IATF 16949:2016 Major NC pertaining to 7.1.5.2.1 Calibration/verification records
Sidney Vianna
Post Responsibly
#11
It has really put us in a bind.
The referenced SI stipulates: "...the organization is responsible to ensure that there is evidence that the laboratory has been evaluated and meets the requirements of Section 7.1.5.3.1 of IATF 16949..."
A simple self declaration by your customer confirming their calibration lab complies with the above suffices.
:tunnel: Auditor is happy
#14
Since the customer provides the equipment AND the calibration, I content it’s not an “external lab” in the conventional sense that IATF 16949 considers it to be.
@codya24 This is a great case study.
I agree here with FB. However, take it a step further to tie all the bows.
First off, the clause about "External Lab" most certainly does not apply (assuming I understand the process here based on Cody(OP)): The customer manages the equipment they keep on Cody's site. The only thing that Cody's site does, is send the equipment when due. Call this an SLA with the customer. So Cody's org is not sending to an "External Lab". In turn, they are not responsible for that lab.
The clause that is in play is 8.5.3 - Cody's site needs to care for customers' property. So the SLA to send the equipment when due is part of that "care". Cody's site is doing their job.
Cody's site should be responsible for the 10% of the equipment that is theirs.
I would tell the CB and Auditor - This is the customer's property; we are caring for it per 8.5.3. This finding is invalid; please remove.
Enghabashy
#15
The calibration for inspection , measuring & testing equipment are relevant for measuring & gauges used for the fixtures checks ; therefore you should receive the following evidences from your customer :
1- reports of all check points of their owned fixtures & the relevant measuring devices references used to check/ measure the parameters ;
2- copies of all calibration certificates which covering the relevant references ;
3- your internal check form which used as incoming fixtures -they should verify that the relevant references stated in certificates have traced to int./N Standard ;
4- the Cert. have accreditation logo " ISO IEC 17025" covering the scope of measuring ;
5- the essential evidences for appropriate competency of Lab. if they haven't the accreditations ;
6- the written process & formal terms of your customer regarding FIX. checks ; including contracts ; any CSR & relevant records issues accordingly
Enghabashy
#16
The below Requirement should be considered with essential evidences of controls:
8.5.1.6 Management of production tooling and manufacturing, test, inspection tooling and equipment;
* 1-provide resources for tool and gauge design, fabrication, and verification activities;
*2-system for production tooling management, whether owned by the organization or the customer, including:----etc
The organization shall verify that customer-owned tools, manufacturing equipment, and test/inspection equipment are permanently marked in a visible location so that the ownership and application of each item can be determined.
The organization shall implement a system to monitor these activities if any work is outsourced.
P IATF 16949:2016 Letter of conformity IATF 16949 - Automotive Quality Systems Standard 5
O Informational Ford Motor Company Customer Specific Requirements for IATF 16949:2016 - 08 Jan 2021 Customer and Company Specific Requirements 0
O Release of Sanctioned Interpretations (SIs) related to Rules 5th Edition and Sanctioned Interpretations related to IATF 16949:2016 IATF 16949 - Automotive Quality Systems Standard 0
L "IATF-Compliant" IATF 16949:2016 certification? What does this mean? IATF 16949 - Automotive Quality Systems Standard 13
N IATF 16949:2016 7.1.5.3.2 External Laboratory - How to approve the Testing Laboratory without accreditation scope IATF 16949 - Automotive Quality Systems Standard 2
M IATF 16949:2016 clause 8.4.2.3 - We don't have ISO 9001:2015 certificate IATF 16949 - Automotive Quality Systems Standard 26
C IATF 16949:2016 Section 8.5.1.2 item d) accessible for use at the designated work area(s) IATF 16949 - Automotive Quality Systems Standard 5
L Comparison matrix between IATF 16949:2016 to ISO 12207, ISO 9001 and Automotive SPICE IATF 16949 - Automotive Quality Systems Standard 3
B IATF 16949:2016 – Technical Specification (eBook edition) IATF 16949 - Automotive Quality Systems Standard 3
