How to understand correctly the section of 5.11 MOC in API Spec Q1?
lanley liao
We have a little confused that we have already modified some documented procedures according to the requirement of nonconformances correction action. During the auditing, the auditor said that where is the MOC activity record. then the document modification applications and approved forms for documented procedures modified were provided to the auditor by us. however, the auditor said that this is not recorded for the requirement of 5.11 MOC. Finally, the auditor wrote in auditing finding that the required records of MOC activities related to the management system procedures were not maintained. hence, how to understand correctly the section of 5.11 MOC in API Spec Q1? How to differentiate between document change and management of change.
I would be greatly appreciated it if you can help me.
Lingli Liao.
April,27,2021.
Thee Bouyyy
Multiple Personalities
Sorry for the late response.
First, I would like to bring your attention to MOC process. 5.11 clearly says that, "MOC is applicable for changes which negatively impact quality."
Here, you are talking about d) Changes to the management system procedures, including changes resulting from corrective and preventive actions.
Now, my question to you is that, "What type of documented procedures you have modified?" "Do you think so that will impact negatively on quality?" "Do you have document change program available?"
You have to clearly write in procedure like this, "For sake of clarity please note that our management / M.R. will decide which change can impact negatively on quality or which change does not impact. M.R. ensures that MOC is required only for changes which negatively impact quality of product. Routine process / person change / termination / promotions are not treated as MOC, provided they do not impact negatively on quality of product."
jmech
Thee Bouyyy has raised a good point. The requirement is to "use the MOC process for any of the following that may negatively impact the quality of the product". His suggestion is one way to handle it that makes sense (assuming that M.R. means Management Representative), provided that the management rep is reasonable in their assessments of which changes may negatively impact quality.
The challenge with this requirement is that whether a change "may" negatively impact product quality is often unclear.
The "changes to the management system procedures, including changes resulting from corrective and preventive actions" clause is a weird one because when you change the procedures due to a corrective action, the change should be intended to improve product quality and should not have a negative impact on product quality.
Document changes shall always follow your document control procedure (per API Q1 4.4.3). Additionally, when a management system procedure is changed in a way that may negatively impact product quality, the MOC process shall also be followed.
Example #1:
If you change your inspection procedure in any way, you must follow your document control procedure.
If you change your inspection procedure to increase the frequency of inspection, this change will not negatively impact product quality, so MOC is not required.
If you change your inspection procedure to decrease the frequency of inspection, this change may negatively impact product quality, so MOC is required in addition to document control.
Example #2:
If you change your "documented procedure to measure customer satisfaction" (required per 6.2.1) to reduce the frequency of measurement of customer satisfaction, the change is required to follow your document control procedure, but it is debatable whether this "may" negatively impact product quality, so it is unclear whether you would be required to use MOC for it.
lanley liao How to correctly understand the bullet list d) of 6.3 Analysis of Data for API Spec Q1 Oil and Gas Industry Standards and Regulations 7
J Help to understand and response to API AAR during the re-certification audit Oil and Gas Industry Standards and Regulations 17
lanley liao How to understand and master the requirements of each section in API monogram product. Oil and Gas Industry Standards and Regulations 5
lanley liao How to understand this words that the planning of internal audit shall take into consideration the results of previous audits? Oil and Gas Industry Standards and Regulations 10
lanley liao How to understand this bulleted list from API 600 Oil and Gas Industry Standards and Regulations 0
A Tips and Tricks to understand ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
lanley liao How to understand the term 3.1.21 'Servicing' and the clause 5.7.1.2 'Servicing' of API Spec Q1? Oil and Gas Industry Standards and Regulations 19
sutie How to understand VDA 6.3 2016 P4.1 VDA Standards - Germany's Automotive Standards 6
Ajit Basrur Need help to understand HIPAA requirements ISO 13485:2016 - Medical Device Quality Management Systems 17
H Embedded Software - I don't understand that Calibration and Metrology Software and Hardware 2
J IATF 16949 Clause 9.3.2.1 - How to understand "measures" IATF 16949 - Automotive Quality Systems Standard 4
J Please help me understand what a process is ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J Please Recommend books that explain how to understand IATF 16949 IATF 16949 - Automotive Quality Systems Standard 3
J How to understand the word "include" in IATF 16949 IATF 16949 - Automotive Quality Systems Standard 2
J How to understand IATF 16949 Clause 8.5.6.1.1 - Process Controls IATF 16949 - Automotive Quality Systems Standard 2
J How to understand IATF 16949 Clause 8.5.2.1 - Traceability IATF 16949 - Automotive Quality Systems Standard 5
S Trying to understand 7.2.1(d) of ISO 13485 - Medical Device User Training ISO 13485:2016 - Medical Device Quality Management Systems 8
M Help me understand how to conduct a Chi Square Test Statistical Analysis Tools, Techniques and SPC 3
S Informational Please help this newbie understand ISO 9001 Work Instructions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 44
F Help me understand the ANOVA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
M Kindly help me to understand MSA Acceptance Level Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
T Help me understand how to define Processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 40
N Help me understand the ISO section 7.5.2 from API Q1 perspective Oil and Gas Industry Standards and Regulations 4
A Help me understand the applicability of 21 CFR Part 820.198 (Customer Complaints) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
D Pls hlep me understand the "Total Anaerobic Plate Count" Food Safety - ISO 22000, HACCP (21 CFR 120) 1
A How to understand the source of variability and "stream-to-stream variation" Six Sigma 8
K Training the absolute beginner to understand AQL Training - Internal, External, Online and Distance Learning 1
R How to understand the exception of IEC 60601 sub-clause 8.11.5 IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
B I want to understand the ISO certification process. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
M Reference to understand ISO9001 Book, Video, Blog and Web Site Reviews and Recommendations 1
N Owner of Company Doesn't Understand Corrective Action.... Quality Manager and Management Related Issues 12
R How to understand the IEC 60601 50 ms limit? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
L Fourier Analysis for NVH - Reference info to understand the Fourier Analysis method General Measurement Device and Calibration Topics 4
R How to understand the "full scale peak-to-valley output" mentioned in IEC 60601-2-27 IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
A Help Engineers understand the differences between Bill of Materials and Routers Document Control Systems, Procedures, Forms and Templates 9
G Numbers that will help us understand what the Cost of Rework is Misc. Quality Assurance and Business Systems Related Topics 7
Z How to understand Processes, Procedures and Documented Procedures Misc. Quality Assurance and Business Systems Related Topics 7
G Newbie in IMDS - Please help me understand what I have to do RoHS, REACH, ELV, IMDS and Restricted Substances 4
J Knowledge of CAR/PAR Procedures - Should the entire organization know/understand? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
K General Term for Inspection Process of Sample Parts that everyone can understand Supplier Quality Assurance and other Supplier Issues 10
B ISO 9001:2008 - Can any one help me to understand this paragraph? Clause 8.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
Z Don't quite understand interpretation of ISO17025: 2005 clause 1.4 and 1.2 ISO 17025 related Discussions 13
L What's the best way to understand IEC 60601-1 standards IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
J How to understand NOTE 2 in the ISO 9000 definition of defect? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
R Please help us to understand clause 5.5.2 of ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Q An Engineer that does not understand gage R&R? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 17
D Can Someone help me to understand....... Imported Legacy Blogs 3
B Books to Understand FMEA Book, Video, Blog and Web Site Reviews and Recommendations 5
G Upper Management Pay - I seriously don't understand this Quality Manager and Management Related Issues 30
