IATF 16949:2016 clause 8.4.2.3 - We don't have ISO 9001:2015 certificate
John C. Abnet
Teacher, sensei, kennari
#11
include a second-party audit process in their supplier management approach."
Good day @malasuerte ;
With all due respect, allow me to respond in defense of @Jim Wynne 's previous comment to this . You are correct in regards to the possible benefits of auditing members of the supply chain if /when needed. Indeed , when developing an IATF 16949 management system I consistently council organizations to establish criteria for what MAY be the impetus for a 2nd party audit, and of course the competency criteria for any who may be involved in performing those audits (7.2.4).
I would, however, council that many coming to this site for answers are very new to this and other topics. Therefore, it is our collective responsibility to ensure our opinions are left at the door unless of course we are stating that comments made are indeed simply our opinions. As with other standards, if there is not a specific requirement, then the requirement does not exist. Therefore, @Jim Wynne 's comment is indeed correct that there is no requirement to perform supplier audits. This of course does not negate your opinion that it can be one option for for assisting with supplier development and/or supplier monitoring.
On a slightly different topic, we should also take care in the use of subjective terms such as "critical". In my experience, a quick survey of what a term means within an organization often results in a multitude of differing answers. Therefore, I council organizations if/when they wish to use terms such as "key" or "important" or "critical" etc..etc..., to have a specific established definition of any such term in order to prevent confusion.
Hope this helps.
Be well.
Sidney Vianna
Post Responsibly
#12
Good day @malasuerte ; there is no requirement to perform internal supplier audits. T
You should fix your post as per my suggestion above, since we are not talking about internal audits; as for the IATF 16949:2016 standard, actually 8.4.2.3 lists 5 stages of supplier development and in 3 of such stages, supplier audits are required. So, in reality there are requirements for supplier audits, unless the supplier is IATF 16949 certified.
John C. Abnet
#13
Arghhhh. The term "internal" was a mistype (brain skip). Thanks for pointing this out @Sidney Vianna . It's too late for me to edit it. As a staff member can you "reset" the edit option so I can fix it? Thank you.
malasuerte
#15
Hope this helps.
Be well.
Sorry if my opinion is causing issues. My view may be skewed working for a large company, when we most definitely, unequivocally must audit our suppliers! I will concede there is no absolute requirement to audit suppliers. But the clause 100% factually states you must have a 2nd-Party audit process. I would imagine there are companies that would not need to audit their suppliers - but you still need to have a process to do so.
8.4.2.4.1The organization shall include a second-party audit process in their supplier management approach. Second-party audits may be used for the following:
a) supplier risk assessment;b) supplier monitoring;c) supplier QMS development;d) product audits;e) process audits.
Based on a risk analysis, including product safety/regulatory requirements, performance of the supplier, and QMS certification level, at a minimum, the organization shall document the criteria for determining the need, type, frequency, and scope of second-party audits.
The organization shall retain records of the second-party audit reports. If the scope of the second-party audit is to assess the supplier's quality management system, then the approach shall be consistent with the automotive process approach. NOTE: Guidance may be found in the IATF Auditor Guide and ISO 19011.
Sidney Vianna
Post Responsibly
#18
John C. Abnet
#19
OK. So, with the SI, there are 4 levels of supplier development, with TWO requiring supplier audits. So, unless the supplier base is IATF 16949 certified, organizations are still required to perform supplier audits according to this S.I. Or am I missing something?
Nope...missing nothing. You noticed the point of my FYI.
Be well.
