IATF 16949 - 7.1.5.3.1 Internal calibration laboratory requirements
bkirch
In reading the requirement of IATF 7.1.5.3.1(shown below), my interpretation is that items a thru f should be a part of the defined scope. I have heard some people say that a thru f are requirements that needs to be specified and implemented, but do not have to be a part of the written scope. Could someone share their thoughts on the correct interpretation?
7.1.5.3.1 Internal laboratory
An organization’s internal laboratory facility shall have a defined scope that includes its capability to perform in the required inspection, test, or calibration services. This laboratory scope shall be included in the quality management system documentation. The laboratory shall specify and implement, as a minimum, requirements for:
a) adequacy of the laboratory technical procedures;
b) competency of the laboratory personnel;
c) testing of the product;
d) capability to perform these services correctly, traceable to the relevant process standard (such as ASTM, EN, etc.); when no national or international standard(s) is available, the organization shall define and implement a methodology to verify measurement system capability;
e) customer requirements, if any;
f) review of the related records.
NOTE Accreditation to ISO/IEC 17025 (or equivalent) may be used to demonstrate the organization’s in-house laboratory conformity to this requirement.
Ajay Akole
Lab Scope means a document describing the no of test or calibration activities carried out in lab, standard used & master / test equipment used for test or calibration
Marc
<snip> 7.1.5.3.1 Internal laboratory
An organization’s internal laboratory facility shall have a defined scope that includes its capability to perform in the required inspection, test, or calibration services. This laboratory scope shall be included in the quality management system documentation. The laboratory shall specify and implement, as a minimum... <snip>
Yup - All of the a through f line items..
Ripitup65
If you are a production facility and use measurement devices and test equipment to support the manufacturing process; this would not fall under the internal laboratory intent. Reference the IATF 16949 FAQ.
batteryguy
Can you direct me to where you see this in the FAQ's, or provide a quotation from the FAQ's? I don't see anything about internal laboratory requirements there.
I have the concerns about properly addressing our lab scope as well. We have an internal lab, but their "scope" is generally material testing, finished product testing, and investigations for manufacturing concerns. Our calibrations are performed by a 3rd party ISO 17025 accredited company. Do we still need to document a lab scope for this, or is it only applicable to "calibration labs"?
jack770214
We got a strength for having a lab manual that satifies all of internal lab requirements. The scope as we documented it is a subset of the lab manual describing the lab capabilities. In any case, no matter what you call it you will need to document all of the internal lab requirements of the IATF standard and be able to justify what your not doing. One auditor we has a fetish on magnehelic gauges and always verifies that the cfm exhaust has been checked...every audit...
Sent from my LGMP260 using Tapatalk
AMIT BALLAL
See page 5 - 7.1.5.3.2- Question 2 for the FAQ related to this.
Ripitup65
Reviewing this again, is the answer of #2 only pertaining to the external laboratory's statement/ability that they cannot use their in-line inspection equipment and claim it as an internal laboratory?
AMIT BALLAL
The question is "If the organization has inspection, measuring and test equipment in the final assembly and test area, is it considered an internal laboratory?"
The question speaks about "Organization", and IATF uses the word for the organization seeking implementation of IATF16949 standard.
This question also speaks about Internal laboratory and related to the organization, and related to final assembly and testing. Hence it cannot be for external laboratory.
As far as inclusion of this question of in section 7.1.5.3.2 is concerned, I have no clue. Correct me if I am wrong.
Woody
Thanks to jack770214 for pointing out a Laboratory Manual received 'bonus points' - information on such manuals is how I managed to step into this rabbit hole...
An internal laboratory is any place within your certified site where calibrations, tests, and even certain measurements take place. So all internal laboratories support production. The FAQ is asking about measurement and testing taking place in final assembly where I would assume it is referenced in the Control Plan or manufacturing process documentation.
Having said that, in addition to stamping, we have an e-coat line. That requires a great deal of daily testing, so we include that as another internal laboratory because the degree of risk (consider risk in all activities) indicates we should exercise more control over that activity.
