How to Validate the Automated Processes (CNC Lathe and Milling)?
Hello everyone in the community. I am Mechanical Engineer and hired by medical devices manufacturing company as a Validation officer.
I am a beginner in Validation field so I don't know much about it and so far I have only been doing Machinery Qualification. Most of the processes/operations are manual i.e. machines are utilized and operated by worker to get the job done. For these machine I have mostly done Installation qualifications and training of workers. While I am moving toward the automated process i.e. CNC Machining on Lathe and Milling machines I am completely blank here shall we validate these or just verify the output?
If validation needs to be done then shall we proceed and if verification is employed how shall I go about it? Your help is much appreciated. @bobdoering your help would be much appreciated.
Regards
Sohail
Tidge
I encourage a review of this historical document: Classic GHTF Guidance
I'm going to jump past the part of the discussion about motivating the validation (e.g. risk controls) and its power (e.g. sample sizes) and jump right to the main course: challenging the allowed range(s) of the process. Once a process is established, there will be an allowed range of settings for certain 'variables'... this could be speed settings, orientation of raw materials, flow of cutting fluid, whatever. These operator controlled settings (even if the operator is a computer!) are challenged 'at the extremes' to make sure that process outputs are conforming to specifications over the entire range of allowed settings. That is: the allowed/expected variation in the process doesn't lead to non-conforming outputs. This is referred to as an Operation Qualification (in medical device manufacturing, pharma uses a different definition).
The variability from raw materials and different operators is challenged during a Process Qualification (again, this is the definition used in medical device manufacturing, pharma uses a different definition).
normhowe
Tidge's advice is spot-on from my experience. One challenge that we've seen is the number of parameters and their extremes that need to be tested if you just charge ahead without thinking. The best strategy is to characterize your process well during design so that you have a clear understanding of how those parameters interact with each other. For instance, if you know that three parameters always follow each other, and you have a good theory for why, then you might be able to run only two test conditions. The caveat, as ever, is to document your reasoning well.
Dear @Tidge Thanks a lot for your reply. I went through the document you mentioned and according to that Numeric control (NC) cutting processes "may be verifiable, but for business purposes, validation can be chosen" and I fully understand that but Computer Numeric Control Processes are different from NC then how can we go about validating CNC cutting processes? Can you refer to me a template or something that gives more guidance for validating these CNC cutting processes? Thanks in Advance
Tidge
Your walking between worlds: Non-product Software (NPS) validation and Process validation.
Briefly: The process validation doesn't care if it is controlled by a human or computer, up until the point at which "variability due to operators" comes into play (PQ). The nature of the OQ challenges is essentially the same. The NPS validation needs assurance that the NPS system is in a state of control over the intended life of the software. For "embedded" software that "comes with the machine" and isn't going to be changed, there isn't much more onus on the Medical Device manufacturer beyond what would be covered in the IQ. (e.g. document the version of the firmware).
