IAQG 9100:2016 - QMS Requirements for Aviation, Space and Defense
Marc
Fully vaccinated are you?
International Aerospace Quality Group --> IAQG 9100 - Quality Management Systems - Requirements for Aviation, Space and Defense Organizations
This document standardizes quality management system requirements to the greatest extent possible and can be used at all levels of the supply chain by organizations around the world. Its use should result in improved quality, schedule and cost performance by the reduction or elimination of organization-unique requirements and wider application of good practice. While primarily developed for the aviation, space and defense industries, this standard can also be used in other industry sectors where a quality management system with additional requirements over an ISO 9001 system (e.g.: high reliability critical systems) is needed.
TrustAuto1
Marc,
Where did the Purchasing Requirements of the AS9100 Standard go in Rev. D? e.g. 7.4, 7.4.1, 7.4.2, & 7.4.3. Only section I can find that somewhat related to was A.8 Control Of Externally Provided Processes, Products, and Services. Within our Department of Interactions Chart; Supply Chain is one of our Key Processes that I will have to perform an Internal Audit on. Please advise.
Mike_H
Is there a matrix somewhere showing a comparison between AS9100: 2009 and 2016 text? I have seen something in the past for IS09001
Document Dame
We’re beginning our transition from AS9100C to Rev D and our Rev D certification audit is scheduled for September 2017.
I was informed by our registrar that our Internal Audits for this year must be performed to the Rev D standard.
It's going to be interesting auditing 26 Processes to Rev D before we know if the changes we made to the 26 processes are sufficient to meet the Rev D standard.
How would an auditor view this situation?
That's why I love my job. It's never dull!
howste
Thaumaturge
I have made one, but it contains the full text of the standard so I can't post it here due to copyright restrictions. Maybe I can take out the text and just leave the clause numbers and comments to make it legal to post.
BoardGuy
Though you say you have 26 processes and not all of them will be impacted by the revision of AS9100. I have done a line by line review and base on my organizations QMS we have found that the hype about the “new requirements” are baseless for us.
Your auditor is correct that you will have to perform a system audit to confirm conformance to AS9100D requirements. But you only need to audit the changes that were introduced by AS9100D so existing audits could be used with supplemental audits performed to show how the organization is meeting the new/change requirements.
How is it done you may ask? Simply create a master 10 section audit report for AS9100D and then go section by section referencing audits previously performed to AS9100C. Summarize audit to show existing conformance to requirements and audit just those additional requirements added by Revision D. Bingo, audit is done you’re auditor has evidence that the internal audit was performed to AS9100D.
Mike_H
If you could make the changes and share that , it'd be a start at least.
:thanks:
Document Dame
Thank you for helping me see clearly.
I’ve been concentrating solely on the changes and wasn’t seeing the things that stayed the same.
I’ll get to work on the Master 10 Section Audit Report today.
Your help is greatly appreciated.
Marc AS/EN/JISQ 9100:2016 IAQG Sanctioned Aerospace Auditor Training Available (Nov 2016) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
Sidney Vianna Interesting Discussion Will the IAQG go the IATF way and bypass the Accreditation Bodies? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
I IAQG AS9104 Definition of Employee AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Kevin Walters IAQG Required Audit Days Needed (Please help) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
T IAQG Approved Training Providers vs. Probitas Authentication Approved Training Providers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Sidney Vianna IAQG News New IAQG Resources - AS9104-3 Requirements for Aerospace Auditor Competency & Training Courses AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
Sidney Vianna IAQG SCMH explains "positive risk"..........but does it? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
Sidney Vianna IAQG News IAQG has a new website - December 2019 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
Sidney Vianna Informational New IAQG Document - AS9100 Clarifications of Intent AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
S IAQG guidelines for AS9100 report writing AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
E Participation required in OASIS and IAQG? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
Sidney Vianna High number of certificate suspensions in the IAQG OASIS database AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 20
Marc IAQG-OASIS - 9101:2016 Form 4: Cause Code Listing Now Included in Form AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
Marc IAQG Cleveland, Ohio Meeting - October 16-19, 2017 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
R Questioning legitimacy of CBs if not in IAQG-OASIS Database - AS9100 Certificate Registrars and Notified Bodies 8
Sidney Vianna IAQG Winter 2016 Newsletter Available AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
Marc IAQG announces 9100D:2016 Deployment Support Webinars (Winter 2017) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
Marc The IAQG OPMT has posted an updated Resolutions Log AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
D Interpretation of new IAQG ruling - Audit duration for nonconformance verification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
Marc IAQG Listed AS9100 National Accreditation Bodies as of 29 June 2014 ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 7
D IAQG OASIS - New tool to calculate Audit Time AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
T Is IAQG planning an update of AS9102? Revision B of AS9102? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Sidney Vianna IAQG OPMT Communiqu? about Unaccredited AS91X0 Certificates AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
J How IAQG plans to ensure that correct PEAR level determination is done by Auditors? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
Sidney Vianna New Visual Identity Logos for the IAQG & the 3 Regional sectors: AAQG, APAQG and EAQG AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
Sidney Vianna AS91X0 Transition Deadline - New IAQG Decision - 2012 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 54
Sidney Vianna IAQG AS9100C Auditor Guidance Material - What to look for ? What to ask AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Sidney Vianna IAQG AS9100 Rev. C Clarifications Document now available AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
M AS9100C - On track to IAQG timeline? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Sidney Vianna The IAQG (International Aerospace Quality Group) Newsletters AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
J IAQG Resolution #67 - Extension of time frame for upgrade to ISO 9001:2008 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
D IAQG Sanctioned Aerospace Auditor Transition Training Training - Internal, External, Online and Distance Learning 1
J OASIS: IAQG Auditor Reporting AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
P IAQG Making electronic versions of appendices to AS9101 Rev D AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
Sidney Vianna AS9100 Rev. B - The IAQG has made available a clarifications document AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
P IAQG General Assembly Forum - Anybody out there attending? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
John Broomfield Zombie Requirements - Registrar's auditors have yet to get IAQG-designed training AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Sidney Vianna AS/EN 9120:2009 for Distributors - News from the IAQG website AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
Sidney Vianna AS/EN 9110:2009 for MRO organizations - News from the IAQG website AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
Sidney Vianna IAQG International Dictionary - Online Resource AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
Sidney Vianna Invitation to attend the IAQG meeting in Phoenix - April 2009 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
Sidney Vianna IAQG Guidance PCAP 001 - Competence Management Guideline AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
K AS9100 Registrar Accreditation has been withdrawn by IAQG Registrars and Notified Bodies 22
Sidney Vianna IAQG Sanctioned Resolutions for the Aerospace QMS Certification Scheme AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
Sidney Vianna IAQG - International Aerospace Quality Group AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
S Ignoring 9100 for certain purchases AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
M AS 9100 Scope for Repair Station with PMA approval AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
C AS 9100 D AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
L AS 9100 D consultant in Delhi, India AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
Nicole Desouza AS 9100 Rev D Gap Analysis AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
