Hyperlink/Word Protection - Procedures hyperlinked from a master list
E
energy
Currently, we have some procedures hyperlinked from a master list which contains the procedure Names and Numbers. The procedures are password protected and are on a read only access drive. The problem: When I password protect the master document list, I lose the hyperlink function to the linked procedures. Any ideas? As we progress further, I want to insert hyperlinks into the procedures themselves to access forms that are mentioned. If it is determined that I cannot password protect a hyperlinked document, time for a change in plans. I've read all the posts regarding Adobe and realize that it is desirable, but I want to be absolutely sure that this isn't cockpit problems. Laura M., what have you done about it?
energy
G
Graeme
May I ask some dumb computer-related questions that might apply?
  • Is this a purely internal computer network or is there outside access to it as well? (That determines the level of security you need.)
  • What type of operating system are you using on the servers and the workstations? (Some are better than others in security.)
  • Is your master list a web page, a Word document, or an Acrobat PDF file? (It makes a difference how you do it.)
I use a web page as the master list and link to all documents. The documents are PDF files in a read-only folder on a server. (Only the document coordinator - me - has full access.) Users log on to the network at their computers, which gives them access to the folder. I have not had any problems with using a web page.
I have had problems using hyperlinks between documents if I created the link in Word or Acrobat. However, the problems have been to do with the way the link is named and handled rather than the access security. I have stopped embedding links for now. I plan to go through documents to add links later, once the rate of continual improvement of the system slows down ...
Graeme C. Payne
ASQ Certified Quality Engineer
[email protected]
E
energy
Al
I did what you suggested. My "handle" is tenergy, as there is another energy out there. Who'd a thought? Thanks for the tip.
Connecticut is beautiful right now.
energy
Graeme, e-mail on it's way to you with the particulars of your inquiries. Thanks for the assistance.
[This message has been edited by energy (edited 03 July 2001).]
I
ISO Chick
Hi all
Speaking of Hyperlinks is there anyone out there that can help me, at my wits end.......
Using Microsoft Visio at the minute for all my flowcharts, and as people have said before, using a flowchart for the basis of my ISO 9000:2000 manual and then hyperlinking down through the layers. I am the only one in the company with this software so pasting it into word documents so that everyone can access read only documents. Only thing is the hyperlinks don't transfer and having trouble hyperlinking the sections I want in word
Does anyone have anything that can help me................ please...........
Brian L
Hi ISO Chick ,
Hope this is of some assistance to you , I also encountered some problems with the links between viso and word. If you are putting visio charts into word , right click on the flowchart and tell it to copy drawing and paste into your word document , this will bring the links with it so that you can edit the chart directly from the word doc by double clicking on it. I found this to be the best method of bring visio into word. If you do it another way word will think it's a picture and won't let you edit it, which is extremely annoying as like you i've been adding flowcharts into procedures.A picture is worth a thousand words!!
If it refuses to work , i found that deleting the chart from word and trying again worked (after banging my head off the desk a few times!!!)
Regards,
Brian L
L
Laura M
All our forms are on a .html page with links. I don't have hyperlinks in protected word docs. Also - I don't use word docs - I use .pdf. Haven't run into your situation, but thanks for the heads up.
Trakmann
ISO Chick,
(this is Trakman at home)
Don't put hyperlinks in the Visio object, put them at the top or bottom of the page, in word.
The trick with the Visio stuff is to make it about 3/4 the size of the page that you work on in Visio. This way you can copy and paste into word without having annoying anchor & re-size problems.
For read only documents you need to protect them. Don't protect them using the "Read only" feature in word, select "tools --> Protect Document --> Forms" this will prevent people from modifying them off-line. The "read only" feature can be easily bypassed - re-open the document and delete the password!.
Purely as a logistical suggestion, keep hyperlinking out of general P&P's. This will save you serious re-work if they get moved, or re-titled, or whatever.
Have a HTML page with all links on it to all documents (or sub-pages)this works well as your efforts to make the system work flawlessly focuses on a few pages, not the entire system.
An on-line system is well worth the learning curve.
Trakman.
