HV Test of HF Surgical Unit
We test the HF Surgical Unit . If suppose working voltage is 890Vrms Between live and applied part then as per the table 6 of 60601-1 we have applied test voltage 2 x (√2U+ 1 500) (approx : 6.3 KV). But EUT is not pass on 6.3 KV , so as per the particular standard 201.8.8.3
lf, during dielectric strength testing of solid insulation forming MOPP, a breakdown or flashover occurs at the Creepage Distance specified in
8.9 of the general standard and 201.8.5.1.2 of this standard, then the test shall be carried out on the components which provide MOPP, such as
transformers, relays, optocouplers or Creepage Distance on printed circuit boards.
So can we test on transformers, relays, optocouplers components? And how much KV we have applied.
Regards
Roshan
Peter Selvey
Yes, normal dielectric strength is for solid insulation only (usually some type of plastic), it's a kind of ageing test.
And most modern materials will be fine, recently I tested normal 300V PVC insulation at 10kVrms and it didn't break down.
But it is difficult to do in practice as you need to isolate out the plastic material and test. Even testing components may have trouble. For example, testing a transformer may still have cr/cl path for the windings around the edge of the plastic insulation. You really need to cut apart the transformer and test the plastic on its own. Or ask for a sample of the transformer bobbin without any winding and test that with foil on each side, making sure there is enough space. Same for relays etc.
I am surprised that IEC 60601-2-2 does not use any modified values. The ESU voltages that are output are highly regulated and only appear briefly. Therefore the insulation is not subject to long term stress or significant transient voltages. The test values in IEC 60601-1 are really designed around mains voltages that are long term with high transients.
However, the test should take into account the peak voltage, which may be around 6kV anyway. In my opinion, the test for the unit should be the same as the test for accessories, Vpeak (test) = Upeak +1000V. For example if the open circuit output voltage is measured at 6kVp, the test voltage peak should be 7000Vp, which can be 7000Vdc or 4950Vrms. I think the HF dielectric strength test should also be done, but for components (it would be difficult to test an assembled unit as the capacitive load would be too high).
Finally to note that measurement of peak and rms at high frequency is difficult to do accurately. If you not done any checking or validation of the measurement system at the frequency of interest, then assume an error of ±20%, and keep in mind that errors of ±50% are possible with HV probe/oscilloscope set up, even if "calibrated". The calibration is for dc/low frequency only and does not apply at high frequency. Plus there are common setting errors in the scope that can have a large impact on the measured values.
C What is the most appropriate Bioburden Test Method for Surgical Gloves ISO 13485:2016 - Medical Device Quality Management Systems 10
I Dielectric Test for HF Surgical Equipment (IEC 60601-2-2 clause 201.8.5.1.2) IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
H Surgical Sealant Package Integrity Test for Glass Vial Filled Product Other Medical Device Related Standards 3
E Test report to certify compliance with IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 2
E Tensile test machine, tinius olsen 602 Manufacturing and Related Processes 1
M Test failure Root cause not found Customer Complaints 10
D Tip test 10° -> 5° IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
M Sponsor name presented in the test report EU Medical Device Regulations 4
M Packing Validation & Accelerated Aging Test ISO 13485:2016 - Medical Device Quality Management Systems 2
S OEM full range calibrations vs Validation special test points Medical Device and FDA Regulations and Standards News 0
S Shelf Life Test for IFU and Implant Card Other Medical Device Related Standards 1
S Critical characteristic on manufacturing operations test procedure Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
S Knee Implant (Femoral -Cobalt chrome)-Sub chronic toxicity test (ISO 10993-11)choice of root Medical Device and FDA Regulations and Standards News 2
S Non parametric test for semi-quantitative data. Statistical Analysis Tools, Techniques and SPC 5
Ed Panek Disaster Recovery Test IT (Information Technology) Service Management 3
Z Is Op Amp Common-Mode Rejection Ratio (CMRR) test applicable to battery operated devices? Other Medical Device Related Standards 0
E When to perform accelerated aging studies and transport test(OQ or PQ) Qualification and Validation (including 21 CFR Part 11) 4
A Test requirements for marketing in US when RATED values are not of US IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
H Secondary Circuits, Voltage Test and Clearance/Creepage IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
S Fogging test as per DIN 75201(50ug/g ) VDA Standards - Germany's Automotive Standards 3
E 60950-1 resistance to abnormal heat test Various Other Specifications, Standards, and related Requirements 0
S User evaluation for self monitoring blood glucose test systems US Food and Drug Administration (FDA) 4
E MSA for Push and Pull test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
J Confusing on Harmonic Emissions/Voltage Fluctuations/Flicker test for CISPR 11 Class A Equipment IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
E Routine production tests - dielectric voltage withstand test IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
Crimpshrine13 Laboratory Scope - Calibration vs. Test Methods - IATF 16949 IATF 16949 - Automotive Quality Systems Standard 3
R Accelerated Aging - Creating test samples - Implantable medical device Question Other Medical Device Related Standards 4
L ASQ's Biomedical Auditor Course Test ASQ - American Society for Quality 1
W Regarding Requirement for Hi pot & Leakage Current test Station Set-up IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
R Regulatory Affairs Certification (RAC) prep - Practice test versus actual exam Professional Certifications and Degrees 1
R SAT (System Accuracy Test) temperature according to AMS2750E AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
R MSA for ATE (Automatic Test Equipment Embedded Software) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
D Test summary report example for design validation wanted - ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 1
S Documenting Design Verification Test Results (ISO 9001) Design and Development of Products and Processes 1
A Earth leakage current test for Permanently installed Large scale MEE IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