N How to validate Regulations and Standards? ISO 13485:2016 - Medical Device Quality Management Systems 12
L How to determine / validate Medical Device Storage Conditions ISO 13485:2016 - Medical Device Quality Management Systems 1
Anonymous16-2 21 CFR Part 11 - Steps to take if we want to validate an electronic system Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
T How to “validate/qualify” a new measurement equipment? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
R Validation of Medical Device Hardware containing Software - How many to Validate ISO 13485:2016 - Medical Device Quality Management Systems 1
S Do we need to validate Software used in Drug discovery and development process? Qualification and Validation (including 21 CFR Part 11) 2
kisxena Memo to File - Failure to Validate Supply Chain Security Management Systems 1
A ISO 13485:2016 - Validate our use of software that impacts on the QMS ISO 13485:2016 - Medical Device Quality Management Systems 12
A Process to Validate the Accuracy of Test Reports (AS9100) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 38
C Do we need to Validate Off the Shelf Software? Manufacturing and Related Processes 5
M How to validate hundreds or even thousands of parts? Qualification and Validation (including 21 CFR Part 11) 7
B How to validate Microsoft Excel Spreadsheet Calculations for the Cpk value Capability, Accuracy and Stability - Processes, Machines, etc. 9
M How to validate a system to make it compliant with 21 CFR Part 11 Qualification and Validation (including 21 CFR Part 11) 2
B Do I need to validate my database software? Calibration and Metrology Software and Hardware 1
K COTS Validation: Should we validate Windows after each Update? IEC 62304 - Medical Device Software Life Cycle Processes 3
S How to validate a homegrown software 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
A How to verify and validate the effectiveness of CAPA with regards to employees ? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
A When to verify and when to validate Design Changes 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
H How To Validate Electronic Part From Non Authorized Distributor Process Maps, Process Mapping and Turtle Diagrams 7
G Prototype Manufacturing Equipment - Validate or not to validate? Quality Manager and Management Related Issues 2
S How to validate Device Shelf Life? CE Marking (Conformité Européene) / CB Scheme 8
M Destructive VTMV Subgroups - A Destructive Variable Test Method to Validate Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
M How to validate a Dye Test method used to evaluate Package Integrity Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 8
I When to Validate and when not to Validate US Food and Drug Administration (FDA) 24
C How do you Validate Solderability of Components Prior to Soldering Operations Manufacturing and Related Processes 5
M Welding - to Validate or Not? If so, How? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
V Do we need to Validate a Server/Back-End System? Qualification and Validation (including 21 CFR Part 11) 2
I Using validated SAS JMP to validate Excel for Statistical Analysis? Qualification and Validation (including 21 CFR Part 11) 11
E How to Validate Master Equipment that has been brought to onsite General Measurement Device and Calibration Topics 12
E When to Validate a Process - 21 CFR Part 820.75.(a) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
R How to bond PVC (Tygon) Tubing and Validate the Process ISO 13485:2016 - Medical Device Quality Management Systems 13
T Do I need to validate a basic Excel spreadsheet Quality Assurance and Compliance Software Tools and Solutions 14
R Process Validation - Adhesive Bonding, what to validate and how? Qualification and Validation (including 21 CFR Part 11) 10
N How to Validate a Gage R&R Spread Sheet General Measurement Device and Calibration Topics 3
A How to Validate Effectiveness of Mitigations? ISO 14971 - Medical Device Risk Management 13
C Validate the idea of a Composite Performance Index Quality Tools, Improvement and Analysis 4
M How to determine/validate the "REQUIRED MANPOWER" in an office environment? Service Industry Specific Topics 4
R How to Validate Vision Inspection Systems Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
C Third-party lab needed to validate cleaning & disinfection? EU Medical Device Regulations 12
Proud Liberal How to validate the geometry of a 8 mm pitch, 22 tooth Gates HTD sprocket Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
T How does a tool-shop validate molds? Verification vs. Validation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
D Validate 99.5% reliability 90% confidence - Sample size calculation Reliability Analysis - Predictions, Testing and Standards 4
J Protocol to validate the use of Electronic Records like DHRs, NCMRs, Validations ISO 13485:2016 - Medical Device Quality Management Systems 3
N Periodically validate test reports for raw material - AS9100 7.4.3 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
V Calibration of a Digital Vernier - Need to check/calibrate/validate all 3 functions? General Measurement Device and Calibration Topics 9
P Last-off-part comparison used to validate the set-up (TS16949 Clause 7.5.1.3) IATF 16949 - Automotive Quality Systems Standard 3
E How to validate product if gage is determined out of calibration Document Control Systems, Procedures, Forms and Templates 19
M Digital Filling System - What do I need to Validate Here? Software Quality Assurance 1
M Seat Cover Product Validation for PPAP - How can I validate my product? APQP and PPAP 12
N Do we need to Validate Outsouced Processes? ISO13485 ISO 13485:2016 - Medical Device Quality Management Systems 12
