I-MR Chart vs. X-bar & R Chart - Differences
Izoyd
Hi all,
I would appreciate your help in simply explaining to me the differences between an I-MR Chart and an X-bar & R Chart. What are the differences, why would you use one vs. the other, what are the benefits and drawbacks, how would we move from an X-bar & R chart to an I-MR chart, etc.
I am moderately familiar with X-bar & R charts, but have no experience with I-MR charts. I have checked previous threads, but couldn't find one that was more explanatory in nature.
Any help would be appreciated!!
Thank you!
Hi all,
Thank you!
The NIST/Sematech eHandbook of Engineering Statistics is an excellent source for answers to this type of question.
bobdoering
Stop X-bar/R Madness!!
The key difference is if you have little within-sample variation (you typical 5 piece sample, for example), then the range will not represent the long term variation of the process. So, I -MR uses longer time sequence to detect change, assume that 5 samples over time will better represent the long term variation. One thing about traditional SPC, if your sample does not represent the long term variation, then it is not going to mean much when you try to look for trends and shifts.
Darius
The I-MR chart is used when there is no reason to do subgroups (R Chart), one must not subgroup the data unless there is a reason (relationship between such sets of data, not because you need to do so because the R-Chart you learned used 5 data points).
The I-MR is used in continuos processes (ie. chemical industry).
Izoyd
Thank you gentlemen for the input. I have done some additional research and I think I understand things now. A good website I found was: http://www.qualityamerica.com/knowledgecente/knowctrINDIVIDUALX_MOVING_RANGE_CHARTS.htm
However, I have a further question now. From what I can tell there are two ways to calculate control limits for the I-MR charts.
For X-UCL and X-LCL you can either use:
1) X-bar +/- (3 SD) OR you can use
2) X-bar +/- E2MR-bar.
I was told using #1 is considering X & R to be separate sets of data, whereas #2 shows more of a relationship between X & R, but that this is more a principle of theory.
What I'm confused about now is when you would use one set of equations over the other as the actual calculations do vary between the equations? Is it simply theory? Or is there some other consideration?
Again, I appreciate your help!! I think I'm almost there in understanding for your average quality engineer (and not a statistics expert)...
That is the better source. Davis Balistracci also has a series of similar articles in recent issues of quality digest that are similarly helpful
The key to understanding if a control source is reliable is the level of statistical theory that it espouses. The more the theory the less reliable the source. Control charts are not statistically sophisticated. I strongly recommend that you read Donald Wheeler's work and Davis Balistracci's work to get begin understanding these charts
And in answer to your last question #2 is the correct formula. You should never use +|- 3SD as your limits.
standarderrormaker
Bob, sensible advice like this on using Imr charts is hard to find. Your statement about capturing the proper representation of the common cause variation is perfect. We collect a sample every 4 hrs. We have up to 16 cavities when we take a sample. so our reason is primarily time and metrology cost since we would have to take, say 5 shots to use XbarR. But the better argument is that we get a better representation of the process variation by Using Imr and sampling every 4 hrs.Thank you so much!
bobdoering
Your best approach is to do a process capability - by cavity - to find out which cavity shows the most variation - near the vent, near the runner, near heaters, near cooling runs, etc. Based on that, pick the cavity that has the most variation and plot it on an IMR. If you need more that one chart for more than one cavity to find the one that has the loudest "voice of the process", then that is a good idea for the short term.
Also, the capability should yield the best sampling frequency. Just as in machining, in molding there should be at least 5 sampling times between any adjustment or significant change - including possibly addition of material to the feed if it shows up as statistically significant. I am not sure 4 hours is sufficient sampling rate. That would mean you can run that process for 20 hours with no operator intervention.