B How to comply with IATF 16949:2016 9.3.2.1k - Management review IATF 16949 - Automotive Quality Systems Standard 2
Rameshwar25 Where is Personnel Safety in IATF 16949:2016 IATF 16949 - Automotive Quality Systems Standard 2
O Interview question about IATF 16949 2016 IATF 16949 - Automotive Quality Systems Standard 4
GStough IATF 16949: 2016 and ISO 9001:2015 - How Similar Are They? IATF 16949 - Automotive Quality Systems Standard 15
Sidney Vianna IATF 16949:2016 still doesn't get 7.1.4 of ISO 9001:2015 IATF 16949 - Automotive Quality Systems Standard 15
F IATF 16949:2016 transition audit - Internal Audit Closures IATF 16949 - Automotive Quality Systems Standard 13
Sidney Vianna Top 10 Major and minor NC's during IATF 16949:2016 Audits IATF 16949 - Automotive Quality Systems Standard 8
P Interesting Discussion IATF 16949:2016 Clause 9.2.2.3 and Layered Process Audits IATF 16949 - Automotive Quality Systems Standard 18
C IATF 16949 : 2016 - How put in place a Containment for this kind of Major NC IATF 16949 - Automotive Quality Systems Standard 14
A Looking to become an IATF 16949:2016 Certified Auditor IATF 16949 - Automotive Quality Systems Standard 7
SATHYABALARAMAN What are the topics to be covered for Training the employee as per IATF 16949:2016 IATF 16949 - Automotive Quality Systems Standard 2
SATHYABALARAMAN IATF 16949 2016 Mandatory procedure IATF 16949 - Automotive Quality Systems Standard 2
SATHYABALARAMAN IATF 16949 2016 Mandatory procedure Imported Legacy Blogs 0
R IATF 16949:2016 textbook recommendations IATF 16949 - Automotive Quality Systems Standard 1
Cats Clause Upgrading from ISO 9001:2015 to IATF 16949:2016 - Anyone have a gap analysis tool? IATF 16949 - Automotive Quality Systems Standard 2
C IATF 16949:2016 New CSR (CQI´s) - Share your experience IATF 16949 - Automotive Quality Systems Standard 1
G Combining ISO 9001:2015 and IATF 16949:2016 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C IATF 16949:2016 Cl. 7.2.3 Internal Auditor Competency Requirements IATF 16949 - Automotive Quality Systems Standard 39
M How to get an electronic version of IATF 16949:2016 which is Searchable IATF 16949 - Automotive Quality Systems Standard 8
Icy Mountain ISO9001:2015 & IATF 16949:2016 Gap Analysis Tool IATF 16949 - Automotive Quality Systems Standard 7
J IATF 16949:2016 8.4.1 Control of Externally Provided Products IATF 16949 - Automotive Quality Systems Standard 2
D Does IATF 16949:2016 Clause 7.3 (now 8.3) Apply to "Grandfathered" Products IATF 16949 - Automotive Quality Systems Standard 4
C PDF Copy of IATF 16949:2016 IATF 16949 - Automotive Quality Systems Standard 1
M ISO/TS16949 to IATF 16949:2016 Gap Analysis Questions IATF 16949 - Automotive Quality Systems Standard 2
C Differences between IATF 16949:2016 vs ISO/TS 16949:2009 IATF 16949 - Automotive Quality Systems Standard 13
A Where to find a Draft Copy of IATF 16949:2016? IATF 16949 - Automotive Quality Systems Standard 23
julsbear When will registrars begin audits for IATF 16949:2016? IATF 16949 - Automotive Quality Systems Standard 12
G Insights into the 2016 Version of TS16949 (IATF 16949) IATF 16949 - Automotive Quality Systems Standard 74
F ISO/TS16949 (to become IATF 16949:2016) alignment to ISO 9001:2015 IATF 16949 - Automotive Quality Systems Standard 79
R How many process maps are adequate for a company for IATF 16949? Process Maps, Process Mapping and Turtle Diagrams 6
O IATF 16949 News Upcoming Changes to IATF 16949? IATF 16949 - Automotive Quality Systems Standard 4
V IATF 16949 GM CSR 10.2.4 Error-proofing requirement IATF 16949 - Automotive Quality Systems Standard 2
D IATF 16949 Clause 7.2.2 - On the job training IATF 16949 - Automotive Quality Systems Standard 2
L IATF 16949 8.3 Exclusions Manufacturing and Related Processes 5
D IATF 16949 7.3.1 Awareness- Supplemental IATF 16949 - Automotive Quality Systems Standard 2
Q IATF 16949 8.4.2.4 Supplier Monitoring IATF 16949 - Automotive Quality Systems Standard 2
J Implementation, establishment and certification of IATF 16949. IATF 16949 - Automotive Quality Systems Standard 6
xfngrs 3 year audit cycle IATF 16949 IATF 16949 - Automotive Quality Systems Standard 10
D IATF 16949 Process Map IATF 16949 - Automotive Quality Systems Standard 19
Vader22 IATF 16949 extended manufacturing site help IATF 16949 - Automotive Quality Systems Standard 4
