How to use FC-30 optical compartor?
megan c
Does anybody have some suggested literture on how to use optical compartors.We have recently puchased a FC-30 I have no experience at all with using one.I desperatly need to get this bad boy inspecting on these goverment contracts.PLEASE HELP!!!!!!!!!!!!!
RoxaneB
Welcome to the Cove! :bigwave:
Did the machine come with a user manual? Or could the company from which you purchased the machine help?
megan c
The manual is very old and very useless.Jones & Lamson technical support was very vague.It wasnt much support. We purchased the machine at an auction.
Wes Bucey
Old? Yes! Useless? Maybe.
I've never operated one of these monster machines, but I have seen them. They are excellent for certain puposes.
Aside from the fact someone would buy a machine ("optical comparator" - correct spelling) he didn't know how to use, your situation is not much different from that of any organization where the sole operator of a specialized machine dies or quits without passing on his knowledge.
(I never learned how to program one of our CNC turning centers. In fact, I would have had to read the operating manual just to figure out how to turn it on. I was lucky. We had lots of skilled folks who did know.)
The first thing here is to greet you: Welcome to the Cove! bigwave-d2.gif
The second thing is, don't panic.
Third, here are several options for you, depending on your product, your customer requirements, and your urgency:
  1. If no one in your organization has ANY experience with optical comparators, You can advertise for someone to come in and operate your machine who DOES have experience.
  2. You can survey machine shops in your area for someone who has operated a big 30 inch screen comparator like this to come in and moonlight to train several employees to use it for your specific need.
  3. You can take a general course at a technical college (google - some even have internet access to take an on-line course) on the general concept of using optical devices for inspection.
  4. Ignore the comparator and use an alternate method to inspect your product.
Next, I'm curious about your product and what you need to inspect that you think you need a used optical comparator to perform the inspection. Typically, the best use of an optical comparator is with a specially etched or marked "chart" which can be either frosted glass or a translucent or clear overlay sheet to put on the screen to compare the part or a feature of the part to the drawing, measurement, radius, angle, etc. on the overlay chart. The technical term some use for the chart is "reticle." Here's a company that makes them so you can see what I mean http://www.reticles.com/comparators.htm (this is only one of hundreds of sources.)
If you don't have such a chart for your part, you need to have one made.
I'm looking forward to learning more about your situation.
Govind
Calibrate the equipment first!
Megan,
Welcome to Cove.
Some call this equipment Shadowgraph. We call Profile Projector.
This is the equipment web page from Google search http://www.rtsalesinc.com/Quotes, P...uipment/Jones & Lamson Optical Comparator.htm
This equipment is not very difficult to use. You may require 60 minute training for manual version of this equipment. Since you bought this equipment from an auction, you may want to calibrate the equipment before using. Usually when the profile projectors are moved from one location to other, it has to be recalibrated. The mirrors, lenses mounted inside might have shifted during movement cause erroneous magnification. The calibration technician will also be able to explain you the functions.
It is a simple equipment with a turret to accommodate lenses with different magnification (Example 10X, 25X, 50X, 100X), a table with X, y axis micrometers, a Z axis rotary handle to move the table up/down to adjust the sharpness of the image.
As mentioned by Wes, the overlay is available from various manufacturers including Mitutoyo. You may specify the diameter of the screen and purchase applicable overlays.Overlay with Concentric circles and angle lines, Overlay with thread profiles for inches and metric are the most useful ones. You may create your own overlay with component profiles on “non shrinking drawing film”. Try to use thinnest pen available in the plotter like 0.1mm. Use magnification higher than 25X.
The most painful portion of using the manual profile projector is to align the object on the table. This require patience and time.When I started Metrology back in late eighties, we had to undergo this pain. Later advancement, a (Mitutoyo) fiber optic scale and microprocessor (Example: Quadracheck2000) combination are available that makes the job easier. This attachment automatically senses the shadow edges on the screen and aligns skewed axis in the microprocessor to perform other measurements like distance, hole positions and much more.
Hope this information helps.
Regards,
Govind.
Ron Rompen
Just an add-on to the previous information that has been shared.
One of the BEST uses of an optical comparator/shadowgraph is with optional after-market software/accessory packages. We currently have 2 OC's, both of which use edge-detector technology coupled with QC4000 software.
(Shameless plug here...QC4000 is, IMNSHO, the epitomy of what a software package should be. I can train an operator to do extremely complex layouts, including importation of CAD data, creation of CAD models, export of data to Excel spreadsheets, etc in less than 8 hours. I use this program as the benchmark when evaluating ANY other software).
The reticle system is useful as an attribute (i.e. Go-NoGo) gauge, but does not give variable measurement, which is, in most cases, much more useful.
If you would like more info on this, please PM me, and I will give you additional information (contact names/companies which have proven useful in the past).
G
gaugefixer
Megan, I have to agree with Govind. Get the machine calibrated and get training at the same time. Tell the calibration company that training in the use is needed. Any good technician or calibration organization will be able to do training.
