IATF 16949: 2016 and ISO 9001:2015 - How Similar Are They?
Golfman25
#12
Yep. IATF uses 9001 as a base and then goes up from there. So an IATF company will have every applicable 9001 clause covered, as well as the additional requirements for IATF.
For example, 9001 doesn't require a quality manual. IATF does.
Or consider competence. 9001 is very general and says nothing specific about auditors. IAFT has very specific requirements regarding auditor competency.
N
Nedap
#13
The easiest way to understand the difference of ISO-9001:2015 and IATF-16949:2016 is that ISO-9001 is the main Quality Management Systems standard for any type of manufacturing. IATF-16949 is additional requirement of the Automotive Industry. If you are a Tier I Automotive supplier, you are required to have IATF-16949:2016 which includes ISO-9001:2015.
N
ncwalker
#14
Have you looked at IATF 16949? You could not audit that alone, it would make no sense. It is additional rules, and it needs the main rules to function.
ISO9001 is a set of rules that defines a healthy, functioning QMS in ANY process organization. (I did not say manufacturing, one of the main reasons for the big release change is they want to start using it in the medical service industry, ergo a lot of the manufacturing language in it has been replaced).
Anyway, ISO9001 is the baseline.
Then the International Automotive Task Force (IATF) said "Well, this is a good start, but OUR industry has a few nuances in it that ALSO should be done ..." and that is what is in IATF 16949. Other types of industries have different riders.
All of them are set up in this way: Do everything that ISO9001 says, but then ALSO do this additional stuff.
#15
It's not appropriate to call them "rules". They are requirements. Documented information control is a requirement. Not making hand made changes to documents is a rule which is part of an organization who are implementing a documented information requirement to meet ISO 9001.
O Informational Ford Motor Company Customer Specific Requirements for IATF 16949:2016 - 08 Jan 2021 Customer and Company Specific Requirements 0
O Release of Sanctioned Interpretations (SIs) related to Rules 5th Edition and Sanctioned Interpretations related to IATF 16949:2016 IATF 16949 - Automotive Quality Systems Standard 0
L "IATF-Compliant" IATF 16949:2016 certification? What does this mean? IATF 16949 - Automotive Quality Systems Standard 13
N IATF 16949:2016 7.1.5.3.2 External Laboratory - How to approve the Testing Laboratory without accreditation scope IATF 16949 - Automotive Quality Systems Standard 2
M IATF 16949:2016 clause 8.4.2.3 - We don't have ISO 9001:2015 certificate IATF 16949 - Automotive Quality Systems Standard 26
C IATF 16949:2016 Section 8.5.1.2 item d) accessible for use at the designated work area(s) IATF 16949 - Automotive Quality Systems Standard 5
L Comparison matrix between IATF 16949:2016 to ISO 12207, ISO 9001 and Automotive SPICE IATF 16949 - Automotive Quality Systems Standard 3
B IATF 16949:2016 – Technical Specification (eBook edition) IATF 16949 - Automotive Quality Systems Standard 1
B How to comply with IATF 16949:2016 9.3.2.1k - Management review IATF 16949 - Automotive Quality Systems Standard 2
Rameshwar25 Where is Personnel Safety in IATF 16949:2016 IATF 16949 - Automotive Quality Systems Standard 2
O Interview question about IATF 16949 2016 IATF 16949 - Automotive Quality Systems Standard 4
Sidney Vianna IATF 16949:2016 still doesn't get 7.1.4 of ISO 9001:2015 IATF 16949 - Automotive Quality Systems Standard 15
F IATF 16949:2016 transition audit - Internal Audit Closures IATF 16949 - Automotive Quality Systems Standard 13
