How to understand the clause 6 Planning of ISO 9001:2015
Hi,The question is described below:
The adutior aske us to provide a evidence of planning to achieve quality objectives during auditing the 6.2.2 of ISO 9001:2015.We replies:"this clause is not required to retain a record or maitain a documented information,so we don`t need to provide."Because we have created document information for quality objectie at relevant functions and levels within the organazation,including the Quality Objectives Breakdown Form and Checked Form.How do you think this clause about?
I use the management review report and in the outputs of that document, I describe that based on what is previously described (understand inputs) the company establishes the objectives for the following year so that we can improve performance, etc. (see point 10.1 of ISO 9001: 2015)
Hi,AntonioSousa,Thank you so much! Would you interpret the clause 6.2.2 of ISO 9001:2015 for me ?
I'll try it.
I created a document for recording the quality objectives of year x and planning how to achieve them. I monitor these objectives in the file and make a note worth noting.
Then in the Management Review Report in the chapter of the results entry, I write a text with a summary analysis.
In the exit chapter, I write that taking into account the external, internal context and the results of the risk register, the quality objectives for the following year were those that are in the objectives registration document for year x + 1
In my year x objectives registration document I have our quality policy and I can evidence:
ƒ for the relevant functions, levels and processes relevant to the
Quality Management System;
ƒ processes with the principles of quality policy;
ƒ measurable;
ƒ that considers the applicable requirements;
ƒ that are relevant to the conformity of products and services, and
for customer satisfaction.
In this way, the auditor assesses that the principles contained in the policy are effectively supported by measurable objectives, and are being monitored, and, in case of deviation, actions are triggered.
The standard now also deepens the question of planning to achieve the objectives and reinforces that the organization must determine:
ƒ the actions to be taken to achieve them;
ƒ the necessary resources;
ƒ the associated responsibility;
ƒ the term; and
ƒ the form of evaluation of the results.
When referring that the organization must maintain documented information regarding the objectives, it is expected that this planning will also be evidenced in documents.
The auditor will seek to assess the planning, allocation of responsibilities, the availability of resources, monitoring the planning of actions defined to achieve the objectives, as well as actions triggered in case of deviation
translate by google
Tagin
I maintain a QMS doc called "Quality Objective Plan", which documents the plan for the objective including 6.2.2 a-d (what steps, how is it measured, who is responsible, etc.) It also actually helps to make sure these points are clarified before starting implementation. It's just a simple form, but it makes life easier and audits easier.
I'll try it.
ƒ measurable;
ƒ the term; and
translate by google
LL,
Were you able to explain the five points listed in 6.2.2?
Hi,The five points is "How the results will be evaluated",which told us that how to check quality objectives achieved is effective.in fact,it is an calculation method of objective and targe of the result from process operation ,which i.e is Mathmatic Calculaiton Formula.Right?
