Hi All!
Anyone who can give me an idea will be much appreciated!
Here is my problem: we run a motor shaft various lengths and diameters, but the problem I have is there is an output keyway on the end and it has to be centered in the diameter of the shaft and cannot be off by more than .001. but the shafts are to long to fit in our comparators. I have not been able to find any other way to check to make sure they are on center other than visually and you can see where that would be a disaster at times. I can supply a print if anyone cares to take a stab at an answer!!
-the keyways are cuts in the end of the shaft and are different widths depending on the diameter of the shaft they also vary in length and depth. Also I need this to inexpensive!!!!
Help if you can
Help if you can
