I have 3 different factors - DOE help
marcusja2002
It's been several years since I conducted a DOE so I'm in need of some help taking the rust off.
I currently have access to excel and google, but no SPC software (Minitab, MATLAB, etc.)
Torque level (1-10), RPMs (350-3500), and the measurements I'll be taking are Actual Torque readings (Ft-lbs).
If I took each option I would have over 1260 different combinations I'd want to take an actual torque value from. Since torque has many factors involved I'd be checking 5-10 bolts per setting (6300, to 12600 bolts).
This is where my brain runs into a wall. While I believe, everything should be linear as the RPMs and torque levels go up so should the actual torque but I'm not 100% sure.
Is there a program or process to help me organize this into a feasible experiment?
Thanks in advance.
Statistical Steven
Statistician
Re: DOE help
You only mentioned two factors (Torque level and RPMs). Your response is Actual Torque readings. There are several designs possible depending on your stage of work. If you want to see if your two factors impact your response, then a simple 2-level design with a center point would suffice.
Torque Level 1 and 10
RPMs 350 and 3500
Center Point 5.5 and 1925 (Torque and RPM respectively).
This is 5 runs x 6 Bolts per run would be 30 observations.
If you want to build a model, you might look into Response Surface Methods.
Thanks in advance.
marcusja2002
Re: DOE help
I know once I do all of this I'm supposed to be able to produce a formula that if I put in a specific level and rpm then it will pop out a specific torque value. Or I reverse it and if I choose a torque value I want it will tell me the level or rpm.
How do I turn the data into that formula or where can I read up on that step?
J DoE (Design of Experiments) - Multiple responses with different factors Using Minitab Software 2
B ANOVA - 2 factors with different levels Using Minitab Software 2
K Different Indications for Use in Different Countries -- how to handle IFU? Other Medical Device Regulations World-Wide 3
John C. Abnet Terms- Different Items in a system ISO 26262 - Road vehicles – Functional safety 0
K How to handle GTINs for different configurations of one device with one part number? Other Medical Device Related Standards 0
D Different limits for new and worn gauges General Measurement Device and Calibration Topics 2
V Sister companies selling same medical device under different names ISO 13485:2016 - Medical Device Quality Management Systems 3
Y What are different Special Inspection Level 1-4 and General spesification 1-3 ? AQL - Acceptable Quality Level 0
K Why 'FD&C act section number' and 'section number' in the title of the act are different? US Food and Drug Administration (FDA) 1
K Biocompatibility Testing - Multile products of different sizes and shapes US Food and Drug Administration (FDA) 2
T Different Authorized Representative and distributors in Saudi Arabia Other Medical Device Regulations World-Wide 0
P Design verification driven by new equipment. How is this different than process validation? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
R Yield Plot for different groupings Using Minitab Software 3
F How do you add accuracies for tools with different measurement devices? General Measurement Device and Calibration Topics 1
R Does any here use an internal auditing tool that works on different platforms? Internal Auditing 3
H What is different between PED certificate and CPR certificate? Manufacturing and Related Processes 2
R QMS Standard appilications on different Defense Sector Quality Management System (QMS) Manuals 1
A Statistical Analysis - Check if these organisms at different concentrations affect the growth of wheat seedlings Using Minitab Software 4
M Different procedure templates for different standards - We have two different management systems ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M Identical Sales Package in Different Countries Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
E Different requirements for Class II and Class III Medical Devices Other ISO and International Standards and European Regulations 5
C Subsidiaries; same/different Quality Policies? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
qualprod Controlling documents in two different Applications ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
A Touch current in single fault conditions test and earth leakage current in normal conditions test, are they really different tests? IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
H IFU in different language other than English EU Medical Device Regulations 5
J Ethicon Suture - Why Ethicon specs are different internationally Other Medical Device and Orthopedic Related Topics 0
A Torque Value for Different types of Fasteners (Socket Head, Button Head, CSK) Manufacturing and Related Processes 2
M Different websites for different markets - FDA, Health Canada or other requirements Medical Information Technology, Medical Software and Health Informatics 4
C PCBA Hardware Component different failure types - How to rate detection? FMEA and Control Plans 8
E Different types of Actions? CARs, OFIs or N/A ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
smryan ISO 9001:2015 8.6 & 8.5.1.h) - Redundant or different? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
V Additional Controls for processing the raw data on different computers (processing system) Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 5
MrTetris Informational Risk Register - Same hazardous situation, different severity of harms ISO 14971 - Medical Device Risk Management 7
A PFMEA severity score different applications FMEA and Control Plans 11
xfngrs How similar or different are IATF 16949 Vs. ISO 13485 IATF 16949 - Automotive Quality Systems Standard 0
I Requirements for different Labeling Levels 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
S CE Marking requirements - A Medical device with different config sold under same name EU Medical Device Regulations 0
B IATF 16949 - Different Registrars for remote and manufacturing sites? IATF 16949 - Automotive Quality Systems Standard 2
W Transport validation to different climate zones ISO 13485:2016 - Medical Device Quality Management Systems 13
W Design and Process Validation - Different? ISO 13485:2016 - Medical Device Quality Management Systems 6
M Is it ok to provide a different language upon request? EU Medical Device Regulations 25
O New stability - Yes or No - Similar product but for different intended use EU Medical Device Regulations 1
D Design Transfer between two companies with different QMS CE Marking (Conformité Européene) / CB Scheme 3
P Any official doc/spec on different types of Yield calculation? Manufacturing and Related Processes 0
R Medical devices certified by different notified bodies EU Medical Device Regulations 6
V Software as control or protection will lead to different Software Safety Class? IEC 60601 - Medical Electrical Equipment Safety Standards Series 18
Q Is it acceptable to mix components from two different lots into an assembly? ISO 13485:2016 - Medical Device Quality Management Systems 1
H Numbering for documents with same content but different language ISO 13485:2016 - Medical Device Quality Management Systems 4
