I have just purchased the all new Core Tools Software (CTS) from AIAG
N
ncwalker
#11
Making a rabbit part is an excellent suggestion. A good concept is to have two databased. One for developement (where you can play around and sort out how stuff works) and one for production that has the real data.
You may find your test entries cannot be deleted.
#12
AIAG will offer a free webinar on 4-4-19, this is the information:
4/4/19 2:00 pm to 4/4/20 EST
Analysis of Risk: Using the New AIAG-VDA FMEA Process
Join us for a 60 minute webinar on the new AIAG-VDA FMEA Handbook! The AIAG program director for the project will present the new Six Step FMEA Process, updated form sheets and new Severity, Occurrence, Detection and Action Prioritization tables. He will also describe the approach that supports the alignment of ISO 26262 for Functional Safety and the FMEA process, the Supplemental FMEA for Monitoring and System Response. Finally, we will share AIAG and VDA’s training plans for the new handbook as well as known OEM plans for adoption, roll-out and customer specific requirements.
  • Discusses new Six Step FMEA Process, updated form sheets, and new Severity, Occurrence, Detection and Action Prioritization tables.
  • Describes Supplemental FMEA for Monitoring and System Response.
  • Reviews known OEM adoption/roll-out plans for handbook including planned customer specific requirements.
  • Communicates AIAG and VDA training plans for new handbook.
Please send to me a email to [email protected] to provide the website adreess for register on this webinar.
Regards
W
#13
I have just purchased the all new Core Tools Software (CTS) from AIAG. I want to use it to correlate all of the data in my current core tools documents. This product is not intuitive at all and I can't figure out how to get it to "work". :blowup: Has anyone else tried to use it that can help get me started? (AIAG has no instructions or training available, I asked)
I totally agree. Their webinars have been completely superficial and have no "operations" value. There are no instructions/training available so far, but I do have their tech support info - as attached.
W
#14
Guys,
If anyone is able to provide a roadmap for making a PPAP in the new CTS software, I would appreciate that very much.
So far, I have manually added a few product families and parts to the "Parts" tab in CTS. Here are some problems I encountered:
- No import function available for Parts
- The attachments that can be attached within the part, are not in sync with the projects associated to it.
- The revision date for each part is technically the date you are creating the part profile and not the actual date you want to enter for the part drawing rev.
- No import available for control plans, process FMEAs, etc.
- No import function available for Customer/Supplier list
I also could not find the way to submit a PPAP (which has the PPAP approval status - approved, rejected, etc.) as mentioned in the first webinar from Oct 3. 2018.
Please let me know if anyone else is having the same issues or I am missing something.
Appreciate it.
- Karan
Slim Pickins
#15
Well Karen, you are not missing anything, it isn't there! You and I are on the same path to nowhere. I have been hacking around and discovered that they only way to enter items is to create the part, then create a "project" about the part, and then go into the project and CTS view to enter data. I also know that regardless of what they said in the webinars, you cannot rearrange rows or columns. You can sort them, but I have been unable to determine how to best accomplish that. Also, the column headings are not in the same sequence as the forms in the AIAG APQP manual (look at control plan view) and they cannot be arranged correctly. I have contacted "support" twice but their answers are as clear as the software. I attached an excerpt below.
My intention was to upload all of my current documentation into this system and then proceed forward, but it looks more and more like all I did was waste $360 and a lot of time looking for what was "promised" in the webinars. :poop:
QUESTIONS TO AIAG:
I am having a difficult time seeing the relationships/ flow of this product. Here are some more questions.
Have you begun, or are you aware of, a user’s blog for this product?
I am assuming that I am required to enter a part, then create a project, and then input data in the CTS view. I am currently trying to populate current data into the system but am having major difficulties.
CTS VIEW
How do I move lines in CTS view to put them in the correct order? (How do I add a line in the middle)
How do I move the column locations? (They don’t match the control plan layout defined in the APQP manual) I can move them by dragging, but it doesn’t save them and they revert back.
Yesterday the process step locked/linked to the operation Type and Operation Disc/Funct. (If I entered a 10 on two lines, the system reworded everything) today they are independent. Thoughts?
