (Yes: Here is how) ISO 17025 related Discussions 8
R Cost per test tool/formula Oil and Gas Industry Standards and Regulations 1
A R chart from ANOVA gage R&R test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
K Ground Bond Test for Class I Medical Electrical Equipment - calibration problems IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
