How to test the quality of black anodized aluminum
Daidawei
We are receiving black anodized aluminum cases for our products that are easily scratched and the layer is probably too thin. What tests can we do to check the quality, what tools would we need and how would we perform them? Is there a simple way, like a scratch test?
Thanks for your help!
jasonb067
Re: How to test the quality of black anodized aluminum?
Is the anodize cosmetic only or is there a functional purpose? I imagine the specific requirements are either on the drawing or referenced in a specification or standard. Those will usually describe test methods which may be as simple as a thickness requirement which will require a laminia thickness gage.
Also anodize should generally not scratch off as it is not a coating but is rather a deposit or growth of aluminum oxidation.
Daidawei
The anodizing is for cosmetic appearance. I will have to check the drawings for the requirements. I checked our cases and the indeed there are scratch marks where you can see the base metal. Perhaps the supplier didn't do it right or didn't anodize it at all and just painted it black. Either way, our IQC missed it (I work in China).
Thanks.
John Broomfield
Daidawei,
Anodizing is a 7.5.2 process. Your supplier selection criteria should have ascertained the status of their anodizing process against your specification for black anodized aluminum cases before placing the order.
Now you may be stuck with what you have bought.
Here is more guidance on specifying and testing anodizing:
http://www.anodizing.org/Reference/reference_guide.html
Best wishes,
John
jasonb067
If the material is being scratched where are the scratches coming from? If the material is simply not as durable as it should be you may have a problem that will be a long time correcting. Otherwise eliminate the scratch source.
Daidawei
Yes, we are definitely stuck with these. I just don't want it to happen in the future. I just started this job this week as a project manager but have somehow become the QA manager (surprise!) and I'm not too familiar with anodized materials.
Thanks for everyone's help. I think I can take it from here.
silentrunning
One quick and simple test to see if it is actually anodized as opposed to a dye or chromate is to check it with a continuity tester. Put a probe on each end of the part. A properly anodized part will have no continuity. A chromated or dyed part will show good conductivity.
Murphys Law
Daidawei - Are you buying these off the shelf or are they making them only for you?
What does you contract say about layer thickness and the quality level of thickness/scratches etc? There maybe a minimum level of defects within this shipment that is 'allowed' per contract.
Did you even specify an Acceptable Quality Level ? If you didn't, then you're company has a problem in your contract process and the contract then is whatever the supplier says it is per their Average Outgoing quality level.
ML.
Big Jim
As Murphy's Law alluded to, a key here is what requirements did you flow down to your supplier?
If you simply stated black anodized, that is probably just what you got. If you stated black anodizing per one of the specs so nicely provided by John Broomfield, particularly hard anodizing, you may not have received what you asked for.
Two principles here in dealing with suppliers:
You should get what you ask for.
You will get what you permit.
Tell them what you want and then hold them to it.
If you didn't ask for the right thing, you may also have an engineering problem in that your engineers were not specific enough with the requirements.
K
kgott
Some time ago I worked for a company that made transportable acommodation and we used anodised aluminium windows and we had smilar issues. One of the things we did was use a sample window frame against which purchased windows were tested if there were doubts about the quality of it.
The sample was viewed under cover at a set height off the ground and viewed from two different angles. It was then taken out outdoors and placed directly facing the sun at the same height and looked at from the same two angles.
Doubtfull product was placed along side the sample on both occasions. The supplier was invited to participate or witness the test which they did in the begining. Thereafter they simply accepted the returns and used the same test for their own testing
Perhaps you could try something similar
L Difference between a Quality Plan and Inspection & Test Plan (ITP) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
L Electrical Cable Harness Quality Control - Sampling Plan for Pull Test Manufacturing and Related Processes 4
M Auditing Test Management Software such as HP Quality Center (HPQC) Test Tool Internal Auditing 1
A Test Documentation Quality for Completed Project Quality Manager and Management Related Issues 1
suildur Assuring the Quality of Test and Calibration Results - ISO IEC 17025 Clause 5.9 ISO 17025 related Discussions 13
P Tips on how to test air and improve air quality - What is a Positive Air? Food Safety Food Safety - ISO 22000, HACCP (21 CFR 120) 3
K Quality Tech Skill and Comprehension Test example and help needed. Quality Manager and Management Related Issues 5
U Question about test management tool (softwares) for Quality assurance department Quality Assurance and Compliance Software Tools and Solutions 10
L EMC Engineer in a Test Laboratory Transitioning into Quality - Looking for Guidance Career and Occupation Discussions 4
B ASQ's CQE (Certified Quality Engineer) Test Questions Pattern Professional Certifications and Degrees 7
A Supplier Quality Management Strategies - Semiconductor Assembly and Test Services Supplier Quality Assurance and other Supplier Issues 6
Jim Wynne A Simple Test for Prospective Quality Technicians Coffee Break and Water Cooler Discussions 57
D CQE (Certified Quality Engineer) Test - 5 hours, any breaks? Professional Certifications and Degrees 3
A Quality Test - Which of the following is not a measure of spread in a distribution? Six Sigma 11
R Hired to set up a First Article Test Lab on base - 17025 Quality System? ISO 17025 related Discussions 3
Q Advice for the ASQ CQM (Certified Quality Manager) Test? Professional Certifications and Degrees 14
Marc Software QA (Quality Assurance) Test Site Software Quality Assurance 0
S ASQ's CQT (Certified Quality Technician) Certification - Is it worth taking the test? Professional Certifications and Degrees 9
L ASQ CQA (Certified Quality Auditor) Test - Any advice for me? Professional Certifications and Degrees 6
M CQM - Has anyone taken the Certified Quality Manager's test? Professional Certifications and Degrees 2
S Knee Implant (Femoral -Cobalt chrome)-Sub chronic toxicity test (ISO 10993-11)choice of root Medical Device and FDA Regulations and Standards News 2
S Non parametric test for semi-quantitative data. Statistical Analysis Tools, Techniques and SPC 5
Ed Panek Disaster Recovery Test IT (Information Technology) Service Management 3
Z Is Op Amp Common-Mode Rejection Ratio (CMRR) test applicable to battery operated devices? Other Medical Device Related Standards 0
E When to perform accelerated aging studies and transport test(OQ or PQ) Qualification and Validation (including 21 CFR Part 11) 4
A Test requirements for marketing in US when RATED values are not of US IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
H Secondary Circuits, Voltage Test and Clearance/Creepage IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
S Fogging test as per DIN 75201(50ug/g ) VDA Standards - Germany's Automotive Standards 3
R HV Test of HF Surgical Unit IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
E 60950-1 resistance to abnormal heat test Various Other Specifications, Standards, and related Requirements 0
S User evaluation for self monitoring blood glucose test systems US Food and Drug Administration (FDA) 4
E MSA for Push and Pull test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
J Confusing on Harmonic Emissions/Voltage Fluctuations/Flicker test for CISPR 11 Class A Equipment IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
E Routine production tests - dielectric voltage withstand test IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
D Test Method Validation Qualification and Validation (including 21 CFR Part 11) 4
Crimpshrine13 Laboratory Scope - Calibration vs. Test Methods - IATF 16949 IATF 16949 - Automotive Quality Systems Standard 3
R Accelerated Aging - Creating test samples - Implantable medical device Question Other Medical Device Related Standards 4
L ASQ's Biomedical Auditor Course Test ASQ - American Society for Quality 1
W Regarding Requirement for Hi pot & Leakage Current test Station Set-up IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
R Regulatory Affairs Certification (RAC) prep - Practice test versus actual exam Professional Certifications and Degrees 1