J Gear Surface Finish - Print with the word "calibrated" Manufacturing and Related Processes 2
S Issuing of CoC to Customer in a Word or Excel format ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
B AS9110 Audit Check Sheet wanted Excel or Word Document AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
A Usable version of MDR in Word format CE Marking (Conformité Européene) / CB Scheme 0
Y Excel Automation - Printing Word Documents from within Excel Excel .xls Spreadsheet Templates and Tools 0
qualprod NC if word "development" stated in Policy? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
E Definition Integrity - The meaning of the word INTEGRITY in ISO 13485 Control of Records Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 6
J How to understand the word "include" in IATF 16949 IATF 16949 - Automotive Quality Systems Standard 2
Q Including the Word "Risk" into the Quality Policy (ISO 9001:2015)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
T Parts Lists - Use of the word "off" against Quantity Coffee Break and Water Cooler Discussions 2
J Does the word "claim" in ISO 9001 Clause 8.2.2 mean "requirement"? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
N Microsoft Word - How to make high-light go away after text is put in Excel .xls Spreadsheet Templates and Tools 5
J Keyboard issue in Word - Making me nuts Coffee Break and Water Cooler Discussions 5
S FDA Forms 482, 483 and 484 - MS Word documents US Food and Drug Administration (FDA) 6
D Scope of ISO 13485 Certification needs the word Production. ISO 13485:2016 - Medical Device Quality Management Systems 9
somashekar Word for the Weekend ~~~ Coffee Break and Water Cooler Discussions 2
S Critical Characteristics of a Word Processor and Excel Software Quality Assurance 2
T "Typing name on MS.Word directly" can be "Electronic Approval Signature" Document Control Systems, Procedures, Forms and Templates 3
M The definition of the word Invalid as in "Password Invalid" Coffee Break and Water Cooler Discussions 7
Manix Exporting Data from MS Access to MS Word or MS Excel Templates Quality Assurance and Compliance Software Tools and Solutions 5
K Definition Audit - Time for a new definition of the word Audit? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 15
K Verification, Validation or Checking? Definition of the word "Checked" Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
V Disabling Copy Paste option in MS Word After Work and Weekend Discussion Topics 30
M Can the same form number be in Word and Excel for ISIR's and such? Document Control Systems, Procedures, Forms and Templates 9
M Converting PowerPoint Presentations into MS Word Documents After Work and Weekend Discussion Topics 6
V Use of the word 'identification number' instead of 'identification code' ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
T Controlled Documents - Can a word document and excel spreadsheet be controlled? Document Control Systems, Procedures, Forms and Templates 5
michellemmm Pagination in Microsoft Word Documents Document Control Systems, Procedures, Forms and Templates 21
H AS9101D Microsoft Word Format: Worth It? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
J Document Format vs Content Revision - Form changed from MS Word to MS Excel Document Control Systems, Procedures, Forms and Templates 7
S Post Market Surveillance SOP - Word Version EU Medical Device Regulations 42
E Signature of Records - Microsoft Word forms Records and Data - Quality, Legal and Other Evidence 7
U New Part 21.137 Quality Manual format example in Word format Federal Aviation Administration (FAA) Standards and Requirements 5
R AS9016 - Notice of Change template in either Word or Excel AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
J What's the meaning of word "map" (Map these requirements with your implemented QMS)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
G Is there an AS9100C to AS9100B word for word comparison chart yet? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
M Requirements for Changing Documentation to correct typos or wrong word selection Document Control Systems, Procedures, Forms and Templates 15
SteelMaiden Today's word: Frisbeetarianism Coffee Break and Water Cooler Discussions 9
B Question about the word "Design" in AS9100 Clause 8.3 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
N What is the Latin word for 'Layered'? Coffee Break and Water Cooler Discussions 12
V Updating Quality Manual - Adding the word Statutory in front of laws and regulations Quality Management System (QMS) Manuals 3
D Microsoft Word problems Document Control Systems, Procedures, Forms and Templates 11
P Revision History in an MS Word document Document Control Systems, Procedures, Forms and Templates 37
J Where to Purchase an MS Word version of ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 28
A How to do Process Flow Charting in MS Word Process Maps, Process Mapping and Turtle Diagrams 15
I Essential Requirements for Medical Devices - Word copy wanted EU Medical Device Regulations 4
T DPMO (defects per million opportunities) - Key word being OPPORTUNITIES Six Sigma 9
T Accountability… A good word or a bad word... Imported Legacy Blogs 2
J eWOM (Electronic Word of Mouth), what is that? Coffee Break and Water Cooler Discussions 0
SteelMaiden Help with MS Office Word 2007? After Work and Weekend Discussion Topics 10
