How to use Total Variation based on Process or Tolerance? Page 60 of the MSA manual
F
Frestruc
Hi Everybody,
I don't know if this question has already been asked, but here he comes...
I have a question concerning p60 of the MSA manual (3th edition): when you do an MSA study on e.g. a new measurement fixture, which TV do you then use?
On p60 there is mentionned that you can do the analysis based on the process variation or based on tolerance. There is mentionned also "Either or both approaches can be taken depending on the intended use of the measurement system and the desire of the customer".
The customer sent us an MSA sheet with a TV based on process variation. If I use this, my %R&R is not good (because the results are very similar to eachother). If I use a sheet with the TV based on the tolerance, my results are off course much better...
Which way of calculating the TV should I use and when do I use the other method?
Thanks in advance for the help...:thanx:
The method to be used depends on the purpose of the gage itself.
If the gage is used solely for inspection to tolerance (accepting or rejecting the product), use the P/T Ratio (gage R&R vs tolerance).
If the gage is used for process control (SPC), use the %GRR (gage R&R vs process variation).
Search this forum and you will find several threads that address this in greater detail.
antoine.dias
Welcome
Hi Frestruc, welcome to the cove.
If you take the tolerance as a reference for MSA calculations you have to take the tolerance divided by six.
See MSA manual ( 3rd version ) at the bottom of page 116
Best regards,
Antoine
B Gage R&R Acceptable (10-30%), deduct Total Variation from Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
P Total Variation in Data - Overall Importance of the Principal Components Reliability Analysis - Predictions, Testing and Standards 1
S Ppk & Cpk - Within Subgroup Variation is always smaller than Total Variation Capability, Accuracy and Stability - Processes, Machines, etc. 18
A %Total Variation & %Tolerance - Differences in Gage R&R Forms and Templates Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
R Total Tolerance Method vs. Total Variation Method - Measurement System Analysis Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
M Total Variation Formula - Can someone provide a source for this formula Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
P Calculating Gage R&R with Part Tolerance instead of Total Variation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
9 Process Variation and Total Variation - Relationship and Definitions Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
W How Total Variation is calculated - Minitab Gage Question Using Minitab Software 2
G Tolerance vs Total Variation in Gage R&R report - MSA 3rd edition pg. 116 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 14
J Gage R&R - Tolerance vs. Total Variation - Process Variation vs. Gage Variation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B Total Productive Maintenance - Company Transport IATF 16949 - Automotive Quality Systems Standard 2
J Implementation of Total Quality Management/Starting a Quality Department Reliability Analysis - Predictions, Testing and Standards 9
K IATF16949 8.5.1.5 Total Productive Maintenance IATF 16949 - Automotive Quality Systems Standard 9
B IATF 16949 Section 8.5.1.5 (Total Productive Maintenance) IATF 16949 - Automotive Quality Systems Standard 19
M Total number of Requirements for ISO 9001:2008 vs. ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
J One third of the total audit days on manufacturing (TS 16949) General Auditing Discussions 2
M Total Productive Maintenance vs. Lean, Six sigma, Business Process Reengineering, etc Quality Tools, Improvement and Analysis 9
F What is the scope for "Total Numbers of Employees on site" per ISO/TS 16949 ? IATF 16949 - Automotive Quality Systems Standard 4
Marc Total Lunar Eclipse Visible in North America - 15 April 2014 Coffee Break and Water Cooler Discussions 4
K Can I use ANSI/AQL for the Total Number of Containers for the entire Lot? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
I Supplier Selection based on Total Cost question Supplier Quality Assurance and other Supplier Issues 4
B Total Resolution of an Measurement Instrument Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
D Pls hlep me understand the "Total Anaerobic Plate Count" Food Safety - ISO 22000, HACCP (21 CFR 120) 1
G How can Total Quality help a company or business compete in the world market? Preventive Action and Continuous Improvement 2
M How many documents total do you currently have? Document Control Systems, Procedures, Forms and Templates 6
5 Reasonable GRR result for a 0-1" micrometer with a total tolerance of .002" Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 16
C A total newbie to AS 9101 needs general help AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
B Total Productive Maintenance Templates to Drive TPM Forward Lean in Manufacturing and Service Industries 1
N Total Productive Maintenance (TPM) Portuguese Definitions and Terms Quality Tools, Improvement and Analysis 4
V Differences between Business Process Reengineering (BPR) and Total Quality Management Quality Manager and Management Related Issues 3
Z KPI Formula Issue - "Change Requests Managed" = Changed/Total ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
optomist1 Circular Runout vs. Total Runout Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
optomist1 Circular or Total Runout Gears and Splines? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
Q Inspecting Total Runout Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
P Uncertainty Measurement for Colour, Odour, Taste, Turbidity, Total Suspended Solids Calibration Frequency (Interval) 2
S Determining the Total Sample Size using AQL - AQL Lot Quantity question AQL - Acceptable Quality Level 8
D TQM (Total Quality Management) Diagram Software Quality Assurance and Compliance Software Tools and Solutions 4
R Total Quality Management (TQM) in the Aerospace Industry AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
A TQPC (Total Quality Process Control) for Injection Molding Quality Manager and Management Related Issues 4
C ASQ Quality Management Journal Vol. 17 Total Quality Management (TQM) Comments Wanted Book, Video, Blog and Web Site Reviews and Recommendations 8
N ISO 9001 and the HR Function - Developing a Total Quality Management System for HR ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
K Where to obtain General Concepts of Total Organic Carbon (TOC) testing information? US Food and Drug Administration (FDA) 2
B Mojonnier method (determining fat and total solids) validation General Measurement Device and Calibration Topics 1
K Quality Assurance Clinical Research Auditor - Masters in Total Quality Management Career and Occupation Discussions 3
R TPM (Total Productive Maintenance) Reference Books Suggestions Book, Video, Blog and Web Site Reviews and Recommendations 3
M Top Three Reasons why TPM (Total Productive Maintenance) Initiatives Fail Manufacturing and Related Processes 39
N Journey towards total quality and Optimal results Misc. Quality Assurance and Business Systems Related Topics 4
L Total Quality Management System Quality Manager and Management Related Issues 3
bobdoering Total Variance Equation and process capability Imported Legacy Blogs 4