Sidney Vianna Top 10 Major and minor NC's during IATF 16949:2016 Audits IATF 16949 - Automotive Quality Systems Standard 8
P Interesting Discussion IATF 16949:2016 Clause 9.2.2.3 and Layered Process Audits IATF 16949 - Automotive Quality Systems Standard 18
C IATF 16949 : 2016 - How put in place a Containment for this kind of Major NC IATF 16949 - Automotive Quality Systems Standard 14
A Looking to become an IATF 16949:2016 Certified Auditor IATF 16949 - Automotive Quality Systems Standard 7
SATHYABALARAMAN What are the topics to be covered for Training the employee as per IATF 16949:2016 IATF 16949 - Automotive Quality Systems Standard 2
SATHYABALARAMAN IATF 16949 2016 Mandatory procedure IATF 16949 - Automotive Quality Systems Standard 2
SATHYABALARAMAN IATF 16949 2016 Mandatory procedure Imported Legacy Blogs 0
R IATF 16949:2016 textbook recommendations IATF 16949 - Automotive Quality Systems Standard 1
C Upgrading from ISO 9001:2015 to IATF 16949:2016 - Anyone have a gap analysis tool? IATF 16949 - Automotive Quality Systems Standard 2
C IATF 16949:2016 New CSR (CQI´s) - Share your experience IATF 16949 - Automotive Quality Systems Standard 1
G Combining ISO 9001:2015 and IATF 16949:2016 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C IATF 16949:2016 Cl. 7.2.3 Internal Auditor Competency Requirements IATF 16949 - Automotive Quality Systems Standard 39
M How to get an electronic version of IATF 16949:2016 which is Searchable IATF 16949 - Automotive Quality Systems Standard 8
Icy Mountain ISO9001:2015 & IATF 16949:2016 Gap Analysis Tool IATF 16949 - Automotive Quality Systems Standard 7
J IATF 16949:2016 8.4.1 Control of Externally Provided Products IATF 16949 - Automotive Quality Systems Standard 2
D Does IATF 16949:2016 Clause 7.3 (now 8.3) Apply to "Grandfathered" Products IATF 16949 - Automotive Quality Systems Standard 4
C PDF Copy of IATF 16949:2016 IATF 16949 - Automotive Quality Systems Standard 1
M ISO/TS16949 to IATF 16949:2016 Gap Analysis Questions IATF 16949 - Automotive Quality Systems Standard 2
C Differences between IATF 16949:2016 vs ISO/TS 16949:2009 IATF 16949 - Automotive Quality Systems Standard 13
A Where to find a Draft Copy of IATF 16949:2016? IATF 16949 - Automotive Quality Systems Standard 23
julsbear When will registrars begin audits for IATF 16949:2016? IATF 16949 - Automotive Quality Systems Standard 12
G Insights into the 2016 Version of TS16949 (IATF 16949) IATF 16949 - Automotive Quality Systems Standard 74
F ISO/TS16949 (to become IATF 16949:2016) alignment to ISO 9001:2015 IATF 16949 - Automotive Quality Systems Standard 79
S IATF 16949 Internal Audit Example IATF 16949 - Automotive Quality Systems Standard 7
B Remote IATF 16949 audit preparation General Auditing Discussions 10
R IATF 16949 Certification for new site with transferred product--what is the impact with CSR and scorecards? IATF 16949 - Automotive Quality Systems Standard 0
B IATF 16949 Cert Expire- New certification body IATF 16949 - Automotive Quality Systems Standard 5
M IATF 16949 - Audit of Remote Location/Support Site and IT IATF 16949 - Automotive Quality Systems Standard 4
B Updated IATF 16949 - Will IATF 16949 get revised when ISO 9001:202X is released? IATF 16949 - Automotive Quality Systems Standard 4
S Thoughts on managing ISO 9001, 13485, IATF 16949 and 17025 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
P IATF 16949 requirement - error-proofing in control plan IATF 16949 - Automotive Quality Systems Standard 3
R IATF 16949 - Outsourcing of internal audits Internal Auditing 10
Crimpshrine13 Laboratory Scope - Calibration vs. Test Methods - IATF 16949 IATF 16949 - Automotive Quality Systems Standard 3
L IATF 16949 certification costs IATF 16949 - Automotive Quality Systems Standard 3
