IATF 16949:2016 clause 8.4.2.3 - We don't have ISO 9001:2015 certificate
Hello friends,
Looking for a clarification on IATF 8.4.2.3; My company is a greenfield and supplying parts to an IATF certified automotive customer for the last six months. They approved us by conducting supplier evaluation audit. Next month they are going to face 1st surveillance audit. The thing is, we dont have ISO 9001:2015 certificate but IATF implementation is under process. We have only consultant's implementation timing plan.
Now, how could my customer justify the scenario to the audit team..? Any suggestions please!
Hendor
Hello MK Ilayaraja!
Your customer (eg a Tier 2) must have an authorization from his customer (eg Tier 1) in order to buy and use yours products.
A report of the 2nd part audit, showing that your company meets the requirements of ISO 9001, should be shared a the (eg Tier 1), to request acceptance.
I recommend that you see the sanctioned interpretation # 8 on this clause (8.4.2.3), which includes the note:
NOTE: The minimum acceptable level of QMS development may be compliance to ISO 9001 through second-party audits, if authorized by the customer.
To see the sanctioned interpretations:
IATF 16949:2016 Sanctioned Interpretations (SIs) – International Automotive Task Force
I hope my comment is helpful
Golfman25
It's right here in the note to the SI
"NOTE: The minimum acceptable level of QMS development may be compliance to ISO 9001 through second-party audits, if authorized by the customer. "
So it's not really your problem. Your customer needs to seek approval from their customer. Happens a lot with small legacy suppliers.
Hello MK Ilayaraja!
Thanks a lot!
Thanks! Much helpful!
Dr. IJ Arora
Hello friends,
My thought is ISO 9001 should have been implemented. The IATF 8.4.2.3 in a way connects risk to not having ISO 9001!! In effect you could interpret this to mean, without ISO 9001, you have created the scope for risks.
If you already have a system in place, and it confirms to ISO 9001, which it should, if you are already well advanced in implementing IATF, then why not self declare you confirm to ISO 9001?
Do feel free to ask additional questions.
malasuerte
Hello friends,
So here is how it works - Customers to the Automotive industry are responsible for their suppliers (Supplier Management). So BMW for example, may be supplied by Bosch, who may be supplied by XXXX, who may be supplied to you. Requirements are expected to be cascaded through the supply chain accordingly.
Since each customer is responsible for their suppliers, part of that responsibility is to audit those suppliers. That is how it is justified.
This same responsibility may be required of your company....if the part you make has a critical component supplied by someone, you should be auditing that supplier.
There is no requirement for auditing of suppliers.
malasuerte
What is 84241? "The organization shall include a second-party audit process in their supplier management approach."
Go ahead...you can say it is not a requirement - but at minimum it is one of the main methods of monitoring your suppliers. Certainly not all suppliers, but critical suppliers for sure! It won't go over well if you tell a Automotive customer that you are not auditing your critical suppliers. We currently are working with over a dozen Auto customers and it is and expectation of every single one! Our company of 140,000 will consider it a requirement.
D Is it required to have the operator initial their work in the IATF 16949:2016 standard? IATF 16949 - Automotive Quality Systems Standard 3
C IATF 16949:2016 Major NC pertaining to 7.1.5.2.1 Calibration/verification records IATF 16949 - Automotive Quality Systems Standard 15
P IATF 16949:2016 Letter of conformity IATF 16949 - Automotive Quality Systems Standard 5
O Informational Ford Motor Company Customer Specific Requirements for IATF 16949:2016 - 08 Jan 2021 Customer and Company Specific Requirements 0
O Release of Sanctioned Interpretations (SIs) related to Rules 5th Edition and Sanctioned Interpretations related to IATF 16949:2016 IATF 16949 - Automotive Quality Systems Standard 0
L "IATF-Compliant" IATF 16949:2016 certification? What does this mean? IATF 16949 - Automotive Quality Systems Standard 13
N IATF 16949:2016 7.1.5.3.2 External Laboratory - How to approve the Testing Laboratory without accreditation scope IATF 16949 - Automotive Quality Systems Standard 2
C IATF 16949:2016 Section 8.5.1.2 item d) accessible for use at the designated work area(s) IATF 16949 - Automotive Quality Systems Standard 5