L The ARL for an X bar Control Chart (n = 5) Statistical Analysis Tools, Techniques and SPC 5
G I-Chart and X bar Chart Control limits Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
L How to interpret the average R bar Value shown in the R Chart Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
O Main difference between X-bar sigma chart / X-bar range chart Statistical Analysis Tools, Techniques and SPC 4
M What is the difference between X Bar - R Charts and Average Chart? Statistical Analysis Tools, Techniques and SPC 7
S What decision rules should be applied for x bar-R chart? Statistical Analysis Tools, Techniques and SPC 10
R Calculation Mean for Control Chart -X Double Bar Statistical Analysis Tools, Techniques and SPC 13
R X Bar R chart - Interpretation in MSA study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M X-Bar Chart - CQE Problem to Solve Statistical Analysis Tools, Techniques and SPC 3
K Individual x Chart - Why use the equation is barX+2.66 bar(MR) Statistical Analysis Tools, Techniques and SPC 6
S Validity of Craig Hane's Global Local Index for X-bar R Chart Assessment Capability, Accuracy and Stability - Processes, Machines, etc. 3
Q X-bar R chart question from CSSBB - QCI CD Professional Certifications and Degrees 2
A Monitoring Out-of-control situations on X-bar and R chart Statistical Analysis Tools, Techniques and SPC 15
S Creating X bar R Chart using XYZ coordinates Statistical Analysis Tools, Techniques and SPC 4
D X Bar Chart - How can I deal with missing values in subgroups Statistical Analysis Tools, Techniques and SPC 12
D x-BAR, p or U chart? Plastics compounding line Statistical Analysis Tools, Techniques and SPC 1
K X bar & R Chart Result - Analysis of the Graph Statistical Analysis Tools, Techniques and SPC 28
W Warping / Flatness SPC - X bar-R chart - Control is Max 0.15 Statistical Analysis Tools, Techniques and SPC 5
K Formulas for X bar & R Chart with one sample size Statistical Analysis Tools, Techniques and SPC 7
R X bar s chart template / form for Excel .xls Excel .xls Spreadsheet Templates and Tools 2
S X bar R chart - Bushing reaming ID - 7 points above or below the center line Statistical Analysis Tools, Techniques and SPC 9
K Seeking: X bar R chart software - Or how to do one in Excel Statistical Analysis Tools, Techniques and SPC 6
K Control limit - How is table for x-bar & R control chart derived? Statistical Analysis Tools, Techniques and SPC 7
A SPC procedure / flow chart Statistical Analysis Tools, Techniques and SPC 2
optomist1 Paynter Chart Example APQP and PPAP 1
A Fabric roll inspection - What type of Control Chart to use? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
Z Putting back excluded rows/data points in a control chart Using Minitab Software 0
B Control chart and sample time Statistical Analysis Tools, Techniques and SPC 1
J Control chart for huge sample size Statistical Analysis Tools, Techniques and SPC 9
R Capability analysis - What is going on this chart? Manufacturing and Related Processes 15
S How MR (Moving Range) in Z-MR chart is calculated Using Minitab Software 5
M What is "setup control chart"? Statistical Analysis Tools, Techniques and SPC 2
D Virtual Documentation via Master Flow Chart? Process Maps, Process Mapping and Turtle Diagrams 4
A Redesigning our process flow chart, PFMEA and Control Plan Process Maps, Process Mapping and Turtle Diagrams 4
K Vigilance process flow chart EU Medical Device Regulations 1
D Control chart applicable? Percentage of compliance with a standard Statistical Analysis Tools, Techniques and SPC 2
G I-chart form for GM GP-12 Customer and Company Specific Requirements 2
D Link between FMEA, flow chart and control plan FMEA and Control Plans 10
B How to do a control chart - Machining product that requires flatness control Capability, Accuracy and Stability - Processes, Machines, etc. 1
D China - Where I can get NMPA complete structure/organogram chart and GB/YY format list China Medical Device Regulations 1
K Turtle diagram or process interaction chart - Making it easier for an auditor Process Maps, Process Mapping and Turtle Diagrams 23
D Should "Waste" be included as Output in SIPOC Chart? Process Maps, Process Mapping and Turtle Diagrams 8
S Assembly House Process Chart ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
K Why calculate LCL in P-chart? Statistical Analysis Tools, Techniques and SPC 4
B GM GP-12 Pre-Launch - They asking for a I chart Statistical Analysis Tools, Techniques and SPC 2
bobdoering SPC Charting frequency calculator for X hi/lo chart Imported Legacy Blogs 0
K Operating characteristic (OC) curve S chart Statistical Analysis Tools, Techniques and SPC 1
K What is the Beta RISK for S chart OF XBAR-S chart Statistical Analysis Tools, Techniques and SPC 0
S Understanding control chart and measurement capability Statistical Analysis Tools, Techniques and SPC 2
F Appropriate Control Chart Statistical Analysis Tools, Techniques and SPC 5
