HP3325A Function Generator - Troubleshooting Modulation on Output
TGroulx
Edited content:
Yes, it is an HP3325A model.
I am getting modulated distortion on the output sparatically. I can not trace where it is coming from. I would like to fix it. If anyone has dealt with this error (which is not common and unheard of by most of my peers) please let me know what the error was so that I may fix it.
I have a feeling I am dealing with a short (or other inductance) from the amplifier into the frequency oscillator output. As it is amplitude modulation.
Thank you for any help.
Terry
Re: 3325A Troubleshooting Modulation on Output
Trying to find where this could be inserted if anyone has dealt with this.
Looks like AM
pretty funky, have never seen anything like it, it is not constant and in fact at the moment I can not duplicate it. Yesterday it was failing today it is fine :rolleyes:
I have a feeling that most people here will have no idea what you're asking. Could you explain the issue in more detail?
TGroulx
Terry
Jerry Eldred
I have a couple of thoughts...
1. When it appears, demodulate it and see what the modulation frequency is. That may be a clue.
2. Beware of ground-loop-induced RFI/EMI.
3. Beware of RFI/EMI in general. Could be you have interference coming from somewhere else. I have seen numerous instances of RFI/EMI causing extra junk to intermittently ride on generator outputs, and oscilloscope inputs.
4. Check line voltage (low probability; but I have had crazy problems due to insufficient line voltage). It is at least worth a quick check.
5. Definitely check power supply voltages and ripple while the problem appears. If you have a flaky cap on a supply voltage, that MIGHT cause that sort of problem.
6. Press CAL and see what it does.
7. Change functions and see what it does. Does the problem appear in triangle, square, sine, or just sine? That could narrow down it's source.
Those are a few thoughts.
TGroulx
Thanks!!!!!
1. I cannot believe I did not check that.
2. Checked
3. Checked
4. Good Idea
6. Good Idea
6. No change
7. No Change
W
wmarhel
It was amazing the number of times people would write up test equipment for failure to operate, only to find out that:
1) It wasn't plugged in
2) The batteries were dead
3) the fuse was blown (which the operator was usually allowed to repair themselves if they would have checked it in the first place)
4) The unit wasn't turned on to begin with
Some of the people writing the problem up would have used the equipment to repair and maintain an aircraft. Everyone is a allowed a brain fart now and then I guess. Better to write the equipment up, then to pencil whip the repair of the aircraft.
As for being sporadic, does it seem to have a pattern to the occurrence? Does it happen when somebody might be banging on, or bumping into the test bench? Does it do this when the case cover is on/off/both? How about trying to isolate the ground of this unit?
I didn't read the particular specs for this unit, but what frequency ranges are we talking about, and does it do this across the entire frequency span of unit?
Have you cleaned the board and connections and make sure there is nothing which might be bridging somewhere?
It's been over 10 years since I've worked on anything like that, but keep us posted for a root cause.
Wayne
Hershal
Metrologist-Auditor
I agree with the others, most likely a bad cap.....also take a good look at the circuit board for cracks or other signs of solder joints degrading especially with caps in the power supply, or if a hair or similar might have shorted something just enough to allow bleed through to your output....
Hershal
TGroulx
eh, contacted customer, we set it off to the side temporarily. No bad caps, no other locatable problems, we have decided it is now a spare time project in order to keep costs down for the customer.
