How to validate Regulations and Standards?
Firstly, I apologize for my poor English.
Hi, could anyone tell us how to establish validation procedure for regulations and standards.
If there were user needs that the device is lightweight, we would write that the device must be X lbs +/- Y lbs and within Z inches in height as design input. Then, I would identify them on drawings or specifications as design verification. Finally, the resulting product would be tested in the actual or simulated use environment as a part of validation. It’s easy for us to understand this process but when it comes to “Regulations and Standards, we’ve been confused.
So far, that my opinion:
1.We would write that the device must comply with XYZ Regulations and Standards as design input. Design output is specifications.
2As Early stage of design verification, we would just identify that specifications state that the device must comply with XYZ Regulations and Standards (example: Must evaluate biocompatibility complying with ISO 109930-1).
3.End stage of design output would be biocompatibility test results.
4.AS end of design verification, we would just identify that biocompatibility test result.
5. We don't know how the resulting product validation
I know my recognition is wrong so, could anyone tell us correct procedure for design the verification/validation.
planB
nannan,
for your specific example ISO 10993-1:2018, you may walk through the flowchart and referenced sections provided in Figure 1. Would this flowchart address your verification/validation questions at least with regards to biocompatibility?
HTH,
yodon
For standards, you're really just wanting to demonstrate compliance (ignore "verification" and "validation" for now). I think all of the standards describe the means by which compliance is demonstrated. NBs will generally be looking for evidence that compliance was assessed by an accredited lab. There's nothing stopping you from doing the testing yourself but that will delay the review since they won't "trust" your data whereas if you had a 10993 (or 60601-1) reports from an accredited lab then they will accept those without much review.
thank you for your replay.
Do you mean that standards (not regulations) are just methods of the design verification? Sorry I can't understand why it can be ignored verification and validation.
Thank you for all your support, but I think my strategies from wrong premises, so could you see following figure to clarify my understanding?
The text shown in blue is the intended question also I don't know specific things that apply to "????????".
nannan,
HTH,
thank your for your support.
May be a little different from my intention
Could you see my new post?
Tidge
I would NOT try to associate "Regulations" with "User Needs". Fundamentally: Compliance to Regulations is only required to market devices.
It is true that regulations (and standards) are often established because they are motivated for patient/user safety, but user needs are independent of regulations/standards. A design team should have a regulatory/market strategy for devices, but don't confuse this with user needs.
The model shown has many peculiarities. I would destroy it (Design Inputs exist both before and after Design Outputs?)
Ed Panek
QA RA Small Med Dev Company
User Needs drive Design Inputs. Generally, regulators accept solid "bench " testing to demonstrate fulfillment of user needs but sometimes its not complete. For example, if your device is to be used on human skin it will require some skin irritation mitigation. This would involve ISO 10993 and its subchapters. If you have a test report from a lab conducting ISO 10993 testing on your device along with a Literature Review on the materials you use it closes many questions from the due diligence perspective.
yodon
My mistake, I meant ignore the "terms" verification and validation for now.
We frequently have risk controls that say the risk is mitigated by design in accordance with some standard. Then the test lab demonstrates compliance so in effect, the compliance testing is often associated with some of the verification. We don't, though, articulate all the requirements from a standard as design inputs (or cite the standard as a user need). The point I intended to make was to not try to put a label on compliance testing.
I also agree with @Tidge in that your model is a bit off. You won't "ask a Dr. if the device is lightweight." There are a lot of nuances there that would take a wall of text to post. If you're trying to do V&V on your own, you might want to get some more experienced help.
Tagin
Would it make sense to think of compliance with standards/regulations as 'design constraints'? Or, is it more straightforward to think in terms of two sets (or classes) of requirements: 1) user reqs., and 2) regulatory reqs.?