While the machine may be old and a beast; a good technician will clean it up and suggest some parts or upgrades that you may need.
Good luck!
optomist1 Best Optical Comparators General Measurement Device and Calibration Topics 9
P Need a programmer for QVI's VMS software for optical inspection machine Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
S Is Optical Parallel Set required calibration? ISO 17025 related Discussions 1
S Optical coherence tomography (OCT) device - Do we need to apply IDE? Other US Medical Device Regulations 0
G How to compute or estimate a micrometer or caliper flatness using optical flat General Measurement Device and Calibration Topics 2
Q NADCAP NDT (specifically RT) - Calibration of eye loupe reticle & optical comparator AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
J TOPCON PP-70 Optical Comparator - User Manual Needed General Measurement Device and Calibration Topics 0
G Optical Comparator Light Bulb Wear question General Measurement Device and Calibration Topics 1
rob73 Advice/recommendations for equipment to measure a soft pvc tube - Optical Measuring? General Measurement Device and Calibration Topics 4
D Using a "broken" measurement device in a TS 16949 company - Optical comparator IATF 16949 - Automotive Quality Systems Standard 4
C Uncertainty Estimation for Spark Optical Emission Device Measurement Uncertainty (MU) 1
Marc Mind-bending optical illusion paintings Coffee Break and Water Cooler Discussions 3
T Optical Comparator measuring of Position of a Threaded Hole Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
M Basic International Standards required for a Manufacturing Industry (Optical Media) Other ISO and International Standards and European Regulations 4
C Optical Comparator Uncertainty Budget Measurement Uncertainty (MU) 2
S How to calibrate AOI (Automated Optical Inspection) for IOPQ Qualification and Validation (including 21 CFR Part 11) 3
A Best Way for SPC via Optical Comparator with output to Computer for Data Analysis Statistical Analysis Tools, Techniques and SPC 4
M Typical values of MTBF for Optical Avionic Networks Reliability Analysis - Predictions, Testing and Standards 1
F Optical Gaging Systems - Shadows, debris, etc. cause parts to measure out of spec Measurement Uncertainty (MU) 7
S Calculating an Uncertainty Budget for an Optical Comparator General Measurement Device and Calibration Topics 4
J How to measure the True Position on an Optical Comparator Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
R Optical Emission Spectrometer Calibration General Measurement Device and Calibration Topics 0
3 Vision System Optical Calibration Standard General Measurement Device and Calibration Topics 6
B Optical Steel Surface Inspection System (best hardware to recommend) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
J Checking the Theoretical Sharp of a Flush Head Bolt on an Optical Comparator Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
T Optical Emission Spectrometer Calibration to a National or International Standard Various Other Specifications, Standards, and related Requirements 4
J Uncertainty Budget for the Optical Microscope - Deriving Linearity Uncertainty Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S GR&R (Gage R&R) for an Optical Comparator or Vision System Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
J MU (Measurement Uncertainty) for an Optical Microscope Measurement Uncertainty (MU) 7
M Methods for Verification/Calibration of Video (Optical) Extensometer General Measurement Device and Calibration Topics 2
A Optical Magnification Checking Graticule - Starrett 400-360 (P-10089) General Measurement Device and Calibration Topics 2
somashekar Optical epoxy for LED having good thermal shock resistance. Manufacturing and Related Processes 2
Q Validating the AOI process (Automated Optical Inspection) Reliability Analysis - Predictions, Testing and Standards 9
F How to inspect the 5 different dimensions using an optical comparator Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
Q PCBA Visual Inspection Tools & Methods - discounting Optical Tools Manufacturing and Related Processes 11
M Serial Numbers for Product - Common sense? Optical Components for Telecommunications Manufacturing and Related Processes 9
Marc Email in the 18th Century - The Optical Telegraph After Work and Weekend Discussion Topics 0
K GR&R for an Automatic Optical Inspection Machine (AOI) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
ScottK Moving an optical comparator - recalibration needed? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
Jim Wynne Checker Square Optical Illusion Coffee Break and Water Cooler Discussions 14
samer Some Optical Illusion Examples Coffee Break and Water Cooler Discussions 6
B Can I calibrate Optical Comparators internally? General Measurement Device and Calibration Topics 22
ScottK Automating variable inspection - Calipers, micrometers, and optical comparators Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Q What is the best optical comparator? General Measurement Device and Calibration Topics 14
H Attribute Gage R&R for Repair Station Operators - AOI (Automated Optical Inspection) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
D Calibration of Optical Comparator Overlays - Radius, Thread and Angle General Measurement Device and Calibration Topics 11
N Ocr (OPTICAL CHARACTER RECOGNITION) Scanners Quality Assurance and Compliance Software Tools and Solutions 4
M How can I evaluate/measure backlash on an optical comparator General Measurement Device and Calibration Topics 1
D Optical flats - "FLATNESS INTERPRETATION CHART, Light Wave Band Pattern Guide" General Measurement Device and Calibration Topics 4
