Plinkin' mostly, I got it for the target range. Hey, under a "C" note, I couldn't pass it up. Your right it is the bolt hand gun, and I'll have to get back to you on the scope. Don't have the sheet with me.
I have an AR-15 too.
AR16 Specifications
·CALIBER .223 REM (5.56 MM NATO)
·MODES OF FIRE: SAFE/SEMI/AUTO/BURST
·20/30/40 ROUND MAGAZINE
·39.25" OVERALL LENGTH
·20" BARREL LENGTH
·RIFLING - 1 IN 7" OR 1 IN 9" OR 1 IN 12"
·WEIGHT W/O MAG. - 7.5 LBS (3.4 KG)
·WEIGHT W/LOADED MAG. - 8.75 LBS (4 KG)
Weight US CUSTOMARY METRIC
Rifle AR-15, 7.2 lb 3.40 kg
without magazine and sling
Sling; adjustable 4 oz 0.11 kg
Empty magazine 4 oz 0.11 kg
Loaded magazine 1 lb 1 oz 0.46 kg
Length
Rifle with compensator 39.625 in 100.65 cm
Barrel 20 in 50.8 cm
Barrel with compensator 21 in 53.34 cm
Mechanical features
Rifling right-hand twist 6 grooves 1:7
Method of operation direct gas
Type of breach mechanism rotating bolt
Method of feeding magazine
Cooling air
Trigger pull 5.5 to 9.5 lb 2.49 to 4.31 kg
Ammunition
Caliber .223 5.56 mm
Type ball,blank,dummy,tracer
Firing characteristics
Muzzle velocity (approx) 3,100 fps 94,488 cmps
Muzzle energy 1,322 ft-lb 1,785 N-m
Chamber pressure 52,000 psi 358,540 kPa
Maximum rate of fire
Semiautomatic 45 rds/m
Sustained rate of fire 12/15 rds/m
Maximum range 3,938 yds 3,600 meters
Maximum effective range
Individual point targets 602 yds 550 meters
Area targets 875 yds 800 meters
AR16 Specifications
·20" BARREL LENGTH
Length
Mechanical features
Cooling air
Ammunition
