I need to make an MSDS for PCB (Printed Circuit Board) Assembly Product
P
Phyllis
:) Hi Folks,
I am working in a PCBA manufacturing firm. Many of the Japanese clients are asking for the MSDS of our product(OEM). Any idea to create one as we do not have any chemical expert in our company?
My idea is to elaborate it into component level like PCB, solder paste, components, ask the suppliers to provide the MSDS for the materials then to consolidate into one MSDS. Any comment?
However, I think we have to prepare the Product Safety Datasheet will be more appropriate instead.
:truce: Phyllis
Bridget
Sounds like a plan
Hi Phylis:
I understand your problem, we often have to collect data from suppliers to consolodated into one MSDS and for the suppliers who cannot supply me with enough information I just searched with google until I find the company who manufacturers the "base" material and start from there. Most of ours are metals and I am not a Metallurgist!
FYI-- there are EU directives that idenitfy the format and the requirements for our medical devices. You might ask you customer if there is any such format or requirements to fit their needs before you start the project.
If your components are significantly different you will just have to list them in one document the best you can, you are the one who understands the most about your product. Companies in Japan will request the CAS# (Chemical Abstract Number) and not every material has one, just be honest and tell them. You can search for the CAS in your search engine and learn more about the number system.
Good luck,
Bridget
Al Rosen
Phyllis said:
:) Hi Folks,
:truce: Phyllis
Hi Phyllis:
You may find this useful. http://www.ccohs.ca/oshanswers/legisl/msds_prep.html
Bridget
Good Link
Thanks Al,
That is a good link and I have bookmarked it also.
Bridget
Al Rosen
Bridget said:
Thanks Al,
Bridget
Try these too.
http://www.msdssearch.com/Default.htm
http://www.msds.com/index.asp
Phyllis:
I believe there is an exemption in the US for electronic circuit board MSDS' since they do not pose a hazard during normal handling and use. The issues are raised for the materials used during fabrication and assembly. Also, Japan may have regulations that are somewhat diffeferent than the US and sometimes language differences create misunderstandings. You may want to research this before supplying anything. But, the files attached may be useful.
  • MSDS scrap cktbd.pdf
  • MSDScktbd.pdf
  • chemicals.pdf
P
Phyllis
Thanks for your information and assistance
Hi Al and Bridget,
Thanks so much for your help and the information are very useful to me. Today, I have attended a seminar, which was conducted by SEIKO EPSON(2 Japanese managers) on Green Materials Purchasing. They introduce the RoHS Directive, and the date directive obligation take effect on July 2006 in Japan.
I would like to share the EPSON WEBSITE as followings:
1) Materials related to Green Purchasing
http://www.epson.co.jp/e/community/environmental_gpurchasing.htm
2) Materials related to Lead Free
http://www.epson.co.jp/e/community/environmental_leadfree.htm
They are useful also for a "fresh" guy(like me) in handling Japan green purchase policy and survey...
:thanx: Phyllis
hmt3660
:) Hi Folks,
:truce: Phyllis
Can you please help share the detals of MSDS for assembled PCB.
[email protected]
Steve Prevette
Deming Disciple
One issue is they are no longer called MSDS's, they are SDS's. And there is an international Global Harmonized Standard for the labeling and SDS'.s If you google "creating an SDS" you will find lots of ads and other pages for how to do it. One example is at How to Create SDS under the GHS | MSDS Authoring Services Inc.. I do not attest to the validity of the information there, it is just one that came up upon search.
Ninja
Looking for Reality
FWIW...beyond the "How do I?" part...there is lasting liability involved.
If you don't have a reasonably capable, and defensible, person already on board you may want to consider having an outside agency or consultant prepare the SDS. Offloading the liability is typically worth the money.
(It isn't really offloading the liability, but having somewhere to pass the buck later if needed).
