Humidity not recorded weekly - How would you Correct it?
P
Pudge
Hello again,
We just recently went through our registrar audit. All in all, we did ok. Except we received a minor nonconformity stating that, "Organization's procedures to record Humidity weekly are not being followed." His objective evidence was the Humidity X Chart in QA Lab. Ok, so a CAR was issued, but during the investigation process, I found no procedure in the companies CMS or Procedures Booklet saying that the Humidity would be recorded weekly or at anytime. My question is, How would you close out a CAR in this situation?
Thanks in advance,
Jeremy Hill
CarolX
Hi Jeremy and congrats on one minor…great job.
One question..why is humidity recorded?
Was it something someone started years ago and folks just kept it up? Or is a requirement that the humidity needs to verified on a regular basis. Answer those questions and you can answer your CAR.
Al Rosen
Pudge said:
Hello again,
Thanks in advance,
Jeremy Hill
Do you state that the environmental conditions will be controlled? If so, where do you state this and where is the objective evidence?
Jonell
I think that I would try to dig a bit deeper, there are a couple of things that come to mind here. The first one would be to talk to whoever escorted him during this portion of the audit. Maybe there is a procedure floating around out in your shop that is not under document control. Another possiblity is that there are actual instructions on the chart itself and the auditor read those instructions and found that your company wasn't following them. If that doesn't yield any results, then you may want to consider contacting the registrar to see if he/she can tell you what procedure he/she is referring to.
If all that fails, you might have to answer that no documented procedure exists for the problem stated.
Hope this helps!
Jonell
P
Pudge
The Humidity is supposed to be recorded in the lab for our CMM, while it is known verbally that it is to be done it isn't stated in any procedures that it will be done
Al Rosen
If it is known verbally then it is part of an undocumented procedure. If someone was interviewed during your audit and stated that the humidity is supposed to be recorded and it is not being done, you are not following procedures. You didn't mention which standard, but ISO 9001:2000 does not require a documented procedure except for 6 areas, so a verbal procedure is all that is required. I would start recording the humidity and state that in your answer to the car. A documented procedure would be a good idea in this situation.
Hershal
Metrologist-Auditor
The previous answers are all good. I belive that documenting appropriate environmental conditions is essential to calibration.
A CMM may not necessarily require RH to be recorded however. Temp certainly, vibration of course (e.g. the lab is by a railroad track).....but RH perhaps not. Depends a lot on what you are checking with the CMM and the ambient environment.
Then you also need to procedurize the recording of appropriate enviornmental conditions and train the personnel on that recording. That is the answer the auditor is likely looking for.
Just my thoughts.
Hershal
Sidney Vianna
Post Responsibly
Pudge said:
Hello again,
Thanks in advance,
Jeremy Hill
Jeremy, before you proceed, I believe that you need to know where the requirement is coming from. Your external auditor HAS to identify the source for the requirement. If the requirement comes from one of your own internal documents, he should be able to identify the document back to you. Did you not have a de-briefing or exit meeting? Apparently he did not follow ISO 19011:
"...Nonconformities and their supporting audit evidence should be recorded. Nonconformities may be graded. They should be reviewed with the auditee to obtain acknowledgement that the audit evidence is accurate, and that the nonconformities are understood. Every attempt should be made to resolve any diverging opinions concerning the audit evidence and/or findings, and unresolved points should be recorded...."
G
Greg B
Pudge,
Good points are made by several of the reply posts especially (IMHO) Al and Sidney.
I would definitely have been asking, at the close out (exit) meeting, what did the auditor base his/her NC on (As Sidney stated). Do not be intimidated by the auditor, you are ALLOWED to discuss ALL facets of their findings and argue your case, if necessary.
How you close the CAR out is entirely up to you. Do you want a procedure? The procedure could be the actual ‘Humidity Form’. Just add some text at the top with instructions on how it is to be completed or filed etc. Identify it in your system and Bob's your Uncle. A procedure does not need to be a tomb.
K
Ken K
We use to measure and record temp/humidity of the lab twice a day until we had our ISO17025 audit. The auditor wanted to know the levels at a certain time of day and we couldn't provide the information.
He didn't write us up, just suggested we improve our procedure, so we bought a chart recorder, revised the procedure and let the recorder do the work.
