How will you handle Clause 6.1 - Risks and Opportunities for AS9100 Rev. D Auditors?
O
oldqamanager
Trying to find some ideas on how I can demonstrate compliance with this clause. Have heard lots of opinions, but not very much specific guidance. Anyone have any ideas? A risk register? A risk assessment spreadsheet? FMEA's. Is there a simple way to comply?? Thank you.
Sidney Vianna
Post Responsibly
Re: How will you handle Clause 6.1 Risks and Opportunities for AS9100 Rev. D Auditors
As a starting point, you can scroll down the page and see the "Similar Discussion Threads" section. Issue has been discussed many times.
O
oldqamanager
Well Thank you!!!
KyleB
Quality Engineer
Re: How will you handle Clause 6.1 - Risks and Opportunities for AS9100 Rev. D Audito
Here's an idea we went with, Adding some Risk coloring to our turtle diagrams.
Mike S.
Happy to be Alive
Old,
The ideas you have could be used, the one shown directly above as well. Do what makes sense to you.
durnan
I have a risks and opportunities procedure and documents, using Pestle, Swot and Risk register. If you would like a copy
  • Like
Reactions: JTM
Q
QAMTY
Durnan
Could you share such documents in order to cross ideas?
AMIT BALLAL
Hi!
I had shared these formats here earlier. Resending.
I hope it helps.
Regards,
Amit
  • Context-of-the-organization.xlsx
K
KF55555
Duran, if you are still willing to share a copy of your procedure, I would be interested in seeing how you wrote it.
AndyN
Moved On
Why not use your management review process? It doesn't say you have to have a procedure for section 4, just that items such as the scope, interested parties need to be documented in something which might be called a quality manual...
If you consider the theme behind the section 4 and 6 requirements, there's a lot of "business planning" hinted at. Doing a SWOT (or similar) doesn't need a procedure. Recording the results, evaluating which risk and opportunities present themselves and developing a plan (per 6.1) is well suited to being put on the agenda of the management review.
Having just gone through the AS9100D upgrade process using this methodology, I was pleased/shocked to hear the CB auditor describe it as "best in class" as an approach...:mg:
