Humidity Problem in our Laboratory
G
grzesiek
hello everyone
we have a problem with low humidity in our lab, this concerns especially our weighing room
humidity is low (25-30% RH), after attaching two boxes with water to a wall heater which we thought would solve the problem, but unfortunately it only helped to go from 15 to about 27
there is a window in the room and because it is winter i suspect that this could be a problem, still i dont think there's anything to be done in this particular area
i was wondering if buying some humidity controller (preferably cheap), but am worried if that will not affect weighing (sound, turbulation, temperature of the device), can someone reccomend a good one?
we would want to go in the 40-70% RH range
i would appreciate help if someone had simmilar problem and found solution, as well as any ideas to solve the issue
BradM
hello everyone
i was wondering if buying some humidity controller (preferably cheap), but am worried if that will not affect weighing (sound, turbulation, temperature of the device), can someone recommend a good one?
Oh yes... we dealt with the same issue. We bought two units (not expensive ones) and placed in the room. Our balances were on air tables, so vibration did not become a factor. We constantly monitored temperature anyway.
I can look today and see what brand we have. BTW....70% is an awful lot of humidity. Are you sure you need to go that high?
G
grzesiek
hi brad
should have been 40-60 RH
I have read mt materials that 20-80 is a must, best is 40-60, so we are trying for 30-70, but would like 40-60, this is where this 70 came from :)
what is air table btw? would you expect these instruments to affect balances on the wall table?
BradM
hi brad
Gotcha.:agree1: As you are quickly realizing... it is awfully difficult to control the humidity in the room after the fact. We bought some Air King humidifiers to go in the room. They have been doing decent. However, it is worthy to note that the rooms were already controlled to an extent; just not tight enough.
Here is a Honeywell that may work for you:
http ://www .drillspot.com/products/349612/Honeywell_DH90A1007_Whole_House_Dehumidifier - OBSOLETE BROKEN 404 LINK(s) UNLINKED - PLEASE HELP - REPORT POSTS WITH BROKEN LINKS
I haven't used it, though.
Good question.
Here are some products from TMC:
http: //www .techmfg.com/products/tabletop/tabletop_pzt.htm - OBSOLETE BROKEN 404 LINK(s) UNLINKED - PLEASE HELP - REPORT POSTS WITH BROKEN LINKS
They are not inexpensive, but, if you have any vibration issues, these will help.
Otherwise, there are some small granite plates with cushion legs on them that can help a little bit. They are sold by VWR.
Hope that helps.
samsung
hello everyone
Why not to consider putting up one or two Desert Coolers like this in your lab.
We always do it in our labs to achieve RH at about 60%. During winters, we additionally have to put a room heater since we need to maintain the temp at 27 degrees in addition to 60% RH. And indeed we never thought of buying any other device for this purpose.
The desert cooler as shown in the picture is the simplest piece of equipment that can be fabricated anywhere. It can either be fitted in widows or can be placed on a stand inside the room. The desired humidity level depends on the fan speed & the area of the side panels holding grass pads to soak the water.
G
grzesiek
thanks for the info brad
i think the one you pointed would be too big for us, i think something more portable will be needed
G
grzesiek
hi samsung
we have put some wall heaters humidifiers (boxes with water) as we dont want to do too much air current too, cos it could degrade repeatability of our weighings
have you put it in weighing room also?
thanks for replies so far
samsung
hi samsung
we have put some wall heaters humidifiers (boxes with water) as we dont want to do too much air current too, cos it could degrade repeatability of our weightings.
Have you put it in weighing room also?
We have a separate room for precision weighing balances where we do not allow too much air current to flow since, as you pointed, it degrades the efficiency of the weighing systems.
We keep non-precision balances (where too much accuracy is not required) in the outside room (humidity controlled) and we just switch off the desert coolers while weighing in order to avoid any disturbance due to air flow. As it takes only 2-3 minutes for a weighing it does not affect the RH so much to go beyond the tolerance (range - 55 - 65%).
For precision weighing, you need to ensure optimum room humidity for the fact that changes in humidity during weighing can affect the mass of the material being weighed. 40 to 60% RH is the desirable range for the weighing rooms.
Please note that dry air with less than 40 % relative humidity increases the risk of your weighing vessel or the sample to become electrostatically charged to cause weighing errors arising through the electrostatic forces that act between the weighing sample and the surroundings.
Thanks.
Daniel Walker - 2011
we had a honeywell in-line steamer installed in the hvac system above the lab. A $90 wall mounted controller in the lab switches the unit on and off. The humidifier water is supplied by a small water line that they ran off the nearest water supply in the ceiling. A little more cost up front, but no maintenance so far in 3 years. We hold 50% +/- 5% all year round.
Oh, and it sends the humidified air out of the existing ducts which are positioned to eliminate currents along the walls where the balances are. Don't place balances in the corners of the lab. We found that the corners are problem spots no matter what air distribution method you use.