validationspec How to Validate the Automated Processes (CNC Lathe and Milling)? ISO 13485:2016 - Medical Device Quality Management Systems 5
L How to determine / validate Medical Device Storage Conditions ISO 13485:2016 - Medical Device Quality Management Systems 1
Anonymous16-2 21 CFR Part 11 - Steps to take if we want to validate an electronic system Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
T How to “validate/qualify” a new measurement equipment? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
R Validation of Medical Device Hardware containing Software - How many to Validate ISO 13485:2016 - Medical Device Quality Management Systems 1
S Do we need to validate Software used in Drug discovery and development process? Qualification and Validation (including 21 CFR Part 11) 2
kisxena Memo to File - Failure to Validate Supply Chain Security Management Systems 1
A ISO 13485:2016 - Validate our use of software that impacts on the QMS ISO 13485:2016 - Medical Device Quality Management Systems 12
A Process to Validate the Accuracy of Test Reports (AS9100) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 38
C Do we need to Validate Off the Shelf Software? Manufacturing and Related Processes 5
M How to validate hundreds or even thousands of parts? Qualification and Validation (including 21 CFR Part 11) 7
B How to validate Microsoft Excel Spreadsheet Calculations for the Cpk value Capability, Accuracy and Stability - Processes, Machines, etc. 9
M How to validate a system to make it compliant with 21 CFR Part 11 Qualification and Validation (including 21 CFR Part 11) 2
B Do I need to validate my database software? Calibration and Metrology Software and Hardware 1
K COTS Validation: Should we validate Windows after each Update? IEC 62304 - Medical Device Software Life Cycle Processes 3
S How to validate a homegrown software 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
A How to verify and validate the effectiveness of CAPA with regards to employees ? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
A When to verify and when to validate Design Changes 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
H How To Validate Electronic Part From Non Authorized Distributor Process Maps, Process Mapping and Turtle Diagrams 7
G Prototype Manufacturing Equipment - Validate or not to validate? Quality Manager and Management Related Issues 2
S How to validate Device Shelf Life? CE Marking (Conformité Européene) / CB Scheme 8
M Destructive VTMV Subgroups - A Destructive Variable Test Method to Validate Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
M How to validate a Dye Test method used to evaluate Package Integrity Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 8
I When to Validate and when not to Validate US Food and Drug Administration (FDA) 24
C How do you Validate Solderability of Components Prior to Soldering Operations Manufacturing and Related Processes 5
M Welding - to Validate or Not? If so, How? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
V Do we need to Validate a Server/Back-End System? Qualification and Validation (including 21 CFR Part 11) 2
I Using validated SAS JMP to validate Excel for Statistical Analysis? Qualification and Validation (including 21 CFR Part 11) 11
E How to Validate Master Equipment that has been brought to onsite General Measurement Device and Calibration Topics 12
E When to Validate a Process - 21 CFR Part 820.75.(a) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
R How to bond PVC (Tygon) Tubing and Validate the Process ISO 13485:2016 - Medical Device Quality Management Systems 13
T Do I need to validate a basic Excel spreadsheet Quality Assurance and Compliance Software Tools and Solutions 14
R Process Validation - Adhesive Bonding, what to validate and how? Qualification and Validation (including 21 CFR Part 11) 10
N How to Validate a Gage R&R Spread Sheet General Measurement Device and Calibration Topics 3
A How to Validate Effectiveness of Mitigations? ISO 14971 - Medical Device Risk Management 13
C Validate the idea of a Composite Performance Index Quality Tools, Improvement and Analysis 4
M How to determine/validate the "REQUIRED MANPOWER" in an office environment? Service Industry Specific Topics 4
R How to Validate Vision Inspection Systems Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
C Third-party lab needed to validate cleaning & disinfection? EU Medical Device Regulations 12
Proud Liberal How to validate the geometry of a 8 mm pitch, 22 tooth Gates HTD sprocket Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
T How does a tool-shop validate molds? Verification vs. Validation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
D Validate 99.5% reliability 90% confidence - Sample size calculation Reliability Analysis - Predictions, Testing and Standards 4
J Protocol to validate the use of Electronic Records like DHRs, NCMRs, Validations ISO 13485:2016 - Medical Device Quality Management Systems 3
N Periodically validate test reports for raw material - AS9100 7.4.3 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
V Calibration of a Digital Vernier - Need to check/calibrate/validate all 3 functions? General Measurement Device and Calibration Topics 9
P Last-off-part comparison used to validate the set-up (TS16949 Clause 7.5.1.3) IATF 16949 - Automotive Quality Systems Standard 3
E How to validate product if gage is determined out of calibration Document Control Systems, Procedures, Forms and Templates 19
M Digital Filling System - What do I need to Validate Here? Software Quality Assurance 1
M Seat Cover Product Validation for PPAP - How can I validate my product? APQP and PPAP 12
N Do we need to Validate Outsouced Processes? ISO13485 ISO 13485:2016 - Medical Device Quality Management Systems 12
