How to use Sampling Plans - Confusion on Lot Sampling
V
vasilist
Hello to all!
Either i am confused on how to use sampling plans or i need to review my knowledge about statistics.
Here's the case :
There's a supplier whose product is flour. he produces sacks of 50kr.
I have to check if he delivers sacks of 50 kgr (net weight).
The supplier delivers the sacks in XX different stores.
The average number of sacks delivered per month is 1455 in these XX stores.
I check the MIL-STD105E and i see that the coresponding letter is K
I choose the general inspection level II and i use the normal inspection table.
There as i understand i have to weight 125 sacks and according to AQL i will reject the lot (1455) if i find a number equivalent or higher to number "Re"
What i want to ask is trhe following : Am i going the right way?
Some thoughts / questions :
- i know that MIL-STD105E was cancelled. Should i use ISO 2859 and if yes which vesrion?
- Could the average number of sacks per month as described above represent a "Lot"?
- There is no reference to AQL in the contract between buyer / supplier. I have to persuade our top management to discuss it with the supplier.
- Our supplier has not gave us a range (+/-) concerning the net weight of the product.
How can i make a descent sampling or what sampling method should i use?
I will appreciate even the slightest help since it seems that no matter if i know some things in practice i do not feel sure on what to do. Thank you for your time reading this post.
V
vasilist
Re: Confusion on Lot Sampling - How to use sampling plans
Dear Coury, it's ok. Thank you anyway.
After reading all the AQL posts in the apropriate forum i understood that my post has troubled the visitors maybe because . Moreover i understood that there is NO AQL defined in a contract between the supplier and the buyer (us). The issue is to persuade top management to include the AQL in the contracts...
Not the AQL, necessarily, but a reasonable tolerance. If the nominal weight is 50kg, how much is the supplier allowed to vary from that amount? It sounds to me like you need to establish a tolerance and then ask your supplier to do MSA and a capability study. From that point you might ask your supplier to improve the process or you might accept the supplier's present capability and adjust the tolerance accordingly.
Note that because flour is a food product, there might be regulations in your locality dealing with package weight that will bear on your situation.
F Product audit sampling plans IATF 16949 - Automotive Quality Systems Standard 3
A ISO 2859-1 - 9.3.3.2 Switching score - Sampling Plans and PPM AQL - Acceptable Quality Level 0
V Statistical basis and justification while comparing / changing sampling plans Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
N The question asks about sampling plans and AQL Reliability Analysis - Predictions, Testing and Standards 5
C Are zero defect sampling plans relevant to AS9120B Distributor AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
M ISO / ASTM standards for Sampling Plans for Medical Devices Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
M Help interpreting MIL-STD-105E Single Sampling Plans Tables Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
A Attribute Sampling Plans with Switching Rules - Software Recommendations Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
U AQL, Lot Size vs Sampling Plans AQL - Acceptable Quality Level 8
P Lot Acceptance Plan that specifies BS 6001 Double Sampling Plans, general inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
M AS9100A (old revision) - Required C=0 sampling plans if sampling was used? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
D Disposable Medical Device Sampling Plans per ISO 2859-1 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
R Relating Cpk to Sampling Plans - AS9100C Para 8.2.4 & AS9103 Para 4.4 d. Capability, Accuracy and Stability - Processes, Machines, etc. 1
R Is AQL sampling plans applicable for Bulk Pharmaceutical Manufacturing (API)? Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
K Sampling Plans - Continuously Decreasing Sampling Over Time Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
G Why do we use Sampling Plans based on Producer's Risk? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 20
J Sampling Plans - AQL Table Application AQL - Acceptable Quality Level 2
Q Inspection Methods and Plans - Forgetting to Switch Sampling Levels Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
C C=0 vs. AQL MIL Standard 105 E - Sampling Plans Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
I Sampling Plans - Guidance to Sampling a Process during Validation Qualification and Validation (including 21 CFR Part 11) 12
T Skip Lot Sampling Plans (SkSP) - Oil for Trans Fatty Acid Content Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
R Zero Acceptance Sampling Plans 5th edition by Squeglia - Question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
O Sampling Plans for a Medical Device - What to use for my Accept and Reject Number? AQL - Acceptable Quality Level 3
M Zero Acceptance Number Sampling Plans for Isolated Lots Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
K Cleaning Validation Plans, Sampling, etc - Allergens in Food Qualification and Validation (including 21 CFR Part 11) 1
T Zero Failure Sampling Plans Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
H How to decide AQL value? Sampling Plans AQL - Acceptable Quality Level 5
B Determining Statistical Confidence and Reliability Levels with Sampling Plans Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
A What is a good lot size? We use the C=0 Sampling plans at AQL %1.0 AQL - Acceptable Quality Level 9
B AS9100C Sampling Plans - When samples have known nonconformities Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
R Sampling plans for mass-produced fasteners - I'm concerned with PPM and AOQL Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
I Sampling Plans for Critical Defects Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
P Zero Acceptance Number Sampling Plans, Fifth Edition (e-Book) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
A Use of sampling plans like MIL-STD-105 E or ANSI Z1.4? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
A Use of sampling plans like MIL-STD-105 E or ANSI Z1.4 for setting AQL's? AQL - Acceptable Quality Level 13
G Sampling plans for large quantities along lines of ISO 2859-1:1999 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
K Design of Lot Acceptance Sampling Plan - Zero Acceptance Number Sampling Plans Inspection, Prints (Drawings), Testing, Sampling and Related Topics 27
R Sampling Plans - ISO 2859-1: 1999 - How to calculate the switching score? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
I Asian Supplier Sampling Plans besides MIL-STD-105? My thought was ISO 2859? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
P Sampling Plans for Corrective and Preventative Maintenance Service Orginizations Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
QChas The Source of "C=0 Sampling Plans Index Values (Associated AQLS)" AQL - Acceptable Quality Level 3
R Need to set up sampling plans in Receiving Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
S Developing sampling plans based on AS1199, ISO 2859-1 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
B Can Continuous Sampling Plans be applied to service organizations? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
J Reducing Inspection Costs - Sampling Plans and Producer's Risk Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
L Sampling Plans - Can a company create its own Sampling Plan? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
Douglas E. Purdy Sampling Plans & Control of Nonconforming Product Inspection, Prints (Drawings), Testing, Sampling and Related Topics 21
C Internal Audit Sampling Plans - Determining Internal Audit Sample Size Internal Auditing 45
A Sampling Plans and Cpk - Ways to Calculate the Sample Quantity Inspection, Prints (Drawings), Testing, Sampling and Related Topics 15
J How do you explain sampling plans to management? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
