IATF 16949:2016 Cl. 7.2.3 Internal Auditor Competency Requirements
danangsuryowardhono
#13
Yeah i have read in other discussion.. thanks Sir..
Sent from my D6503 using Tapatalk
Stijloor
#14
For example: 3rd Party Auditors will verify (through audit reports/records) that the automotive process audit approach was used during the audit. If they find that the old-style checklist or the clause-by-clause approach was used, you're in trouble. Anything that deviates from the required auditors' demonstrated ability to apply skills and knowledge, is a nonconformity against the competency requirement.
#15
Your lead internal auditor will likely set the requirements to BE an internal auditor. Then you will need to document the education/training/auditing that has occurred for each auditor in ISO or MSA or auditing principles, etc. Add in the time they spent on gap analysis from TS to IATF, toss in the time they spent on APQP teams working on the FMEA's etc. Talk about the time they spent with consultants or other internal auditors defending their gap/FMEA's/audits. Explain that all the audits counting toward IATF were done to the new ISO/IATF clauses. Show your CB auditors that you are using these tools to evaluate their competency.
We passed our IATF16949 audit in June.
malasuerte
#17
So I received an email from our registrar and they specifically addressed internal auditor competency. Basically they compared the requirements of their auditors and the 12+ hours they spent upgrading their qualifications with the suggestion that anything less could be a problem for internal auditors. As I suggested, it's trending toward "certified" internal auditors.
FALSE! INCORRECT and UNTRUE!
Any registrar requiring an external certification would be grounds for an appeal.
Auditors must be trained and competent. ISO 19001 plus the standards provide guidelines on what this means.
Golfman25
#18
So it is FALSE, INCORRECT and UNTRUE that it is TRENDIND towards "certified" internal auditors? The original standard didn't require a process map. But guess what, everyone did them and the 4th edition rules essentially required one. Sure, a registrar couldn't require an external certificate. But they can make it very difficult for you to "pass" without one. You can really go down a rabbit hole with this. Trust me, in several years some type of "certification" will be "normal" and "expected" and the easy way out.
I
ISOexcited
#20
There is nothing in the standard that states a certification is required.
What I have seen done is a sort of job shadow. The QA Manager (who has an extensive background in ISO standards) took a newly selected internal auditor on several internal audits as a co-auditor. After x amount of hours the new auditor then performed their own audit and submitted it for review. This was used to prove competency, and the new auditor was then authorized to perform internal audits on their own.
O Informational Ford Motor Company Customer Specific Requirements for IATF 16949:2016 - 08 Jan 2021 Customer and Company Specific Requirements 0
O Release of Sanctioned Interpretations (SIs) related to Rules 5th Edition and Sanctioned Interpretations related to IATF 16949:2016 IATF 16949 - Automotive Quality Systems Standard 0
L "IATF-Compliant" IATF 16949:2016 certification? What does this mean? IATF 16949 - Automotive Quality Systems Standard 13
N IATF 16949:2016 7.1.5.3.2 External Laboratory - How to approve the Testing Laboratory without accreditation scope IATF 16949 - Automotive Quality Systems Standard 2
M IATF 16949:2016 clause 8.4.2.3 - We don't have ISO 9001:2015 certificate IATF 16949 - Automotive Quality Systems Standard 26
C IATF 16949:2016 Section 8.5.1.2 item d) accessible for use at the designated work area(s) IATF 16949 - Automotive Quality Systems Standard 5
L Comparison matrix between IATF 16949:2016 to ISO 12207, ISO 9001 and Automotive SPICE IATF 16949 - Automotive Quality Systems Standard 3
B IATF 16949:2016 – Technical Specification (eBook edition) IATF 16949 - Automotive Quality Systems Standard 1
B How to comply with IATF 16949:2016 9.3.2.1k - Management review IATF 16949 - Automotive Quality Systems Standard 2