G
grzesiek
thanks for all the replies guys, this really helped me a lot
I forgot absolutely that the device is "switchable" samsung, thanks :)
"Please note that dry air with less than 40 % relative humidity increases the risk of your weighing vessel or the sample to become electrostatically charged to cause weighing errors arising through the electrostatic forces that act between the weighing sample and the surroundings."
yeah, that's the main reason why we make the effort
C One Time Service Supplier - Temperature and Humidity Testing Service ISO 13485:2016 - Medical Device Quality Management Systems 5
J ISO 15223-1: Keep dry vs. humidity limitation label symbol Other Medical Device Related Standards 2
Q Weigh Scale Electronics - Suggested Storage Humidity and Temperature Manufacturing and Related Processes 7
S IEC 60601-1 Humidity Precondition Test IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
S Methods to reduce relative humidity in Datacenter IEC 27001 - Information Security Management Systems (ISMS) 3
M Saturated salts issue - Humidity Chamber General Measurement Device and Calibration Topics 5
V Temperature/humidity requirements in internal metrology laboratory General Measurement Device and Calibration Topics 3
N ESD and Humidity Monitoring in Work Areas Manufacturing and Related Processes 1
Ajit Basrur MS Excel to study Correlation between Humidity & Differential Pressure Excel .xls Spreadsheet Templates and Tools 7
M How to Measure Paper considering Variation and Humidity General Measurement Device and Calibration Topics 10
D Sterile Medical Device Temperature and Humidity (Storage) Labeling Requirements EU Medical Device Regulations 5
Ron Rompen Help with Corrosion (Humidity) Testing Procedure - Sintered Metal Steel Parts Manufacturing and Related Processes 9
J Transformer Compliance Testing, overheat then humidity treat, then dielectric test? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
P Humidity Pre-Conditioning before leakage current and dielectric strength tests IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
B Do I need to perform Gage R&R on a Digital Temperature & Humidity Gage Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 18
J Relative Humidity and Plastic Raw Material Moisture Manufacturing and Related Processes 4
G IEC 61010 Humidity Preconditioning and Condensation CE Marking (Conformité Européene) / CB Scheme 4
M Daily Temperature and Humidity Graph template Document Control Systems, Procedures, Forms and Templates 2
A MSA (Measurement Systems Analysis) for Humidity Machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B Temperature/Humidity inside a store Human Factors and Ergonomics in Engineering 7
M Temperature and Humidity requirements for Raw Material Storage and Quality Labs IATF 16949 - Automotive Quality Systems Standard 13
R 5% to 95% Non-Condensing Humidity Storage Test Conditions and Failure Modes APQP and PPAP 2
D PCBA Lab Temperature & Humidity Requirements - Advice needed Manufacturing and Related Processes 7
M Cl 5.7 Humidity preconditioning required for all Medical Electrical Equipment? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
H What is the ISO Class 7 cleanroom requirement on Temperature and Humidity ? Manufacturing and Related Processes 3
S ETO ISO 11135-1 & ISO 17665-2 - Purity and Quality of Steam (Humidity) Qualification and Validation (including 21 CFR Part 11) 3
T ISO 2230 (Guidelines for Storage of Rubber Products) - Temperature, Humidity & Light Other ISO and International Standards and European Regulations 8
K Desiccants & Humidity Control inside ocean going Shipping Containers Supplier Quality Assurance and other Supplier Issues 5
T Calibration Laboratory Temperature/Humidity goes out of tolerance due to Power Loss General Measurement Device and Calibration Topics 9
E Humidity Pre-Conditioning IEC 60601-1 (2005) IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
D Buying a Temperature and Humidity Device, and Calibration AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
D Will just Heat and Humidity be Adequate to Simulate EtO Sterilization? Design and Development of Products and Processes 2
R Inspection Humidity Control - Range for Mechanical Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
N Chilled Mirror Dew Point Meter for Humidity Measurement Measurement Uncertainty (MU) 2
R Does Humidity affect Electronic Instrument Calibration? General Measurement Device and Calibration Topics 16
D How to use temperature and humidity environmental control data? Statistical Analysis Tools, Techniques and SPC 18
B Analytical Lab Environmental Condition (Temperature & Humidity Control Limit) General Measurement Device and Calibration Topics 5
S Temperature and Humidity Chamber Verification General Measurement Device and Calibration Topics 5
C Need source for temperature and humidity gage General Measurement Device and Calibration Topics 8
M Temperature/humidity monitoring process procedure Manufacturing and Related Processes 2
N Uncertainty calculations for RH (Relative Humidity) sensors Measurement Uncertainty (MU) 5
N Uncertainty for Humidity Probes - Temperature Effect from 0.5?C dew point = 1.3%rh Measurement Uncertainty (MU) 2
I Temperature and humidity storage requirements? US Food and Drug Administration (FDA) 6
J Controlling Temperature and Humidity in the CMM Room and does anyone use Artifacts? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
K Relative Humidity Requirement on Calibration Certificates General Measurement Device and Calibration Topics 5
E Humidity Requirements for an ISO 7 or ISO 8 Medical Device Cleanroom? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
A Relative Humidity + ISO 9001:2000 Audit of Maintenance Department ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 30
A Controlling Humidity in a Textile Testing Laboratory General Measurement Device and Calibration Topics 10
D Is Temperature & Humidity monitoring in a Metrology / Test Laboratory required? General Measurement Device and Calibration Topics 28
G What material would you use in extreme humidity and mercury vapor lighting? Various Other Specifications, Standards, and related Requirements 20