J Warehouse temperature and humidity control EU Medical Device Regulations 7
C One Time Service Supplier - Temperature and Humidity Testing Service ISO 13485:2016 - Medical Device Quality Management Systems 5
J ISO 15223-1: Keep dry vs. humidity limitation label symbol Other Medical Device Related Standards 2
Q Weigh Scale Electronics - Suggested Storage Humidity and Temperature Manufacturing and Related Processes 7
S IEC 60601-1 Humidity Precondition Test IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
S Methods to reduce relative humidity in Datacenter IEC 27001 - Information Security Management Systems (ISMS) 3
M Saturated salts issue - Humidity Chamber General Measurement Device and Calibration Topics 5
V Temperature/humidity requirements in internal metrology laboratory General Measurement Device and Calibration Topics 3
N ESD and Humidity Monitoring in Work Areas Manufacturing and Related Processes 1
Ajit Basrur MS Excel to study Correlation between Humidity & Differential Pressure Excel .xls Spreadsheet Templates and Tools 7
M How to Measure Paper considering Variation and Humidity General Measurement Device and Calibration Topics 10
D Sterile Medical Device Temperature and Humidity (Storage) Labeling Requirements EU Medical Device Regulations 5
Ron Rompen Help with Corrosion (Humidity) Testing Procedure - Sintered Metal Steel Parts Manufacturing and Related Processes 9
J Transformer Compliance Testing, overheat then humidity treat, then dielectric test? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
P Humidity Pre-Conditioning before leakage current and dielectric strength tests IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
B Do I need to perform Gage R&R on a Digital Temperature & Humidity Gage Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 18
J Relative Humidity and Plastic Raw Material Moisture Manufacturing and Related Processes 4
G IEC 61010 Humidity Preconditioning and Condensation CE Marking (Conformité Européene) / CB Scheme 4
M Daily Temperature and Humidity Graph template Document Control Systems, Procedures, Forms and Templates 2
A MSA (Measurement Systems Analysis) for Humidity Machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B Temperature/Humidity inside a store Human Factors and Ergonomics in Engineering 7
M Temperature and Humidity requirements for Raw Material Storage and Quality Labs IATF 16949 - Automotive Quality Systems Standard 13
R 5% to 95% Non-Condensing Humidity Storage Test Conditions and Failure Modes APQP and PPAP 2
D PCBA Lab Temperature & Humidity Requirements - Advice needed Manufacturing and Related Processes 7
M Cl 5.7 Humidity preconditioning required for all Medical Electrical Equipment? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
H What is the ISO Class 7 cleanroom requirement on Temperature and Humidity ? Manufacturing and Related Processes 4
S ETO ISO 11135-1 & ISO 17665-2 - Purity and Quality of Steam (Humidity) Qualification and Validation (including 21 CFR Part 11) 3
T ISO 2230 (Guidelines for Storage of Rubber Products) - Temperature, Humidity & Light Other ISO and International Standards and European Regulations 8
K Desiccants & Humidity Control inside ocean going Shipping Containers Supplier Quality Assurance and other Supplier Issues 5
T Calibration Laboratory Temperature/Humidity goes out of tolerance due to Power Loss General Measurement Device and Calibration Topics 9
E Humidity Pre-Conditioning IEC 60601-1 (2005) IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
D Buying a Temperature and Humidity Device, and Calibration AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
D Will just Heat and Humidity be Adequate to Simulate EtO Sterilization? Design and Development of Products and Processes 2
R Inspection Humidity Control - Range for Mechanical Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
N Chilled Mirror Dew Point Meter for Humidity Measurement Measurement Uncertainty (MU) 2
R Does Humidity affect Electronic Instrument Calibration? General Measurement Device and Calibration Topics 16
D How to use temperature and humidity environmental control data? Statistical Analysis Tools, Techniques and SPC 18
B Analytical Lab Environmental Condition (Temperature & Humidity Control Limit) General Measurement Device and Calibration Topics 5
G Humidity Problem in our Laboratory General Measurement Device and Calibration Topics 12
S Temperature and Humidity Chamber Verification General Measurement Device and Calibration Topics 5
C Need source for temperature and humidity gage General Measurement Device and Calibration Topics 8
M Temperature/humidity monitoring process procedure Manufacturing and Related Processes 2
N Uncertainty calculations for RH (Relative Humidity) sensors Measurement Uncertainty (MU) 5
N Uncertainty for Humidity Probes - Temperature Effect from 0.5?C dew point = 1.3%rh Measurement Uncertainty (MU) 2
I Temperature and humidity storage requirements? US Food and Drug Administration (FDA) 6
J Controlling Temperature and Humidity in the CMM Room and does anyone use Artifacts? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
K Relative Humidity Requirement on Calibration Certificates General Measurement Device and Calibration Topics 5
E Humidity Requirements for an ISO 7 or ISO 8 Medical Device Cleanroom? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
A Relative Humidity + ISO 9001:2000 Audit of Maintenance Department ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 30
A Controlling Humidity in a Textile Testing Laboratory General Measurement Device and Calibration Topics 10