O Informational Ford Motor Company Customer Specific Requirements for IATF 16949:2016 - 08 Jan 2021 Customer and Company Specific Requirements 0
O Release of Sanctioned Interpretations (SIs) related to Rules 5th Edition and Sanctioned Interpretations related to IATF 16949:2016 IATF 16949 - Automotive Quality Systems Standard 0
L "IATF-Compliant" IATF 16949:2016 certification? What does this mean? IATF 16949 - Automotive Quality Systems Standard 13
N IATF 16949:2016 7.1.5.3.2 External Laboratory - How to approve the Testing Laboratory without accreditation scope IATF 16949 - Automotive Quality Systems Standard 2
C IATF 16949:2016 Section 8.5.1.2 item d) accessible for use at the designated work area(s) IATF 16949 - Automotive Quality Systems Standard 5
L Comparison matrix between IATF 16949:2016 to ISO 12207, ISO 9001 and Automotive SPICE IATF 16949 - Automotive Quality Systems Standard 3
B IATF 16949:2016 – Technical Specification (eBook edition) IATF 16949 - Automotive Quality Systems Standard 1
B How to comply with IATF 16949:2016 9.3.2.1k - Management review IATF 16949 - Automotive Quality Systems Standard 2
Rameshwar25 Where is Personnel Safety in IATF 16949:2016 IATF 16949 - Automotive Quality Systems Standard 2
O Interview question about IATF 16949 2016 IATF 16949 - Automotive Quality Systems Standard 4
GStough IATF 16949: 2016 and ISO 9001:2015 - How Similar Are They? IATF 16949 - Automotive Quality Systems Standard 15
Sidney Vianna IATF 16949:2016 still doesn't get 7.1.4 of ISO 9001:2015 IATF 16949 - Automotive Quality Systems Standard 15
F IATF 16949:2016 transition audit - Internal Audit Closures IATF 16949 - Automotive Quality Systems Standard 13
Sidney Vianna Top 10 Major and minor NC's during IATF 16949:2016 Audits IATF 16949 - Automotive Quality Systems Standard 8
P Interesting Discussion IATF 16949:2016 Clause 9.2.2.3 and Layered Process Audits IATF 16949 - Automotive Quality Systems Standard 18
C IATF 16949 : 2016 - How put in place a Containment for this kind of Major NC IATF 16949 - Automotive Quality Systems Standard 14
A Looking to become an IATF 16949:2016 Certified Auditor IATF 16949 - Automotive Quality Systems Standard 7
SATHYABALARAMAN What are the topics to be covered for Training the employee as per IATF 16949:2016 IATF 16949 - Automotive Quality Systems Standard 2
SATHYABALARAMAN IATF 16949 2016 Mandatory procedure IATF 16949 - Automotive Quality Systems Standard 2
SATHYABALARAMAN IATF 16949 2016 Mandatory procedure Imported Legacy Blogs 0
R IATF 16949:2016 textbook recommendations IATF 16949 - Automotive Quality Systems Standard 1
C Upgrading from ISO 9001:2015 to IATF 16949:2016 - Anyone have a gap analysis tool? IATF 16949 - Automotive Quality Systems Standard 2
C IATF 16949:2016 New CSR (CQI´s) - Share your experience IATF 16949 - Automotive Quality Systems Standard 1
G Combining ISO 9001:2015 and IATF 16949:2016 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C IATF 16949:2016 Cl. 7.2.3 Internal Auditor Competency Requirements IATF 16949 - Automotive Quality Systems Standard 39
M How to get an electronic version of IATF 16949:2016 which is Searchable IATF 16949 - Automotive Quality Systems Standard 8
Icy Mountain ISO9001:2015 & IATF 16949:2016 Gap Analysis Tool IATF 16949 - Automotive Quality Systems Standard 7
J IATF 16949:2016 8.4.1 Control of Externally Provided Products IATF 16949 - Automotive Quality Systems Standard 2
D Does IATF 16949:2016 Clause 7.3 (now 8.3) Apply to "Grandfathered" Products IATF 16949 - Automotive Quality Systems Standard 4
C PDF Copy of IATF 16949:2016 IATF 16949 - Automotive Quality Systems Standard 1
M ISO/TS16949 to IATF 16949:2016 Gap Analysis Questions IATF 16949 - Automotive Quality Systems Standard 2
C Differences between IATF 16949:2016 vs ISO/TS 16949:2009 IATF 16949 - Automotive Quality Systems Standard 13
A Where to find a Draft Copy of IATF 16949:2016? IATF 16949 - Automotive Quality Systems Standard 23
julsbear When will registrars begin audits for IATF 16949:2016? IATF 16949 - Automotive Quality Systems Standard 12
G Insights into the 2016 Version of TS16949 (IATF 16949) IATF 16949 - Automotive Quality Systems Standard 74
F ISO/TS16949 (to become IATF 16949:2016) alignment to ISO 9001:2015 IATF 16949 - Automotive Quality Systems Standard 79
S IATF 16949 Internal Audit Example IATF 16949 - Automotive Quality Systems Standard 7
B Remote IATF 16949 audit preparation General Auditing Discussions 10
R IATF 16949 Certification for new site with transferred product--what is the impact with CSR and scorecards? IATF 16949 - Automotive Quality Systems Standard 0
B IATF 16949 Cert Expire- New certification body IATF 16949 - Automotive Quality Systems Standard 5
M IATF 16949 - Audit of Remote Location/Support Site and IT IATF 16949 - Automotive Quality Systems Standard 4
B Updated IATF 16949 - Will IATF 16949 get revised when ISO 9001:202X is released? IATF 16949 - Automotive Quality Systems Standard 4
S Thoughts on managing ISO 9001, 13485, IATF 16949 and 17025 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
P IATF 16949 requirement - error-proofing in control plan IATF 16949 - Automotive Quality Systems Standard 3
R IATF 16949 - Outsourcing of internal audits Internal Auditing 10
Crimpshrine13 Laboratory Scope - Calibration vs. Test Methods - IATF 16949 IATF 16949 - Automotive Quality Systems Standard 3
L IATF 16949 certification costs IATF 16949 - Automotive Quality Systems Standard 3