PART ENTRY
Location is “greyed out” so I can’t enter data. It won’t save a new part because location is mandatory. I rebooted but no luck. (It worked for one part, but not a second one)
How do I use two part numbers for the same part? (My number and the customers number)
ANSWER FROM AIAG
We don't have a user's blog set up for AIAG CTS. You can always contact us by email [email protected] or call (226) 777 0144 for your technical queries. In addition to that we are planning to add site tour, that can be helpful for initial set up and guiding users through the system.
You are correct about the flow, part->project->cts view is required path.
CTS
1. The functionality is not implemented to change rows/lines, you can sort and filter them to get desired arrangement.
2. That's right the columns are keeping the same position on returning on the page and not saving the previous arrangement, we are working on it and should be available soon
3. Options for Entering Operations (Process Step, Ops Type, and Ops Description/Function) in CTS View
  • Lookup Entry via Process Step. To use the lookup selection method, click the Process Step dropdown menu and select desired option from the list. The list shown is based on values entered at the Part Detail record associated with this Project or via the Reusable Library (Admin section). Once added, you can then freely modify the entry to create a custom entry. This entry will not update the Part Detail or Reusable Library records.
  • Direct Entry. You also have the option to directly enter Process Step, Operation Type, and Operation Desc./Func. information to the CTS View. It is not required to use the lookup method.
Part entry
1. Make sure you add location in the admin panel first to have list available when creating a part
2. Two parts can have the same part number and it will save it successfully since the system is using another set of ids to save parts. You can define your own rules to differentiate between two parts in the number itself.
W
#16
QUESTIONS TO AIAG:
CTS VIEW
PART ENTRY
ANSWER FROM AIAG
CTS
Part entry
_____________________________________________________________________________________________________________________________________________________________
Its *Karan. :)
And If it makes you feel any better, I wasted $1800.
I had a meeting with their tech support and project managers, and have realized that the root cause of all problems is the principal difference between what they said they'd offer, and what they are actually offering.
They said they'd offer a service which would help build PPAPs, but neither can it build PPAPs, nor can it submit them.
I have come up with a few Must Haves for their software development team for us to yield any value off it.
1. Add “Import” function for parts list, control plans, process flows, PFMEAs, customers/suppliers, etc.
2. Create links between parts, their projects, and documents involved in their projects
3. Enable previewing & editing of documents within CTS software
4. Fix “Date of Revision” problem
5. Within-CTS software emailing capability for PPAP submission
6. Duplicate function for existing projects so that same projects/PPAPs can be used for multiple customers
Other than these, there are other features that will help too:
1. Automated tracking of time and due dates to avoid manipulation and enable better metrics
2. Email notifications and Escalation notifications for projects approaching and past due date
3. Detailed metrics for late submissions and agent productivity
W
#18
:uhoh: Sorry!! My sister is Karen and I went right to it without looking.
No problem, Haha.
Hopefully they come up with a solution or I'm asking for a refund because even if they agree to develop all those features, the lead time on those would at least be 4 months
Slim Pickins
#19
I cant believe that their "group of volunteers" didn't call all of this out. It was amazing to me the number of issues I found within the small amount of advancement I made in the process of attempting to use it. It is also amazing that other than this thread, I see nothing else about it on the web other than AIAG touting how awesome it is.
UncleFester
#20
Perhaps someone can create a thread in the cove for self-help in using the software.
Like some new releases, the real bug fixes rely on the users to feedback issues encountered.
I wonder how many users will renew their purchase every year?