Rameshwar25 Where is Personnel Safety in IATF 16949:2016 IATF 16949 - Automotive Quality Systems Standard 2
O Interview question about IATF 16949 2016 IATF 16949 - Automotive Quality Systems Standard 4
GStough IATF 16949: 2016 and ISO 9001:2015 - How Similar Are They? IATF 16949 - Automotive Quality Systems Standard 15
Sidney Vianna IATF 16949:2016 still doesn't get 7.1.4 of ISO 9001:2015 IATF 16949 - Automotive Quality Systems Standard 15
F IATF 16949:2016 transition audit - Internal Audit Closures IATF 16949 - Automotive Quality Systems Standard 13
Sidney Vianna Top 10 Major and minor NC's during IATF 16949:2016 Audits IATF 16949 - Automotive Quality Systems Standard 8
P Interesting Discussion IATF 16949:2016 Clause 9.2.2.3 and Layered Process Audits IATF 16949 - Automotive Quality Systems Standard 18
C IATF 16949 : 2016 - How put in place a Containment for this kind of Major NC IATF 16949 - Automotive Quality Systems Standard 14
A Looking to become an IATF 16949:2016 Certified Auditor IATF 16949 - Automotive Quality Systems Standard 7
SATHYABALARAMAN What are the topics to be covered for Training the employee as per IATF 16949:2016 IATF 16949 - Automotive Quality Systems Standard 2
SATHYABALARAMAN IATF 16949 2016 Mandatory procedure IATF 16949 - Automotive Quality Systems Standard 2
SATHYABALARAMAN IATF 16949 2016 Mandatory procedure Imported Legacy Blogs 0
R IATF 16949:2016 textbook recommendations IATF 16949 - Automotive Quality Systems Standard 1
C Upgrading from ISO 9001:2015 to IATF 16949:2016 - Anyone have a gap analysis tool? IATF 16949 - Automotive Quality Systems Standard 2
C IATF 16949:2016 New CSR (CQI´s) - Share your experience IATF 16949 - Automotive Quality Systems Standard 1
G Combining ISO 9001:2015 and IATF 16949:2016 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M How to get an electronic version of IATF 16949:2016 which is Searchable IATF 16949 - Automotive Quality Systems Standard 8
Icy Mountain ISO9001:2015 & IATF 16949:2016 Gap Analysis Tool IATF 16949 - Automotive Quality Systems Standard 7
J IATF 16949:2016 8.4.1 Control of Externally Provided Products IATF 16949 - Automotive Quality Systems Standard 2
D Does IATF 16949:2016 Clause 7.3 (now 8.3) Apply to "Grandfathered" Products IATF 16949 - Automotive Quality Systems Standard 4
C PDF Copy of IATF 16949:2016 IATF 16949 - Automotive Quality Systems Standard 1
M ISO/TS16949 to IATF 16949:2016 Gap Analysis Questions IATF 16949 - Automotive Quality Systems Standard 2
C Differences between IATF 16949:2016 vs ISO/TS 16949:2009 IATF 16949 - Automotive Quality Systems Standard 13
A Where to find a Draft Copy of IATF 16949:2016? IATF 16949 - Automotive Quality Systems Standard 23
julsbear When will registrars begin audits for IATF 16949:2016? IATF 16949 - Automotive Quality Systems Standard 12
G Insights into the 2016 Version of TS16949 (IATF 16949) IATF 16949 - Automotive Quality Systems Standard 74
F ISO/TS16949 (to become IATF 16949:2016) alignment to ISO 9001:2015 IATF 16949 - Automotive Quality Systems Standard 79
S IATF 16949 Internal Audit Example IATF 16949 - Automotive Quality Systems Standard 7
B Remote IATF 16949 audit preparation General Auditing Discussions 10
R IATF 16949 Certification for new site with transferred product--what is the impact with CSR and scorecards? IATF 16949 - Automotive Quality Systems Standard 0
B IATF 16949 Cert Expire- New certification body IATF 16949 - Automotive Quality Systems Standard 5
M IATF 16949 - Audit of Remote Location/Support Site and IT IATF 16949 - Automotive Quality Systems Standard 4
B Updated IATF 16949 - Will IATF 16949 get revised when ISO 9001:202X is released? IATF 16949 - Automotive Quality Systems Standard 4
S Thoughts on managing ISO 9001, 13485, IATF 16949 and 17025 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
P IATF 16949 requirement - error-proofing in control plan IATF 16949 - Automotive Quality Systems Standard 3
R IATF 16949 - Outsourcing of internal audits Internal Auditing 10
Crimpshrine13 Laboratory Scope - Calibration vs. Test Methods - IATF 16949 IATF 16949 - Automotive Quality Systems Standard 3
L IATF 16949 certification costs IATF 16949 - Automotive Quality Systems Standard 3
