How to use Minitab to create this Fractional Factorial Design Matrix
bioplanet
Hello there!
I am a newbie in Minitab software, and I am trying to use it to create a design matrix for a 2^(15-11) fractional factorial design (the (n-11 FrFD) case).
Could you tell me what steps I must follow?
Stat > DOE > Factorial > Create Factorial Design > Number of Factors = 15 > Designs > 1/2048 fraction, 16 runs, resolution III, 2**(15-11).
Note that this is a screening design. If your process has the potential for interactions, you will not be able to distinguish them from a main effect. This is okay if your intent is to screen out insignificant factors and perform a higher resolution experiment on the reduced set remaining.
Barbara B
It is recommended to use at least a resolution IV design to avoid the problems described by Miner. This could be done via a 2**(15-10) design with 32 runs.
T How create a Fractional Factorial Design with Minitab Using Minitab Software 3
S Response Surface Method to create design matrix in Minitab Using Minitab Software 5
G How to create a mixed OAs in Minitab Using Minitab Software 1
R Select the 1 Supplier based on the Parts Durability from 6 Supplier Samples using Minitab Using Minitab Software 11
A One-factor and multiple-response Minitab optimization Using Minitab Software 0
O Problem in Minitab - ERROR * Factor Voltage is highly correlated with other terms Using Minitab Software 10
F Minitab 19 Anova or X bar # of distinct catagories Using Minitab Software 2
S Asterisk in DOE minitab software Using Minitab Software 23
Z Minitab - Updating Graph with specific data points Using Minitab Software 2
S Need help with analysing a survey on minitab Using Minitab Software 1
M Minitab assistant: 1-Sample % Defective Test Using Minitab Software 1
G Batch printing reports in Minitab Using Minitab Software 3
I Number of decimals in equation calculated by MiniTab Using Minitab Software 0
A Acceptance p-value for linearity and bias analysis in minitab results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
M How to change the display of optimization plot in Minitab 18 Using Minitab Software 2
M Minitab tool to evaluate PM (Preventive Maintenance) process Using Minitab Software 6
E Input to ANOVA 1-WAY - How can I perform this analysis in minitab? Using Minitab Software 2
J Including Repeats in DoE using Minitab Using Minitab Software 5
A Minitab 18: How to automate GRR Summary Table save Reliability Analysis - Predictions, Testing and Standards 1
N What subcommands can be used with "Stop" in Minitab 18? Using Minitab Software 8
S Minitab - Factor Analysis: Label on second series of data for Biplot Using Minitab Software 4
J Which Anova dropdown to use for R&R in Minitab? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
J DoE - Number of runs in Plackett-Burman (Minitab) Using Minitab Software 2
D Asterix when pasting a column of values from Excel into Minitab (V17) Using Minitab Software 5
A Generating samples from a population in Minitab Using Minitab Software 0
Ron Rompen Random data generation in Minitab Statistical Analysis Tools, Techniques and SPC 2
I DOE: High variance and small effects in Minitab Using Minitab Software 1
B Informational Expanded Gage R&R Analysis using Minitab Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 18
R Rank Deficiency Error Minitab Using Minitab Software 7
H Minitab 15 - Factorial Design - 3 factors: 4x3x2 - How to? Using Minitab Software 4
A Capability Analysis for Packaging Seal Strength with spec. >0.1 Kgf using Minitab Using Minitab Software 6
Coury Ferguson MiniTab 17 Question-Standard Deviation Default Capability, Accuracy and Stability - Processes, Machines, etc. 5
N Regression Model (Minitab 18) - Which values my input parameters should have Using Minitab Software 2
L MINITAB 17 - Changing Data Using Minitab Software 3
R Conjoint Analysis - Minitab 18 Statistical Analysis Tools, Techniques and SPC 2
F How to make an ANOVA of a design with repeats (not replicates) in Minitab? Using Minitab Software 18
W Definitive screening design in Minitab 17 Manufacturing and Related Processes 1
S Minitab runs at different speeds on identical PCs Using Minitab Software 5
S Minitab limit definition from R & R Using Minitab Software 4
S Standard Deviation Selection on Control Charts - Minitab "pooled deviation" Statistical Analysis Tools, Techniques and SPC 3
P Minitab Data Analysis - Understanding if a Process is in Control or Not Using Minitab Software 2
P Basic Minitab Help - It's about Linear Regression Using Minitab Software 1
