How would you calculate this?
So let us suppose we have a 3 part assembly as a final product. The first part has 5 dimensions. The capability (z-bench) on the dimensions/specifications are listed below:
Dim 1: 4.5
Dim 2: 2.0
Dim 3: 0.5
Dim 4: 3
Dim 5: 6
Part 2 has 3 dimensions: All have a z-bench of 4.0
Part 3 has 4 dimensions: All have a z-bench of 2.5.
Each part is single step processed and then assembled. Let's suppose, for the sake of simplicity, that there are only two specifications for the stack up of the assembly and that the capability of those stack ups are a results of dimensions Part 1-dim 3, part 2- dim1, and 3-1. The capability for those 2 stack up's turns out to be 5.0 for each.
The assembly undergoes two required tests and the capability of those results are 3 sigma and 4 sigma respectively.
Question: What is the overall process capability of the product?
I would use a Monte Carlo simulation using the actual mean and standard deviations for the components to obtain the mean and standard deviation of the assembly.
I would use actual data of the final results over time and plot it against the specification limits and probably calculate the failure rate.
short fo that I would use bootstrapping of the data you have.
...but if this is a homework question then you won’t have any data and you won’t know what the distribution is and...it may be mathematically interesting but has no resemblance to real life. (I haven’t heard the term ‘z-bench’ in over 25 years.
It used to mean the Ppk that results when you take into account both tails of the distribution instead of just the worst tail...for both DFSS and DMAIC but it's really an old term
H How to calculate sample size and sample frequency Statistical Analysis Tools, Techniques and SPC 2
T Calculate FPY for Audit Results AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
D How to calculate the A4 constants in Median/Range control charts? Statistical Analysis Tools, Techniques and SPC 2
S How to calculate Effective Number of People for ISO 13485 Certification? General Auditing Discussions 2
A Need to calculate tolerance Intervals with a set of non-normal data and 3-Parameter Weibull distribution Using Minitab Software 0
U Calculate acceptance of equipment reading after calibration General Measurement Device and Calibration Topics 2
U Calculate acceptance of calibration reading Measurement Uncertainty (MU) 1
S Bend allowance formula to calculate per degree per radii Manufacturing and Related Processes 2
P Commercial excel templates that calculate overhead, hourly rates, fee proposal Excel .xls Spreadsheet Templates and Tools 0
M How to calculate benefits? Moving some developed non controlled software/automation systems Service Industry Specific Topics 2
qualprod Calculate number of people in processes, considering cycle time/takt time = quantity of people Lean in Manufacturing and Service Industries 9
S How to Calculate the producer Risk AQL - Acceptable Quality Level 25
qualprod Methods to Calculate Available Production Rate ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 0
K Why calculate LCL in P-chart? Statistical Analysis Tools, Techniques and SPC 4
B How to calculate CPK with n = 1 Manufacturing and Related Processes 2
A Add-On software for VMC to calculate setting time, Idle Time, OEE etc.. Manufacturing and Related Processes 2
L How to calculate the Probability of Deficiency of the AQL of an Inspection AQL - Acceptable Quality Level 16
V How to Calculate Unbiasing Constant C4 Statistical Analysis Tools, Techniques and SPC 1
J How to Calculate OEE Indicator for a Workshop (15 Machines) Lean in Manufacturing and Service Industries 6
R How to calculate UCL (Upper COntrol Limit) and LCL (Lower Control Limit) Statistical Analysis Tools, Techniques and SPC 5
T I want to calculate reliability at 750 hours Reliability Analysis - Predictions, Testing and Standards 8
R How To Calculate & Print CDF and Lower Bound CDF value for some t(time) with Minitab? Using Minitab Software 1
N How to calculate the Premium Freight charges Service Industry Specific Topics 4
A How to calculate Mean and standard deviation without sample size in Minitab Using Minitab Software 5
R When do I need to calculate Process OEE? Manufacturing and Related Processes 12
kedarg6500 How to calculate Thread Pitch Diameter for non standard TPI like 5/8" 17.75 NF3 Manufacturing and Related Processes 3
C Definition and Way to Calculate some Metrics Lean in Manufacturing and Service Industries 6
M How calculate P value for Linearity and Bias using Excel Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
N Formula that will calculate the NoGo Major Diameter of an M20 x 1.5 6H Thread gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
M How to calculate Cg and Cgk for a 2-Dimensional Area Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
T Calculation Question - Calculate the runner weight for a part Manufacturing and Related Processes 2
M Spreadsheet on How to Calculate SMT Capacity wanted Manufacturing and Related Processes 2
F How to Calculate the unbiased Standard Deviation in Excel using Minitab Formula Capability, Accuracy and Stability - Processes, Machines, etc. 6
S Spreadsheet that will Calculate Audit Duration times based on IAF MD5 and MD11 Excel .xls Spreadsheet Templates and Tools 8
M Calculate PPMs by going back to Date of Production or Date Noticed Quality Tools, Improvement and Analysis 7
M How to calculate MTTF (Mean Time to Failure) Reliability Analysis - Predictions, Testing and Standards 1
H How to calculate the Lot Reject Rate Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
L How calculate the number of samples Statistical Analysis Tools, Techniques and SPC 2
A Simple 125 piece part Capabilty Excel .xls sheet to calculate Cpk Capability, Accuracy and Stability - Processes, Machines, etc. 3
R How to calculate MMC when is placed after datum Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
S Which one is better to calculate, Cpk or Ppk? Statistical Analysis Tools, Techniques and SPC 11
C How to calculate P value on Probability Plot Statistical Analysis Tools, Techniques and SPC 1
S Supplier Disruption Score and how to calculate it Quality Tools, Improvement and Analysis 4
D IAQG OASIS - New tool to calculate Audit Time AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
M How to calculate dimensions of trapezoid ? Quality Tools, Improvement and Analysis 3
J How to calculate Surveillance Audit Days in Corporate Audit Scheme IATF 16949 - Automotive Quality Systems Standard 4
S How to calculate Supplier PPM at Receiving Inspection Document Control Systems, Procedures, Forms and Templates 2
K How to Calculate Sample Size at 95% Confidence Interval on Surface Roughness Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
R How to calculate the value add time? Lean in Manufacturing and Service Industries 2