R IATF 16949 - Outsourcing of internal audits Internal Auditing 10
M Tips on preparing for IATF 16949 Internal Lead Auditor exam Manufacturing and Related Processes 1
J Does anyone have an excel IATF 16949 Internal Audit checklist I could use? IATF 16949 - Automotive Quality Systems Standard 7
V IATF 16949 9.2.2.1 Internal Audit Program - "Process Changes" IATF 16949 - Automotive Quality Systems Standard 11
M IATF 16949 7.2.3 Internal Auditor Competency - Trainer's competency Internal Auditing 7
S IATF 16949: Is "Certified" Internal Auditor mandatory? IATF 16949 - Automotive Quality Systems Standard 9
Ashland78 IATF 16949 Internal Audit Checklist Manufacturing and Related Processes 11
J IATF 16949 CAR - Internal Auditor Requirements IATF 16949 - Automotive Quality Systems Standard 15
T Example wanted - Template for internal audit IATF 16949 IATF 16949 - Automotive Quality Systems Standard 1
H Do you have to perform an full internal prior to IATF 16949 audit? IATF 16949 - Automotive Quality Systems Standard 21
F IATF 16949:2016 transition audit - Internal Audit Closures IATF 16949 - Automotive Quality Systems Standard 13
H Internal laboratory scope requirements - IATF 16949 Cl. 7.1.5.3.1 IATF 16949 - Automotive Quality Systems Standard 1
B Going into IATF 16949 transition without Internal Audits IATF 16949 - Automotive Quality Systems Standard 4
A IATF 16949 - 9.2.2.1 Internal Audit Programme - looking for example IATF 16949 - Automotive Quality Systems Standard 5
B IATF 16949 Cl. 9.2.2.1 - Internal audit program - Types of evidence Internal Auditing 1
D IATF 16949 - Internal Auditor Training/Certification Requirements Training - Internal, External, Online and Distance Learning 2
C IATF 16949 Cl. - 7.2.3 Internal Auditor Competency IATF 16949 - Automotive Quality Systems Standard 1
D Please share your IATF 16949 Internal Audit Plan and Schedule Internal Auditing 13
C IATF 16949:2016 Cl. 7.2.3 Internal Auditor Competency Requirements IATF 16949 - Automotive Quality Systems Standard 39
Q IATF 16949 Cl. 7.2.3 - Internal Auditor Competency and Records IATF 16949 - Automotive Quality Systems Standard 5
Q How can an Internal Auditor Trainer's Competency be Evaluated - IATF 16949 Cl. 7.2.3 IATF 16949 - Automotive Quality Systems Standard 7
P Problem with IATF 16949 Clause 7.2.3 Requirements (Internal Auditor Competency) IATF 16949 - Automotive Quality Systems Standard 3
P IATF 16949 - Internal Audit Frequency Requirements Internal Auditing 2
B Competency of Trainer for Internal Auditor Training (IATF 16949) IATF 16949 - Automotive Quality Systems Standard 11
tony s TS 16949 Internal Audit Trainer Traceability to IATF General Auditing Discussions 6
O Informational Ford Motor Company Customer Specific Requirements for IATF 16949:2016 - 08 Jan 2021 Customer and Company Specific Requirements 0
B Updated IATF 16949 - Will IATF 16949 get revised when ISO 9001:202X is released? IATF 16949 - Automotive Quality Systems Standard 4
O Release of Sanctioned Interpretations (SIs) related to Rules 5th Edition and Sanctioned Interpretations related to IATF 16949:2016 IATF 16949 - Automotive Quality Systems Standard 0
S Thoughts on managing ISO 9001, 13485, IATF 16949 and 17025 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
P IATF 16949 requirement - error-proofing in control plan IATF 16949 - Automotive Quality Systems Standard 3
Crimpshrine13 Laboratory Scope - Calibration vs. Test Methods - IATF 16949 IATF 16949 - Automotive Quality Systems Standard 3
L IATF 16949 certification costs IATF 16949 - Automotive Quality Systems Standard 3
B FCA US Customer Specific IATF 16949- Critical Characteristics 8.6.2 Customer and Company Specific Requirements 0
B IATF 16949 News Six month extension on all valid IATF 16949 certs IATF 16949 - Automotive Quality Systems Standard 10
B FCA US IATF 16949 Customer Requirements updates Customer and Company Specific Requirements 3
S Can assembly manufacturing sub-supplier be certified IATF 16949? IATF 16949 - Automotive Quality Systems Standard 6
D IATF 16949 Requirement for CMMI in a Global Company Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 0
S Definition of "worldwide" in view of IATF 16949 and Product conformity IATF 16949 - Automotive Quality Systems Standard 3
A Document "Correspondence IATF 16949 vs ISO13485" available? IATF 16949 - Automotive Quality Systems Standard 0
H Remote product audits in Coivd-19 - IATF 16949 9.2.2.4 IATF 16949 - Automotive Quality Systems Standard 3
S IATF 16949 - Partial traceability of Aftermarket products IATF 16949 - Automotive Quality Systems Standard 5
M IATF 16949 8.5.1.3 Verification of job set-ups - Do we need secondary check? IATF 16949 - Automotive Quality Systems Standard 7
C Industrial scales and MSA (IATF 16949 requirement 7.1.5.1.1) IATF 16949 - Automotive Quality Systems Standard 30
V Generic IATF 16949 Audit Checklist wanted IATF 16949 - Automotive Quality Systems Standard 3
M Scope of Combined ISO 9001 and IATF 16949 QMS - Non-automotive customers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