lanley liao How to understand the term 3.1.21 'Servicing' and the clause 5.7.1.2 'Servicing' of API Spec Q1? Oil and Gas Industry Standards and Regulations 19
J IATF 16949 Clause 9.3.2.1 - How to understand "measures" IATF 16949 - Automotive Quality Systems Standard 4
J How to understand IATF 16949 Clause 8.5.6.1.1 - Process Controls IATF 16949 - Automotive Quality Systems Standard 2
J How to understand IATF 16949 Clause 8.5.2.1 - Traceability IATF 16949 - Automotive Quality Systems Standard 5
R How to understand the exception of IEC 60601 sub-clause 8.11.5 IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
B ISO 9001:2008 - Can any one help me to understand this paragraph? Clause 8.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
Z Don't quite understand interpretation of ISO17025: 2005 clause 1.4 and 1.2 ISO 17025 related Discussions 13
R Please help us to understand clause 5.5.2 of ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C Need to understand difference between an actual Calibration vs. a Calibration check General Measurement Device and Calibration Topics 3
J Help to understand and response to API AAR during the re-certification audit Oil and Gas Industry Standards and Regulations 17
lanley liao How to understand and master the requirements of each section in API monogram product. Oil and Gas Industry Standards and Regulations 5
lanley liao How to understand correctly the section of 5.11 MOC in API Spec Q1? Oil and Gas Industry Standards and Regulations 3
lanley liao How to understand this words that the planning of internal audit shall take into consideration the results of previous audits? Oil and Gas Industry Standards and Regulations 10
lanley liao How to correctly understand the bullet list d) of 6.3 Analysis of Data for API Spec Q1 Oil and Gas Industry Standards and Regulations 7
lanley liao How to understand this bulleted list from API 600 Oil and Gas Industry Standards and Regulations 0
A Tips and Tricks to understand ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
sutie How to understand VDA 6.3 2016 P4.1 VDA Standards - Germany's Automotive Standards 6
Ajit Basrur Need help to understand HIPAA requirements ISO 13485:2016 - Medical Device Quality Management Systems 25
H Embedded Software - I don't understand that Calibration and Metrology Software and Hardware 2
J Please help me understand what a process is ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J Please Recommend books that explain how to understand IATF 16949 IATF 16949 - Automotive Quality Systems Standard 3
J How to understand the word "include" in IATF 16949 IATF 16949 - Automotive Quality Systems Standard 2
S Trying to understand 7.2.1(d) of ISO 13485 - Medical Device User Training ISO 13485:2016 - Medical Device Quality Management Systems 8
M Help me understand how to conduct a Chi Square Test Statistical Analysis Tools, Techniques and SPC 3
S Informational Please help this newbie understand ISO 9001 Work Instructions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 44
F Help me understand the ANOVA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
M Kindly help me to understand MSA Acceptance Level Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
T Help me understand how to define Processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 40
N Help me understand the ISO section 7.5.2 from API Q1 perspective Oil and Gas Industry Standards and Regulations 4
A Help me understand the applicability of 21 CFR Part 820.198 (Customer Complaints) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
D Pls hlep me understand the "Total Anaerobic Plate Count" Food Safety - ISO 22000, HACCP (21 CFR 120) 1
A How to understand the source of variability and "stream-to-stream variation" Six Sigma 8
K Training the absolute beginner to understand AQL Training - Internal, External, Online and Distance Learning 1
B I want to understand the ISO certification process. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
M Reference to understand ISO9001 Book, Video, Blog and Web Site Reviews and Recommendations 1
N Owner of Company Doesn't Understand Corrective Action.... Quality Manager and Management Related Issues 12
R How to understand the IEC 60601 50 ms limit? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
L Fourier Analysis for NVH - Reference info to understand the Fourier Analysis method General Measurement Device and Calibration Topics 4
R How to understand the "full scale peak-to-valley output" mentioned in IEC 60601-2-27 IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
A Help Engineers understand the differences between Bill of Materials and Routers Document Control Systems, Procedures, Forms and Templates 9
G Numbers that will help us understand what the Cost of Rework is Misc. Quality Assurance and Business Systems Related Topics 7
Z How to understand Processes, Procedures and Documented Procedures Misc. Quality Assurance and Business Systems Related Topics 7
G Newbie in IMDS - Please help me understand what I have to do RoHS, REACH, ELV, IMDS and Restricted Substances 4
J Knowledge of CAR/PAR Procedures - Should the entire organization know/understand? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
K General Term for Inspection Process of Sample Parts that everyone can understand Supplier Quality Assurance and other Supplier Issues 10
L What's the best way to understand IEC 60601-1 standards IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
J How to understand NOTE 2 in the ISO 9000 definition of defect? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Q An Engineer that does not understand gage R&R? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 17
D Can Someone help me to understand....... Imported Legacy Blogs 3
B Books to Understand FMEA Book, Video, Blog and Web Site Reviews and Recommendations 5