Randy
Hey guys this is from 16 years ago, all one has to do is a Google search on "Printed Circuit Board MSDS or SDS" to get answers and examples
N Do Material MSDS's Need To Be Controlled? Document Control Systems, Procedures, Forms and Templates 3
Q Medical Device with Lead (Pb) - Do I need to create an MSDS sheet? Other US Medical Device Regulations 1
Q Do we need to keep MSDS documents for all "chemicals" used in the factory? Occupational Health & Safety Management Standards 4
J MSDS Sheets on Purchased Steel - Do we need them? Occupational Health & Safety Management Standards 18
S MSDS for Forklift Battery - Do I need to get an MSDS for our forklift batteries? Miscellaneous Environmental Standards and EMS Related Discussions 15
S Do MSDS's (Material Safety Data Sheets) need to be controlled. If yes, HOW? Document Control Systems, Procedures, Forms and Templates 9
K Need Help With IATF 16949 Audit NC IATF 16949 - Automotive Quality Systems Standard 5
F Defining the need to perform the Proximity magnetic fields immunity tests (IEC 61000-4-39) according to the IEC 60601-1-2 ed.4.1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
D FDA combo product-need to define direct & indirect impact regarding safety,quality & regulatory.Can anyone point me in right direction-SupplierMgmt 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
C Does a Pass or Fail IP test need UoM on the report? Measurement Uncertainty (MU) 0
P Do Barcode scanners need validation in Medical device manufacturing? Manufacturing and Related Processes 6
S ISO 9001: 2015 MR Outputs - "any need for changes to the quality management system' Management Review Meetings and related Processes 13
S Need guidance for Software validation Qualification and Validation (including 21 CFR Part 11) 5
R Do I need to get calibration certificate from ISO 17025 for IATF Audit IATF 16949 - Automotive Quality Systems Standard 8
H Electronic Replacement parts need CE? CE Marking (Conformité Européene) / CB Scheme 0
G Need for update of Declaration of Conformity EU Medical Device Regulations 4
D Do I need MDSAP? ISO 13485:2016 - Medical Device Quality Management Systems 5
bryan willemot Wanted: in need of start up Lock out Tag out program in Excel or Word, your help is much appreciated Occupational Health & Safety Management Standards 3
Q Does a gage used for a visual verification need to be calibrated? Manufacturing and Related Processes 7
B Hi , everyone i need a procedure for validation of design prototype api 6d (valve manufacturing) Oil and Gas Industry Standards and Regulations 1
J Do we need to raise concessions for every noted deviation under AS9100 Manufacturing and Related Processes 3
M Need to set up a "crisis management and business continuity plan" AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
D MDR technical file: does it need to contain duplicates of controlled documents EU Medical Device Regulations 2
R Customer Returns / RMA's & the need for NCR's AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
T Need advice on what inspection equipment to buy. General Measurement Device and Calibration Topics 2
Sam.F Do heat treatment ovens need calibration? General Measurement Device and Calibration Topics 25
T Need 5 why’s help AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
H Need guidance on importation of Custom-made devices into Japan Japan Medical Device Regulations 1
T Need help understanding AS6174 clause 3.1.5. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
B Spare parts of medical device need CE mark? EU Medical Device Regulations 0
F Change in address for critical supplier - does NB need to be informed? CE Marking (Conformité Européene) / CB Scheme 20
leftoverture REACH Folks - We Need Common Sense! RoHS, REACH, ELV, IMDS and Restricted Substances 23
B Whose waste carrier licence do I need? ISO 14001:2015 Specific Discussions 8
I I need some fun examples of teaching the 5 Whys Lean in Manufacturing and Service Industries 43
R First Time Managing Calibration and Measurement System. Need Help. General Measurement Device and Calibration Topics 19
M CE marked medical device - do they need UKAS certified calibration provider ISO 17025 related Discussions 4
C I need some clearing on requirements of Asuring the validity of results ISO 17025 related Discussions 2
C Need help in determining applicable clause for an audit finding (based on AS9120B) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
K Subcontractors Providing Services Under MDD or MDR need ISO 13485 from EU Notified Body? CE Marking (Conformité Européene) / CB Scheme 8
E Need some peer advice Quality Manager and Management Related Issues 18
S Need clarification on UKCA and "Approved Body" UK Medical Device Regulations 7
S What types of changes need to be notified to NBs? Registrars and Notified Bodies 1
B Do I need a Cleanroom to manufacture Medical Devices? ISO 13485:2016 - Medical Device Quality Management Systems 2
J CMO in Canada do they need MDSAP/13485 certification? ISO 13485:2016 - Medical Device Quality Management Systems 1
M Attempting to Poke Yoke a wire crimping process...need help Design and Development of Products and Processes 3
C I need your help to find the action plan for these quality objectives Misc. Quality Assurance and Business Systems Related Topics 23
ChrisM Class 1 non-sterile device, need certified QMS or not? EU Medical Device Regulations 2
Steve Prevette I need a template to solve world hunger, a world class Quality Program, and make lots of money Coffee Break and Water Cooler Discussions 5
C Need to understand difference between an actual Calibration vs. a Calibration check General Measurement Device and Calibration Topics 3
S How many tester quantity we need on the line based on the cycle time and peak volume Manufacturing and Related Processes 3
