I need help about Dyeing process - Is dying process a special process?
selsensoy
Hi everyone,
I am Quality Engineer in a tractor manufacturing factory and we are trying to establish Quality Management System and I wonder if dying process should be defined as a special process or not? If it is a special process why? If it is not why? Could you help me about this issue?
:thanx:
Howard Atkins
Forum Administrator
selsensoy said:
Hi everyone,
:thanx:
Welcome to the cove.:bigwave:
As you have posted this in the TS forum whether dyeing is a special process or not is irrelevant as all process need to validated see 7.5.2.1.
For ISO9001 I think that as the process is only to colour the cloth and this can be non destructively tested it is not but I think that all processes should be controlled in some manners as described in 7.6.2.
One thing I think that as a supplier to the tractor industry you are not able to register to TS, see here
http://iaob.org/iso_ts16949_faq.html
D.Scott
Processes are defined by you. It is possible to run a business under a quality system while only defining one process. Personally, I would not be comfortable defining only one process and would try to outline in a practical way what our company does. Your "dying" process could stand alone or it could be part of an overall "Product Realization Process". If, for example, you dyed a material as part of every job order (only enough material for that job), you might consider it a process step and include it in the larger process. If you dyed material and put it into stock for later use on many jobs, it may be better described as a process on its own.
I use the following logic. Can the larger process be done without the "dying"? If so, consider "dying" as a sub-process not used on every job. If not, then it is a part of the larger process and should be included as a "step".
Dave
Howard Atkins
Forum Administrator
Dave
Dave,
I am sorry but I think that you have missed the point. The question is about special processes.
I agree with all you said about the way to define processes
D.Scott
OK, Thanks Howard. Sorry if I misled you selsensoy.
I guess my brain wasn't awake early enough :>) I hope it is just temporary.
Dave
Al Rosen
selsensoy said:
Hi everyone,
:thanx:
If you can verify your process without destroying the product it is not a special process. Please tell us a little more about your dyeing process so that we can help you better. What are the basic steps and how do you determine conformity to the requirements?
selsensoy
our dying process
Hi!
We have 3 requirements for the conformity in dying process.
1-All parts of the tractor body should have been dyed.
2-the paint should not come in great amounts if so we scrape the paint (destroying the paint), sandpaper and re-dying
3-Some parts of the tractor body should have not been dyed because of assemblying if they had been dyed the paint is removed for assembly in the next process.
According to the items mentioned above is our dying process is a special process or not?
:thanx:
Al Rosen
selsensoy said:
Hi!
:thanx:
To answer that, we need to know if all the above can be measured or checked without destroying the paint. Items 1 & 3 seem to be able to be verified by visual inspection so they would not be an issue. That leaves item 2. What is your criteria for "great amounts of paint" and how do you measure this?
selsensoy
the item 2
Hi again,
for the item 2 we don't measure, we make visual inspection if the paint has leaked or not because of the "great amounts of paint"
:thanx:
Howard Atkins
Forum Administrator
The whole idea of a special process is in my view an artifical division.
The requirements odf the standard 7.5.2 are sensible requirements for all processes base on the concept of prevention rather than detection.
Why make artifical divisions.
The requirement of TS that 7.5.2 applies to all processes is one of the areas of sanity in the standard
U Need Help With API Q2 Quality Manual Oil and Gas Industry Standards and Regulations 8
D Need some Help on 8D fault tree analysis Problem Solving, Root Cause Fault and Failure Analysis 6
K Screen printing ink and machine selection_ Need help Manufacturing and Related Processes 6
S Need help on "Country of Origin" Medical Device and FDA Regulations and Standards News 0
SocalSurfer AS9100 new certificate, but need QMS software, help Quality Assurance and Compliance Software Tools and Solutions 2
S Need help with analysing a survey on minitab Using Minitab Software 1
K A proposal for the model Quality Management - I need help for the project ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
R Probability - Need a help to solve the below question Statistical Analysis Tools, Techniques and SPC 5
8 Need Help - Runout - Function Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
S New to FAIR, need help in filling it out AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
R Pls help --- Need expert advice on Video Measurement Measurement Uncertainty (MU) 0
Ajit Basrur Need help to understand HIPAA requirements ISO 13485:2016 - Medical Device Quality Management Systems 17
Z I need help with getting a CFS in China Manufacturing and Related Processes 2
S Need help wrapping my head around confidence vs beta error Statistical Analysis Tools, Techniques and SPC 2
P Received a minor for not having good measureables/goals. Need help with KPIs. IATF 16949 - Automotive Quality Systems Standard 52
A Failed the AS9120B Exam Twice.....Need Help AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
Ajit Basrur Need help in Conditional Formatting for the entire row Excel .xls Spreadsheet Templates and Tools 3
H Need help on Quality Improvement Plan (QIP) Quality Tools, Improvement and Analysis 5
S Help: Need Control Self Assessment Questionnaire for HR Departmental Functions Process Audits and Layered Process Audits 0
M Need help in Calibration of Directional Coupler General Measurement Device and Calibration Topics 2
L Need HELP with Internal Audit Program ISO 13485.2003 Quality Management System (QMS) Manuals 3
J Supporting Processes - Internal Audits - Need help settling a debate IATF 16949 - Automotive Quality Systems Standard 4
A Cpk Formula seems off, need help!? Capability, Accuracy and Stability - Processes, Machines, etc. 11
A Need Help With AEA Auditor Related Situational Questions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
E Transformer Overload Test - Need help IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
C I Need Help with Drafting Conventions!!! Design and Development of Products and Processes 4
M Need help on QMS Development in an AS9100C certified organization AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
R Need Help on Analysis: How to know potential causality model from historical data Problem Solving, Root Cause Fault and Failure Analysis 5
B Need help tracking training for my business Quality Assurance and Compliance Software Tools and Solutions 3
B Need help with a Control Plan for Encapsulation Mold / Trimming / Forming Tooling FMEA and Control Plans 9
S I need help from all of you bros Oil and Gas Industry Standards and Regulations 1
LRE67 Need help identifying this "thing" Coffee Break and Water Cooler Discussions 9
G Need help on Device Description in the Acceptance Checklist for Traditional 510(k) Other US Medical Device Regulations 2
K Need help finding a book on Documentation Book, Video, Blog and Web Site Reviews and Recommendations 8
J Need help/advice on video editing software etc..... Coffee Break and Water Cooler Discussions 8
L Need Help with Case Study Questions Manufacturing and Related Processes 16
W Help explaining the need for the Process Approach AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Ron Rompen Unusual problem with Excel - Need some help Excel .xls Spreadsheet Templates and Tools 7
S Need help on new TS 16949 Rules IATF 16949 - Automotive Quality Systems Standard 5
M Need help with Network Analyzers and which DUT can be Calibrated with it Calibration and Metrology Software and Hardware 2
R Need help on defining scope for Design Verification File for Class III IVD 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
J Help I need your opinion on a News Letter Misc. Quality Assurance and Business Systems Related Topics 15
N Need Help Preparing for Medical Device Quality Engineer Interview Career and Occupation Discussions 2
B Need help on an application we are working on Coffee Break and Water Cooler Discussions 4
S Need help with Project Charter for my Six Sigma Green Belt Project Six Sigma 1
Q Need help on MSA study on a torque analyzer Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
B Need help in adding second location to FDA Registration Other US Medical Device Regulations 4