J Requirements as a Distributor for Incoming Inspection of Purchased Finished Medical Device Medical Device Related Regulations 0
L Have been purchased by a corporate company ISO 13485:2016 - Medical Device Quality Management Systems 7
S Managing specification changes on standard parts purchased through trading companies Document Control Systems, Procedures, Forms and Templates 2
J Verification of purchased product / Alexa as a medical device ISO 13485:2016 - Medical Device Quality Management Systems 6
F AS9100 D - Verification of purchased product - Sheet metal and aluminum extrusion stock AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
D PPAP a Rebranded Purchased Product (we don't manufacture) IATF 16949 - Automotive Quality Systems Standard 6
W Purchased Part Control Plan (IATF 16949) FMEA and Control Plans 7
K ISO 9001 2015 Exclusions - Product Design is purchased. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
D OQ, PQ Requirement for Aerospace? Recently purchased CNC AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
E ISO 13485 Clause 7.3.2 - Purchased Data Approval and Record Requirements ISO 13485:2016 - Medical Device Quality Management Systems 2
M ISO9001:2015 Clause 8.4 Control of External Processes and Purchased Goods & Materials ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
4 Customer Making Changes to a 510k Device They Purchased 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
K TS 16949 Planning Phase: Raw Materials purchased from Distributer and the PPAP impact IATF 16949 - Automotive Quality Systems Standard 3
M Reagent Status Identification - 7.4.3 Verification of Purchased Product ISO 13485:2016 - Medical Device Quality Management Systems 6
D AS9100 7.4.1 vs 7.4.3 - Ensure purchased product conforms to specified requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
M Meeting 7.4.3 Verification of Purchased Product Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
H PPAP for a US$2 Part Purchased from a local Distributor APQP and PPAP 3
G Requirements for Sub Components in a Purchased Assembly APQP and PPAP 4
M Has anyone purchased their powerball tickets? 17 May 2013 Coffee Break and Water Cooler Discussions 8
G Aspects - Use of Purchased Steel Miscellaneous Environmental Standards and EMS Related Discussions 8
R Recently purchased a large number of gages (measurement equipment) General Measurement Device and Calibration Topics 13
somashekar Design as a Purchased Element in QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
Q 8.3 Control of NC product and 7.4.3 Verif. of purchased product, same treatment? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
S Requirements for Evaluations for Purchased Services ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Q Engineering purchased a new Caliper - 7.6 - Initial Calibration Required? General Measurement Device and Calibration Topics 6
M Can I release an "Approved PPAP" if one purchased component has a Interim Approval APQP and PPAP 2
M 7.4.3 Verification of Purchased Product - Drop Shipments Compliance AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
J Using purchased "Training Doc" (TQS) software - Tips/Tricks Training - Internal, External, Online and Distance Learning 7
J AS9100 Clause 7.4.3 Verification of Purchased Product - OEM C of C required? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
W ISO9001 Clause 7.4.3 - Verification of Purchased Product - Software ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
D The Scope of "Verification of Purchased Product" 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
C CE Mark of a purchased Medical Device with different IFU EU Medical Device Regulations 7
L ATEX for Outsourced and Purchased Products Various Other Specifications, Standards, and related Requirements 6
J MSDS Sheets on Purchased Steel - Do we need them? Occupational Health & Safety Management Standards 18
R Technical File Requirements on a Purchased Item EU Medical Device Regulations 3
W What does "Release of Purchased Serial Products" mean? IATF 16949 - Automotive Quality Systems Standard 7
W Are Purchased Machined Components an "Outsourced Process"? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
D Should Purchased Software for both SPC and Gage R&R be documented in the QMS? Quality Assurance and Compliance Software Tools and Solutions 2
L What are the calibration requirements for a newly purchased measuring device? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
A Environmental Aspects of Purchased Materials and Services Miscellaneous Environmental Standards and EMS Related Discussions 3
M Risk Management for Purchased Devices ISO 14971 - Medical Device Risk Management 6
G How do I add in the company we purchased and their products? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
K Verification of Purchased Product - Help Understanding Clause 7.4.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S Ndc less than 5 (purchased part) - Auditor suggest I get waiver from customer Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
C Incoming Inspection - Consignment Storage of some Purchased Parts Supplier Quality Assurance and other Supplier Issues 4
P Outsourced Process or Supplier? Purchased Formed Metal Tubing ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
T Outsourced Process or Purchased Product - Buying OEM Valves ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
J AS9100 Clause 7.4.3 Verification of Purchased Product (audit Finding) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 30
Hershal ACLASS purchased by ANSI-ASQ General Measurement Device and Calibration Topics 3
D Verification Of Purchased Product In A Recruitment Environment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
