How to test operator to see if they can catch the defective parts?
Hi, Top management would like to see the plan for testing new operator to see if they can catch quality defect part during their production or not. The idea is they want us to create bad parts during the normal production run and let operator do the regular job and expecting they find these bad parts. Basically, we will not let operator know of this event and these bad parts cannot be marks/identify which will be notice by operator. I am scratching my head on how to do this? In order to create bad parts, someone has to stop the machine and change tool to create hole size, angle etc.,. The only defect we can create is raw material defect where we can make raw material bad and this will be a visual defect only. Now, This is a risk to ship this parts to customer as this will be tested during normal production run un less we need to hold all product from this lot and do a 200% inspection. Anyone have experience or any suggestion on how we can test operator for the quality defect during the production run? Please and thank you ..
Ps. I know we can create various defective parts and mix with other good parts and ask them to inspecting them during their quality check, which we can create more defects to fail during CMM, gauges and visual, but management want to be on their production process during a regular check.
John Predmore
I think you asked 2 questions, a) how to make bad quality part that isn't obvious and b) how to find the bad part in case the new operator missed it, in the batch of finished parts. You know better than I your process and quality requirements. You mentions a tool to make a hole, so I will assume some type of drilling operation in a block of raw material. You didn't say if there is any gaging involved.
a) you could slip in a block of different raw material which machines differently, a different grade of steel or heat treated differently. If the raw piece has to fit in a fixture, you could make a workpiece that doesn't fit the nest properly. The height of the block could be slightly lower or higher, maybe.
b) Let's assume the pieces do not have serial numbers. If the parts are placed sequentially in stacks or trays after drilling, the location in the tray would correspond to the position in the sequence. One way to make a hidden "red rabbit" is to color the part with ultraviolet dye, then use a black light to find it in the finished parts tray.
Your top management need a lesson in process control. Deming would be spinning in his grave if he could read this. Why waste peoples' time on this futility? Fix the reasons for defects being caused. Do they know about PFMEA?
Yes, operators requires to check part with gauges on Finish good. It will be easy if I can throw the bad part on the finish good pallet before they checking it, but management need engineering/quality to make them create bad part (not us) and they need to be able to capture those bad parts. Engineering cannot just stop the machine and changing tool eg. different drills to make oversize/undersize hole, surface or angle without operator knowing it. M/C cannot do that itself. But, your suggestion below is really help me to get more on this.
Yes this is a good one to add on, we can make part to not fitting to the nest, so operator should be quickly identify the defective raw material and not just place it anyway.
b) Let's assume the pieces do not have serial numbers. If the parts are placed sequentially in stacks or trays after drilling, the location in the tray would correspond to the position in the sequence. One way to make a hidden " is to color the part with ultraviolet dye, then use a black light to find it in the finished parts tray.
Again, yes we should use the ultraviolet dye to identify this bad part later on.
Thank you:
Ron Rompen
What you appear to be describing is (in actuality) a GRR study for operator inspection. Treat it as such.......take a population of KNOWN good parts, and add in your KNOWN bad parts. Number each of the parts (you want a fairly large sample size for this) and keep a record of which parts are known bad and good. Review the parts which were rejected by the operators, to see if they detected all the known bad parts, and if they rejected any of the known good parts.
Sidney Vianna
Post Responsibly
The end goal should always be to develop production processes so capable/robust that you could eliminate inspections as they would become non-value added. That's the essence of Deming's 3rd point of "Cease dependence upon inspection as a way to achieve quality."
It does NOT mean STOP ALL INSPECTION.
For multiple reasons, many organizations will not be able to develop processes that are reliably defect-free; so, while still aiming at better process capabilities via improvement initiatives, they have to rely on some form of inspection and/or testing (verification) for certain attributes to minimize escapes moving downstream. When that is the case, the inspection process itself needs to be effective and there is nothing wrong in making sure the inspectors are capable of detecting the out of spec characteristics.
B Operator protection - When to apply table 7, Dielectric strength test voltage IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
optomist1 MSA Gage R&R - Destructive Test with One Sided Specification and One Operator Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
B Designing a Test Part to Assess CMM Operator's Knowledge Design and Development of Products and Processes 9
B Independent Tests - Another operator or tester to do the final test? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
B Gage R&R for Automatic Test Systems - No operator influence on readings Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
D Test Equipment at Work Station - Are Operator Daily Checks part of Laboratory Scope? General Measurement Device and Calibration Topics 7
A Direct vs. Post-License Investigational Test Authorization (ITA) Canada Medical Device Regulations 0
P Test Method Validation (TMV) for all Measurement Methods in Rec/Inspection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
E How to test 8.7.4.7 d) ? What "not protectively earthed accessible part" means? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
T ANOVA analysis to find F test. Using Minitab Software 3
P API Q1 - Monogram Product & API 4F - Proof Load Test Oil and Gas Industry Standards and Regulations 3
D Test Management Software Software Quality Assurance 1
G 60601-1 8.8.3. short circuit of both side during insulation test IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
K Bacterial Endotoxin test for Purified water Manufacturing and Related Processes 2
shimonv Test Method Validation ISO 13485:2016 - Medical Device Quality Management Systems 10
C Test compulsory for Sutures? Manufacturing and Related Processes 6
dgrainger Informational DRAFT: The Medical Devices (Coronavirus Test Device Approvals) (Amendment) Regulations 2021 UK Medical Device Regulations 1
K Identification test in ph.eur. Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 1
AllTheThings ISO-17025 accredited TEST lab performing internal calibrations (Yes: Here is how) ISO 17025 related Discussions 6
R Cost per test tool/formula Oil and Gas Industry Standards and Regulations 1
A R chart from ANOVA gage R&R test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
K Ground Bond Test for Class I Medical Electrical Equipment - calibration problems IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
P Burst Test Acceptability Criteria ISO 13485:2016 - Medical Device Quality Management Systems 2
A 60601-1 clause 8.11.3.6 Test Clarification IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
E Test report to certify compliance with IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 3
E Tensile test machine, tinius olsen 602 Manufacturing and Related Processes 1
M Test failure Root cause not found Customer Complaints 10
D Tip test 10° -> 5° IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
M Sponsor name presented in the test report EU Medical Device Regulations 4
M Packing Validation & Accelerated Aging Test ISO 13485:2016 - Medical Device Quality Management Systems 2
S OEM full range calibrations vs Validation special test points Medical Device and FDA Regulations and Standards News 1
S Shelf Life Test for IFU and Implant Card Other Medical Device Related Standards 1
S Critical characteristic on manufacturing operations test procedure Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
S Knee Implant (Femoral -Cobalt chrome)-Sub chronic toxicity test (ISO 10993-11)choice of root Medical Device and FDA Regulations and Standards News 2
S Non parametric test for semi-quantitative data. Statistical Analysis Tools, Techniques and SPC 5
Ed Panek Disaster Recovery Test IT (Information Technology) Service Management 3
Z Is Op Amp Common-Mode Rejection Ratio (CMRR) test applicable to battery operated devices? Other Medical Device Related Standards 0
E When to perform accelerated aging studies and transport test(OQ or PQ) Qualification and Validation (including 21 CFR Part 11) 4
A Test requirements for marketing in US when RATED values are not of US IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