L Comparison matrix between IATF 16949:2016 to ISO 12207, ISO 9001 and Automotive SPICE IATF 16949 - Automotive Quality Systems Standard 3
B IATF 16949:2016 – Technical Specification (eBook edition) IATF 16949 - Automotive Quality Systems Standard 3
B How to comply with IATF 16949:2016 9.3.2.1k - Management review IATF 16949 - Automotive Quality Systems Standard 2
Rameshwar25 Where is Personnel Safety in IATF 16949:2016 IATF 16949 - Automotive Quality Systems Standard 2
O Interview question about IATF 16949 2016 IATF 16949 - Automotive Quality Systems Standard 4
GStough IATF 16949: 2016 and ISO 9001:2015 - How Similar Are They? IATF 16949 - Automotive Quality Systems Standard 15
Sidney Vianna IATF 16949:2016 still doesn't get 7.1.4 of ISO 9001:2015 IATF 16949 - Automotive Quality Systems Standard 15
F IATF 16949:2016 transition audit - Internal Audit Closures IATF 16949 - Automotive Quality Systems Standard 13
Sidney Vianna Top 10 Major and minor NC's during IATF 16949:2016 Audits IATF 16949 - Automotive Quality Systems Standard 8
P Interesting Discussion IATF 16949:2016 Clause 9.2.2.3 and Layered Process Audits IATF 16949 - Automotive Quality Systems Standard 18
C IATF 16949 : 2016 - How put in place a Containment for this kind of Major NC IATF 16949 - Automotive Quality Systems Standard 14
A Looking to become an IATF 16949:2016 Certified Auditor IATF 16949 - Automotive Quality Systems Standard 7
SATHYABALARAMAN What are the topics to be covered for Training the employee as per IATF 16949:2016 IATF 16949 - Automotive Quality Systems Standard 2
SATHYABALARAMAN IATF 16949 2016 Mandatory procedure IATF 16949 - Automotive Quality Systems Standard 2
SATHYABALARAMAN IATF 16949 2016 Mandatory procedure Imported Legacy Blogs 0
R IATF 16949:2016 textbook recommendations IATF 16949 - Automotive Quality Systems Standard 1
Cats Clause Upgrading from ISO 9001:2015 to IATF 16949:2016 - Anyone have a gap analysis tool? IATF 16949 - Automotive Quality Systems Standard 2
C IATF 16949:2016 New CSR (CQI´s) - Share your experience IATF 16949 - Automotive Quality Systems Standard 1
G Combining ISO 9001:2015 and IATF 16949:2016 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C IATF 16949:2016 Cl. 7.2.3 Internal Auditor Competency Requirements IATF 16949 - Automotive Quality Systems Standard 39
M How to get an electronic version of IATF 16949:2016 which is Searchable IATF 16949 - Automotive Quality Systems Standard 8
Icy Mountain ISO9001:2015 & IATF 16949:2016 Gap Analysis Tool IATF 16949 - Automotive Quality Systems Standard 7
J IATF 16949:2016 8.4.1 Control of Externally Provided Products IATF 16949 - Automotive Quality Systems Standard 2
D Does IATF 16949:2016 Clause 7.3 (now 8.3) Apply to "Grandfathered" Products IATF 16949 - Automotive Quality Systems Standard 4
C PDF Copy of IATF 16949:2016 IATF 16949 - Automotive Quality Systems Standard 1
M ISO/TS16949 to IATF 16949:2016 Gap Analysis Questions IATF 16949 - Automotive Quality Systems Standard 2
C Differences between IATF 16949:2016 vs ISO/TS 16949:2009 IATF 16949 - Automotive Quality Systems Standard 13
A Where to find a Draft Copy of IATF 16949:2016? IATF 16949 - Automotive Quality Systems Standard 23
julsbear When will registrars begin audits for IATF 16949:2016? IATF 16949 - Automotive Quality Systems Standard 12
G Insights into the 2016 Version of TS16949 (IATF 16949) IATF 16949 - Automotive Quality Systems Standard 74
F ISO/TS16949 (to become IATF 16949:2016) alignment to ISO 9001:2015 IATF 16949 - Automotive Quality Systems Standard 79
Q IATF 16949 9.2 Internal Auditor IATF 16949 - Automotive Quality Systems Standard 13
Vader22 INTELEX software for their IATF 16949 QMS IATF 16949 - Automotive Quality Systems Standard 0
D Preparing for IATF 16949 Letter of Conformance Stage 1 audit IATF 16949 - Automotive Quality Systems Standard 4
X IATF 16949 Section 3.2 Change of ownership IATF 16949 - Automotive Quality Systems Standard 2
Sidney Vianna Tesla Lacks Major Automotive Quality Certifications such as IATF 16949 and ISO 9001 IATF 16949 - Automotive Quality Systems Standard 15
W Looking for IATF 16949 (and ISO 17025) QMS software Suggestions Quality Tools, Improvement and Analysis 8
Sidney Vianna IATF 16949 News IATF News - Top 10 IATF 16949 nonconformities and more..... IATF 16949 - Automotive Quality Systems Standard 7
B IATF 16949 clause 10.2 - requirements following a customer complaint. IATF 16949 - Automotive Quality Systems Standard 9
R How many process maps are adequate for a company for IATF 16949? Process Maps, Process Mapping and Turtle Diagrams 17
O IATF 16949 News Upcoming Changes to IATF 16949? IATF 16949 - Automotive Quality Systems Standard 4