P Search function minimum length Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 3
K Multiple function device products EU Medical Device Regulations 0
D Question regarding ECO process, specifically for Life Science products and defining form fit and function ISO 13485:2016 - Medical Device Quality Management Systems 1
shimonv FDA News FDA guidance on Multiple Function Device Products (8/2020) Other US Medical Device Regulations 1
D DQ documents of new equipment - Function specification Qualification and Validation (including 21 CFR Part 11) 0
J Auditing of Support Function IATF 16949 - Automotive Quality Systems Standard 9
K Measuring Function MEDDEV 2.1/5 relation with MDD 93/42/EEC CE Marking (Conformité Européene) / CB Scheme 1
T Spirometer - Pulmonary Function Testing - ATS/ERS:2005 EU Medical Device Regulations 5
M How to complete structure Analysis and Function analysis sections' columns of AIAG-VDA DFMEA form FMEA and Control Plans 0
8 Need Help - Runout - Function Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
C Function definition for DFMEA FMEA and Control Plans 1
T AS9100D - Scope of QMS for New Company - Only Choosing a Function Subset Due to Management AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
C FMEA - Multiple function failures considerations FMEA and Control Plans 3
S Status products when/if the QMS ceases to function? EU Medical Device Regulations 1
M New Medical Device Accessory with New Function - Is this a major change? Other Medical Device Regulations World-Wide 3
W Is sharing resources treated same way as remote function? IATF 16949 - Automotive Quality Systems Standard 1
H Conveying Form Fit and Function Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
G Function in french called "numbre de posage(s)" - CMK Question Quality Tools, Improvement and Analysis 3
M Remote Office only has Invoice Function - Audit Needed? IATF 16949 - Automotive Quality Systems Standard 0
J FAI per AS9102 affecting Fit, Form, Function AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
MDD_QNA What is the function of the Critical Component List? ISO 14971 - Medical Device Risk Management 2
M Cross Function Process Map for Document Control Process Maps, Process Mapping and Turtle Diagrams 3
F Which Business Function should Approve Suppliers and maintain the ASL Supplier Quality Assurance and other Supplier Issues 8
L How to Introduce the Quality Function to the production floor in a bad environment Misc. Quality Assurance and Business Systems Related Topics 6
A ISO 27001 function wise or department wise audit questionnaire with control & clauses IEC 27001 - Information Security Management Systems (ISMS) 3
M Taguchi Loss Function Problem Misc. Quality Assurance and Business Systems Related Topics 2
C IVDD 98/79/EC Measuring Function Requirements EU Medical Device Regulations 2
N Regulatory and Safety Standards for Medical Device with Measuring Function IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
M Where to start Maintenance Function Kaizen Lean in Manufacturing and Service Industries 4
L Remote Control Inspection Digital Indicator with a TIR (range) function Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
J CE Mark Classification for a a pulmonary function test filter CE Marking (Conformité Européene) / CB Scheme 2
S Outsourcing PPAP Function APQP and PPAP 8
F What is an FAA PAI Maintenance Function List? Federal Aviation Administration (FAA) Standards and Requirements 3
Z Scope of Employee and Function Levels of Internal Audits Internal Auditing 3
T Difference between the terms Function & Process when used in Construction Management Business Continuity & Resiliency Planning (BCRP) 12
N Role of Quality Function in Approving Work Instructions Document Control Systems, Procedures, Forms and Templates 4
C What can you do if Quality is treated as a separate function in an organization? Quality Manager and Management Related Issues 24
V Annual Performance Appraisal - Person vs. Function/Business Career and Occupation Discussions 5
B Which type of DOE was likely used for this transfer function? Six Sigma 4
A Function for Effects - Beginner in usage of the IQRM FMEA and Control Plans 3
P Nonlinear Fit for a Complicated Curve - Fitting a Function to the Data Statistical Analysis Tools, Techniques and SPC 6
V SOPs and Internal Audit Criteria for Regulatory Affairs (Submissions Function) US Food and Drug Administration (FDA) 4
V What kind of Data should support Fit/Function Characteristics? APQP and PPAP 1
S Probability Density Function of a Function of a Random Variable Statistical Analysis Tools, Techniques and SPC 13
J Definition Form Fit or Function - Materials Composition and Manufacturing Processes? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 2
J Function of a Change Number in our ECN / document vault program as a tie-in Problem Solving, Root Cause Fault and Failure Analysis 3
M Quality System Procedure for HR Function needed Document Control Systems, Procedures, Forms and Templates 4
S Critical to manufacturing but not product function - Non-conformance or Not? Nonconformance and Corrective Action 12
M TS 16949 and Form, Fit or Function? What about Calibration of Oven Controllers? IATF 16949 - Automotive Quality Systems Standard 5
